AW: Undefined reference to `__sync_bool_compare_and_swap_4' for some Leon configurations with gfortran
Jan.Sommer at dlr.de
Mon Feb 27 13:15:00 UTC 2017
> -----Ursprüngliche Nachricht-----
> Von: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de]
> Gesendet: Montag, 27. Februar 2017 13:46
> An: Sommer, Jan; devel at rtems.org
> Betreff: Re: Undefined reference to `__sync_bool_compare_and_swap_4' for
> > If I check the different libgfortran.a libraries of
> > sparc-rtems4.12/6.3.0 with nm I get libgfortran.a
> > U __sync_bool_compare_and_swap_4
> Is this reference generated by the compiler or some GCC runtime source code?
> The atomic operations are implemented via the libatomic, so you should only
> have __atomic_() references.
I am not sure if I understand the question correctly.
I checked the mentioned elf.c-file (https://gcc.gnu.org/viewcvs/gcc/branches/gcc-6-branch/libbacktrace/elf.c?view=markup#l960) and
the call to __sync_bool_compare_and_swap_4 does not seem to be dependent on a configuration option of gcc.
The same is true for dwarf.c
There seems to have been a similar issue for hpux: https://patchwork.ozlabs.org/patch/553017/
Would it make sense to set libbacktrace_cv_sys_sync=no in the same way for the respective leon-targets?
> > for the ones in the leon, soft and v8 directory.
> > The libgfortran.a in the leon3 and leon3v7 directory do not have this
> undefined symbol.
> They implement this atomic operation in hardware.
> > Is that correct behavior? If yes, which library do I need to add to the linker?
> It is a compiler or GCC runtime configuration issue.
> > Best regards,
> > Jan
> > Deutsches Zentrum für Luft- und Raumfahrt e. V. (DLR)
> > German Aerospace Center
> > Simulation and Software Technology | Software for Space Systems and
> Interactive Visualization | Lilienthalplatz 7 | 38108 Braunschweig | Germany
> > Jan Sommer
> > Telephone +49 531 295-2494 | Telefax 0531 295-2767 | jan.sommer at dlr.de
> > DLR.de/SC
> > devel mailing list
> > devel at rtems.org
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
