AW: AW: AW: Undefined reference to `__sync_bool_compare_and_swap_4' for some Leon configurations with gfortran
Sebastian Huber
Mon Feb 27 14:25:26 UTC 2017
On 27/02/17 15:15, Jan.Sommer at dlr.de wrote:
>> -----Ursprüngliche Nachricht-----
>> >Von: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de]
>> >Gesendet: Montag, 27. Februar 2017 15:11
>> >An: Sommer, Jan;devel at rtems.org
>> >Betreff: Re: AW: AW: Undefined reference to
>> >gfortran
>> >On 27/02/17 15:08,Jan.Sommer at dlr.de wrote:
>>> > >Ok, thanks for the clarification.
>>> > >I will try to create a patch for gcc and put rtems CC for the discussion.
>> >Another option would be to provide the __sync_() stuff also via libatomic.
> True. I will ask on the gcc mailinglist what they would prefer.
This __sync_() stuff seems to be used in several places in GCC. So,
changing libbacktrace is probably not enough. We need a general solution
for the __sync_() builtins on RTEMS. I don't think GCC can be changed to
emit __atomic_() calls for the __sync_() builtins (I would still try to
ask). The libgcc or libatomic is probably a good place to add them for
RTEMS as functions implemented via __atomic_() builtins.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
