libbsd update to FreeBSD head (2017-01-09)
Tue Jan 10 10:10:00 UTC 2017
Hello,
I updated the libbsd from FreeBSD 9.3 to FreeBSD head (2017-01-09). This
is a very big jump in terms of FreeBSD development. The main goal is to
catch up with FreeBSD and unify the baseline of the different parts of
the libbsd. The network, USB and SD/MMC card parts used different
FreeBSD versions. Thus, using an USB network component didn't work
before due to incompatible network stack interfaces. There will be some
work to do for each supported BSP after the update, e.g. adjustment of
network interface drivers. I guess the x86 support is now broken.
I created a "freebsd-9.3" branch before the update.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
devel mailing list
devel at rtems.org
http://lists.rtems.org/mailman/listinfo/devel
