libbsd update to FreeBSD head (2017-01-09)
Wed Jan 11 01:28:19 UTC 2017
Thanks for the great effort. Is it your intention to attempt to track
the FreeBSD head with libbsd?
On Tue, Jan 10, 2017 at 5:10 AM, Sebastian Huber
> Hello,
> I updated the libbsd from FreeBSD 9.3 to FreeBSD head (2017-01-09). This is
> a very big jump in terms of FreeBSD development. The main goal is to catch
> up with FreeBSD and unify the baseline of the different parts of the libbsd.
> The network, USB and SD/MMC card parts used different FreeBSD versions.
> Thus, using an USB network component didn't work before due to incompatible
> network stack interfaces. There will be some work to do for each supported
> BSP after the update, e.g. adjustment of network interface drivers. I guess
> the x86 support is now broken.
> I created a "freebsd-9.3" branch before the update.
> devel mailing list
> devel at rtems.org
> devel mailing list
> devel at rtems.org
