[PATCH 1/5] score: Replace STATES_DELAYING
Sebastian Huber
Wed Jan 11 10:22:45 UTC 2017
Replace STATES_DELAYING with STATES_WAITING_FOR_TIME.
There is no need for separate timeout thread states. The
Thread_Control::Timer::header and Watchdog_Control::cpu members can be
used to figure out the kind of timeout.
cpukit/libdebugger/rtems-debugger-threads.c | 1 -
cpukit/libmisc/monitor/mon-prmisc.c | 1 -
cpukit/posix/src/nanosleep.c | 2 +-
cpukit/rtems/src/taskwakeafter.c | 2 +-
cpukit/score/include/rtems/score/statesimpl.h | 43 ++++-----------------------
5 files changed, 8 insertions(+), 41 deletions(-)
diff --git a/cpukit/libdebugger/rtems-debugger-threads.c b/cpukit/libdebugger/rtems-debugger-threads.c
index 2e9cf06..64d21c4 100644
--- a/cpukit/libdebugger/rtems-debugger-threads.c
+++ b/cpukit/libdebugger/rtems-debugger-threads.c
@@ -514,7 +514,6 @@ rtems_debugger_thread_state_str(rtems_debugger_thread* thread,
DB_UINT mask;
const struct mapper map[] = {
- { "DELAY", STATES_DELAYING },
{ "DORM", STATES_DORMANT },
{ "LIFE", STATES_LIFE_IS_CHANGING },
{ "SUSP", STATES_SUSPENDED },
diff --git a/cpukit/libmisc/monitor/mon-prmisc.c b/cpukit/libmisc/monitor/mon-prmisc.c
index 5bb4d42..d5e403c 100644
--- a/cpukit/libmisc/monitor/mon-prmisc.c
+++ b/cpukit/libmisc/monitor/mon-prmisc.c
@@ -115,7 +115,6 @@ rtems_monitor_dump_priority(rtems_task_priority priority)
#define WITH_ID(state) (STATES_THREAD_QUEUE_WITH_IDENTIFIER | state)
static const rtems_assoc_t rtems_monitor_state_assoc[] = {
- { "DELAY", STATES_DELAYING, 0 },
{ "DORM", STATES_DORMANT, 0 },
{ "LIFE", STATES_LIFE_IS_CHANGING, 0 },
{ "SUSP", STATES_SUSPENDED, 0 },
diff --git a/cpukit/posix/src/nanosleep.c b/cpukit/posix/src/nanosleep.c
index 10158ff..13f4536 100644
--- a/cpukit/posix/src/nanosleep.c
+++ b/cpukit/posix/src/nanosleep.c
@@ -49,7 +49,7 @@ static inline int nanosleep_helper(
_Thread_queue_Context_initialize( &queue_context );
_Thread_queue_Context_set_thread_state(
&queue_context,
- STATES_DELAYING | STATES_INTERRUPTIBLE_BY_SIGNAL
+ STATES_WAITING_FOR_TIME | STATES_INTERRUPTIBLE_BY_SIGNAL
_Thread_queue_Context_set_enqueue_callout(
&queue_context,
diff --git a/cpukit/rtems/src/taskwakeafter.c b/cpukit/rtems/src/taskwakeafter.c
index 568b937..faf4a83 100644
--- a/cpukit/rtems/src/taskwakeafter.c
+++ b/cpukit/rtems/src/taskwakeafter.c
@@ -39,7 +39,7 @@ rtems_status_code rtems_task_wake_after(
if ( ticks == 0 ) {
_Thread_Yield( executing );
} else {
- _Thread_Set_state( executing, STATES_DELAYING );
+ _Thread_Set_state( executing, STATES_WAITING_FOR_TIME );
_Thread_Wait_flags_set( executing, THREAD_WAIT_STATE_BLOCKED );
_Thread_Timer_insert_relative(
executing,
diff --git a/cpukit/score/include/rtems/score/statesimpl.h b/cpukit/score/include/rtems/score/statesimpl.h
index 9751de0..f90a89e 100644
--- a/cpukit/score/include/rtems/score/statesimpl.h
+++ b/cpukit/score/include/rtems/score/statesimpl.h
@@ -74,8 +74,11 @@ extern "C" {
/** This macro corresponds to a task waiting for BSD wakeup. */
#define STATES_WAITING_FOR_BSD_WAKEUP 0x00000100
-/** This macro corresponds to a task which is waiting for a timeout. */
-#define STATES_DELAYING 0x00000200
+ * @brief This macro corresponds to a task which is waiting for a relative or
+ * absolute timeout.
+#define STATES_WAITING_FOR_TIME 0x00000200
/** This macro corresponds to a task waiting for a period. */
#define STATES_WAITING_FOR_PERIOD 0x00000400
@@ -104,9 +107,6 @@ extern "C" {
/** This macro corresponds to a task those life is changing. */
#define STATES_LIFE_IS_CHANGING 0x00040000
-/** This macro corresponds to a task waiting until a specific TOD. */
-#define STATES_WAITING_FOR_TIME 0x00080000
/** This macro corresponds to a task being held by the debugger. */
#define STATES_DEBUGGER 0x08000000
@@ -139,8 +139,7 @@ extern "C" {
STATES_WAITING_FOR_RWLOCK )
/** This macro corresponds to a task waiting which is blocked. */
-#define STATES_BLOCKED ( STATES_DELAYING | \
- STATES_LOCALLY_BLOCKED | \
+#define STATES_BLOCKED ( STATES_LOCALLY_BLOCKED | \
STATES_WAITING_FOR_TIME | \
STATES_WAITING_FOR_PERIOD | \
STATES_WAITING_FOR_EVENT | \
@@ -246,21 +245,6 @@ RTEMS_INLINE_ROUTINE bool _States_Is_suspended (
- * This function returns true if the DELAYING state is set in
- * the_states, and false otherwise.
- * @param[in] the_states is the task state set to test
- * @return This method returns true if the desired state condition is set.
-RTEMS_INLINE_ROUTINE bool _States_Is_delaying (
- States_Control the_states
- return (the_states & STATES_DELAYING);
* This function returns true if the WAITING_FOR_SEGMENT state is set in
@@ -358,21 +342,6 @@ RTEMS_INLINE_ROUTINE bool _States_Is_waiting_for_semaphore (
-RTEMS_INLINE_ROUTINE bool _States_Is_waiting_for_time (
- return (the_states & STATES_WAITING_FOR_TIME);
- * This function returns true if the WAITING_FOR_TIME state is set in
RTEMS_INLINE_ROUTINE bool _States_Is_waiting_for_rpc_reply (
1.8.4.5
