[PATCH 3/5] Add rtems_assoc_32_to_string()
Wed Jan 11 10:22:47 UTC 2017
 cpukit/libcsupport/Makefile.am           |  1 +
 cpukit/libcsupport/include/rtems/assoc.h | 33 ++++++++++++++++-
 cpukit/libcsupport/src/assoc32tostring.c | 61 ++++++++++++++++++++++++++++++++
 testsuites/sptests/spassoc01/init.c      | 61 ++++++++++++++++++++++++++++++++
 4 files changed, 155 insertions(+), 1 deletion(-)
 create mode 100644 cpukit/libcsupport/src/assoc32tostring.c
diff --git a/cpukit/libcsupport/Makefile.am b/cpukit/libcsupport/Makefile.am
index 550b674..e217a5f 100644
--- a/cpukit/libcsupport/Makefile.am
+++ b/cpukit/libcsupport/Makefile.am
@@ -37,6 +37,7 @@ ASSOCIATION_C_FILES = src/assoclocalbyname.c \
     src/assocnamebyremote.c src/assocptrbylocal.c src/assocptrbyname.c \
     src/assocptrbyremote.c src/assocremotebylocalbitfield.c \
     src/assocremotebylocal.c src/assocremotebyname.c
+ASSOCIATION_C_FILES += src/assoc32tostring.c
 BASE_FS_C_FILES = src/base_fs.c src/mount.c src/unmount.c src/libio.c \
     src/mount-mgr.c src/mount-mktgt.c src/libio_init.c \
diff --git a/cpukit/libcsupport/include/rtems/assoc.h b/cpukit/libcsupport/include/rtems/assoc.h
index c493315..9f65ba6 100644
--- a/cpukit/libcsupport/include/rtems/assoc.h
+++ b/cpukit/libcsupport/include/rtems/assoc.h
@@ -16,7 +16,8 @@
-#include <stdint.h> /* uint32_t */
+#include <stddef.h>
+#include <stdint.h>
 #ifdef __cplusplus
 extern "C" {
@@ -150,6 +151,36 @@ const char *rtems_assoc_name_bad(
 #endif
+typedef struct {
+  uint32_t    bits;
+  const char *name;
+} rtems_assoc_32_pair;
+ * @brief Converts the specified value into a text representation.
+ * @param[in] value The value to convert.
+ * @param[in] buffer The buffer for the text representation.
+ * @param[in] buffer_size The buffer size in characters.
+ * @param[in] pairs Names for particular bits.
+ * @param[in] pair_count Count of pairs.
+ * @param[in] separator Separator between individual names.
+ * @param[in] fallback Fallback value in case no bits contained in the pairs
+ *   are set in the value.
+ * @retval The length of the text representation.  May be greater than the
+ * buffer size if truncation occurred.
+size_t rtems_assoc_32_to_string(
+  uint32_t                   value,
+  char                      *buffer,
+  size_t                     buffer_size,
+  const rtems_assoc_32_pair *pairs,
+  size_t                     pair_count,
+  const char                *separator,
+  const char                *fallback
 #ifdef __cplusplus
 #endif
diff --git a/cpukit/libcsupport/src/assoc32tostring.c b/cpukit/libcsupport/src/assoc32tostring.c
new file mode 100644
index 0000000..31b0885
--- /dev/null
+++ b/cpukit/libcsupport/src/assoc32tostring.c
@@ -0,0 +1,61 @@
+ * Copyright (c) 2016 embedded brains GmbH.
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/assoc.h>
+#include <stdbool.h>
+#include <string.h>
+static size_t space( size_t buffer_size, size_t len )
+  if ( len < buffer_size ) {
+    return buffer_size - len;
+  } else {
+    return 0;
+  uint32_t                   value,
+  char                      *buffer,
+  size_t len;
+  size_t i;
+  len = 0;
+  for ( i = 0; i < pair_count ; ++i ) {
+    const rtems_assoc_32_pair *p;
+    p = &pairs[ i ];
+    if ( ( value & p->bits ) != 0 ) {
+      if ( len > 0 ) {
+        len += strlcpy( &buffer[ len ], separator, space( buffer_size, len ) );
+      len += strlcpy( &buffer[ len ], p->name, space( buffer_size, len ) );
+  if ( len == 0 ) {
+    len += strlcpy( buffer, fallback, buffer_size );
+  return len;
diff --git a/testsuites/sptests/spassoc01/init.c b/testsuites/sptests/spassoc01/init.c
index 2cd14f9..ba3873a 100644
--- a/testsuites/sptests/spassoc01/init.c
+++ b/testsuites/sptests/spassoc01/init.c
@@ -61,6 +61,65 @@ static void reset_name( void )
   memset( name, 0, 40 );
+static void test_assoc_32_to_string( void )
+  static const rtems_assoc_32_pair pairs[] = {
+    { 1, "A" },
+    { 2, "LOOOOONG" },
+    { 4, "C" }
+  char buf[4];
+  size_t len;
+  len = rtems_assoc_32_to_string(
+    0,
+    buf,
+    sizeof( buf ),
+    pairs,
+    RTEMS_ARRAY_SIZE( pairs ),
+    "D"
+  rtems_test_assert( len == 1 );
+  rtems_test_assert( strcmp( buf, "D" ) == 0 );
+    1,
+    buf,
+    sizeof( buf ),
+    pairs,
+    "D"
+  rtems_test_assert( strcmp( buf, "A" ) == 0 );
+    5,
+    buf,
+    sizeof( buf ),
+    pairs,
+    "D"
+  rtems_test_assert( len == 3 );
+  rtems_test_assert( strcmp( buf, "A:C" ) == 0 );
+    7,
+    buf,
+    sizeof( buf ),
+    pairs,
+    "D"
+  rtems_test_assert( len == 12 );
+  rtems_test_assert( strcmp( buf, "A:L" ) == 0 );
 rtems_task Init(
   rtems_task_argument argument
@@ -217,6 +276,8 @@ rtems_task Init(
   free( name );
+  test_assoc_32_to_string();
   TEST_END();
   rtems_test_exit(0);
1.8.4.5
