[PATCH 5/5] posix: Add pthread_getname_np(), ...
Thu Jan 12 14:51:25 UTC 2017
Add pthread_getname_np() and pthread_setname_np().
Update #2858.
 cpukit/posix/Makefile.am                           |   2 +
 cpukit/posix/src/pthreadgetnamenp.c                |  44 +++++++++
 cpukit/posix/src/pthreadsetnamenp.c                |  38 ++++++++
 testsuites/psxtests/Makefile.am                    |   1 +
 testsuites/psxtests/configure.ac                   |   1 +
 testsuites/psxtests/psxthreadname01/Makefile.am    |  19 ++++
 testsuites/psxtests/psxthreadname01/init.c         | 101 +++++++++++++++++++++
 .../psxtests/psxthreadname01/psxthreadname01.doc   |  12 +++
 .../psxtests/psxthreadname01/psxthreadname01.scn   |   0
 9 files changed, 218 insertions(+)
 create mode 100644 cpukit/posix/src/pthreadgetnamenp.c
 create mode 100644 cpukit/posix/src/pthreadsetnamenp.c
 create mode 100644 testsuites/psxtests/psxthreadname01/Makefile.am
 create mode 100644 testsuites/psxtests/psxthreadname01/init.c
 create mode 100644 testsuites/psxtests/psxthreadname01/psxthreadname01.doc
 create mode 100644 testsuites/psxtests/psxthreadname01/psxthreadname01.scn
diff --git a/cpukit/posix/Makefile.am b/cpukit/posix/Makefile.am
index d9a3437..9cc1043 100644
--- a/cpukit/posix/Makefile.am
+++ b/cpukit/posix/Makefile.am
@@ -65,6 +65,8 @@ endif
 libposix_a_SOURCES += src/fork.c src/vfork.c
 libposix_a_SOURCES += src/wait.c src/waitpid.c
+libposix_a_SOURCES += src/pthreadgetnamenp.c
+libposix_a_SOURCES += src/pthreadsetnamenp.c
 if HAS_PTHREADS
 libposix_a_SOURCES +=  src/pthreadatfork.c
diff --git a/cpukit/posix/src/pthreadgetnamenp.c b/cpukit/posix/src/pthreadgetnamenp.c
new file mode 100644
index 0000000..e753823
--- /dev/null
+++ b/cpukit/posix/src/pthreadgetnamenp.c
@@ -0,0 +1,44 @@
+ * Copyright (c) 2017 embedded brains GmbH.
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#define _GNU_SOURCE
+#include <pthread.h>
+#include <errno.h>
+#include <string.h>
+#include <rtems/score/threadimpl.h>
+int pthread_getname_np( pthread_t thread, char *name, size_t len )
+  Thread_Control   *the_thread;
+  ISR_lock_Context  lock_context;
+  size_t            actual_len;
+  _Objects_Allocator_lock();
+  the_thread = _Thread_Get( thread, &lock_context );
+  if ( the_thread == NULL ) {
+    _Objects_Allocator_unlock();
+    strlcpy(name, "", len);
+    return ESRCH;
+  _ISR_lock_ISR_enable( &lock_context );
+  actual_len = _Thread_Get_name( the_thread, name, len );
+  if ( actual_len >= len ) {
+    return ERANGE;
+  return 0;
diff --git a/cpukit/posix/src/pthreadsetnamenp.c b/cpukit/posix/src/pthreadsetnamenp.c
index 0000000..cb0e47c
--- /dev/null
+++ b/cpukit/posix/src/pthreadsetnamenp.c
@@ -0,0 +1,38 @@
+#if HAVE_CONFIG_H
+#endif
+#include <errno.h>
+#include <rtems/posix/posixapi.h>
+int pthread_setname_np( pthread_t thread, const char *name )
+  Status_Control    status;
+    return ESRCH;
+  status = _Thread_Set_name( the_thread, name );
+  return _POSIX_Get_error( status );
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
index 40faa61..e0ce36f 100644
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -1,6 +1,7 @@
 ACLOCAL_AMFLAGS = -I ../aclocal
 _SUBDIRS = psxclock
+_SUBDIRS += psxthreadname01
 if HAS_POSIX
 _SUBDIRS += psxhdrs psx01 psx02 psx03 psx04 psx05 psx06 psx07 psx08 psx09 \
     psx10 psx11 psx12 psx13 psx14 psx15 psx16 \
diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
index 1ac2877..7401258 100644
--- a/testsuites/psxtests/configure.ac
+++ b/testsuites/psxtests/configure.ac
@@ -203,6 +203,7 @@ psxtime/Makefile
 psxtimer01/Makefile
 psxtimer02/Makefile
 psxtimes01/Makefile
+psxthreadname01/Makefile
 psxualarm/Makefile
 psxusleep/Makefile
diff --git a/testsuites/psxtests/psxthreadname01/Makefile.am b/testsuites/psxtests/psxthreadname01/Makefile.am
index 0000000..8726803
--- /dev/null
+++ b/testsuites/psxtests/psxthreadname01/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = psxthreadname01
+psxthreadname01_SOURCES = init.c
+dist_rtems_tests_DATA = psxthreadname01.scn psxthreadname01.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(psxthreadname01_OBJECTS)
+LINK_LIBS = $(psxthreadname01_LDLIBS)
+psxthreadname01$(EXEEXT): $(psxthreadname01_OBJECTS) $(psxthreadname01_DEPENDENCIES)
+	@rm -f psxthreadname01$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/psxtests/psxthreadname01/init.c b/testsuites/psxtests/psxthreadname01/init.c
index 0000000..16fdec6
--- /dev/null
+++ b/testsuites/psxtests/psxthreadname01/init.c
@@ -0,0 +1,101 @@
+ * Copyright (c) 2017 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+#ifdef HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include <errno.h>
+#include "tmacros.h"
+const char rtems_test_name[] = "PSXTHREADNAME 1";
+#define MAX_NAME_SIZE 13
+static void test(void)
+  static const char no_name[] = "NO";
+  static const char big_name[] = "abcdefghijklmnopqrstuvwxyz";
+  static const char new_name[] = "new";
+  char name[sizeof(big_name)];
+  int eno;
+  memcpy(name, no_name, sizeof(name));
+  eno = pthread_getname_np(0xffffffff, name, MAX_NAME_SIZE);
+  rtems_test_assert(eno == ESRCH);
+  rtems_test_assert(strcmp(name, "") == 0);
+  eno = pthread_setname_np(0xffffffff, name);
+  eno = pthread_getname_np(pthread_self(), name, 0);
+  rtems_test_assert(eno == ERANGE);
+  rtems_test_assert(strcmp(name, "NO") == 0);
+  eno = pthread_getname_np(pthread_self(), name, sizeof(name));
+  rtems_test_assert(eno == 0);
+  rtems_test_assert(strcmp(name, "UI1 ") == 0);
+  eno = pthread_setname_np(pthread_self(), big_name);
+  rtems_test_assert(strcmp(name, "abcdefghijkl") == 0);
+  eno = pthread_setname_np(pthread_self(), new_name);
+  rtems_test_assert(strcmp(name, "new") == 0);
+  eno = pthread_getname_np(pthread_self(), name, 3);
+  rtems_test_assert(strcmp(name, "ne") == 0);
+static void Init(rtems_task_argument arg)
+  TEST_BEGIN();
+  test();
+  TEST_END();
+  rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_MAXIMUM_THREAD_NAME_SIZE MAX_NAME_SIZE
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/psxtests/psxthreadname01/psxthreadname01.doc b/testsuites/psxtests/psxthreadname01/psxthreadname01.doc
index 0000000..9094bc0
--- /dev/null
+++ b/testsuites/psxtests/psxthreadname01/psxthreadname01.doc
@@ -0,0 +1,12 @@
+This file describes the directives and concepts tested by this test set.
+test set name: psxthreadname01
+directives:
+  - pthread_setname_np()
+  - pthread_getname_np()
+concepts:
+  - Ensure that set/get of thread names works as expected.
diff --git a/testsuites/psxtests/psxthreadname01/psxthreadname01.scn b/testsuites/psxtests/psxthreadname01/psxthreadname01.scn
index 0000000..e69de29
1.8.4.5
