Thread name support
Mon Jan 16 11:56:13 UTC 2017
On 16/1/17 7:19 pm, Sebastian Huber wrote:
> On 16/01/17 09:08, Chris Johns wrote:
>> On 16/1/17 5:52 pm, Sebastian Huber wrote:
>>> On 13/01/17 18:59, Gedare Bloom wrote:
>>>> On Fri, Jan 13, 2017 at 3:25 AM, Sebastian Huber
>>>> <sebastian.huber at embedded-brains.de> wrote:
>>>>> Hello,
>>>>> I added optional user-defined thread names.
>>>>> https://devel.rtems.org/ticket/2858
>>>>> The GNU pthread extensions pthread_getname_np() and
>>>>> pthread_setname_np() are
>>>>> now available in RTEMS and work for all threads (internal, Classic,
>>>>> POSIX,
>>>>> FreeBSD).
>>>>> http://man7.org/linux/man-pages/man3/pthread_setname_np.3.html
>>>>> The maximum thread name size is a configuration option
>>>>> (CONFIGURE_MAXIMUM_THREAD_NAME_SIZE).
>>>>> Where should this new feature be documented in the C user manual?
>>>> I guess at posix-users/thread.rst? I don't know if we have a list of
>>>> function calls that work across the APIs, but I know quite a few do.
>>> It think the POSIX API manual should be replaced by a simple list of
>>> POSIX functions implemented by RTEMS. Each with a link to The Open Group
>>> documentation and optionally RTEMS-specific things.
>> What happens with PDF or epub format? Currently the PDF documentation is
>> fully contained. Doing this means the users has to have internet access
>> to use it.
> Who looks at the RTEMS documentation to figure out what a POSIX function
> does? I never used the POSIX API manual.
Many people do. It is important when something is not working as
expected. Not all users are keen to jump into the RTEMS source code to
figure something out, or have an inside to outside view.
>>> The thread names are available for every API. It should be documented
>>> somewhere in the user manual.
>> The C user manual? The RTEMS User Manual does not contain any API
>> related doco.
> Hm, the C user manual and the RTEMS User Manual are different things?
Yes. The RTEMS User manual is about using RTEMS, the ecosystem, setting
up a development environment, the type of host hardware you need,
debugging, applications, support, tools and more. The C User manual is
the detail on runtime configuration, the Classic API and other C base
interfaces users need to call to run RTEMS.
