[PATCH] configure: Add RTEMS_TOOL_CHAIN_ERROR
Tue Jan 17 10:02:09 UTC 2017
On 13/01/17 15:54, Joel Sherrill wrote:
> On Fri, Jan 13, 2017 at 4:47 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     On 13/01/17 09:48, Sebastian Huber wrote:
>         On 12/01/17 22:44, Joel Sherrill wrote:
>             I repeat that I would like to purge old tests that result
>             in conditionals in
>             source code we no longer need. So any HAVE_XXX that are a side
>             effect of transitioning newlib additions should be removed.
>         I removed three tests today which I added in the last two
>         years or so.
>     I removed a couple of more obsolete configure stuff. I am done for
>     now.
> Thanks. It is a continuous battle of creep and push back.
> Without looking, I am sure you are right that
> __RTEMS_DO_NOT_INLINE_THREAD_ENABLE_DISPATCH__
> is no longer used but it did serve a purpose that may have been lost
> in all the
> rework.
> When doing coverage testing, inlining a method with one of more
> conditionals
> increases the cyclomatic complexity of the calling method and number
> of test
> cases required to do full coverage of all branch paths. That flag
> eliminated
> at least 250 paths to test in the generated code.
> With the rework, did anything get inlined lots of times that includes a
> conditional test? If so, then the calling method has hidden cyclomatic
> complexity and requires increased test cases for full coverage.
> I am pretty sure this is written down as advice in the coverage area
> but I have no idea how to turn it into good solid coding style/rules.
> The best I can formulate is:
> Inlining a method requires that it be fully tested in the context of each
> place it is called. Inlining complex methods with conditionals is
> undesirable
> from a coverage testing viewpoint. Try to inline only simple methods.
Yes, this is something to think about. The thread dispatch
disable/enable is used in fewer places now, maybe it makes sense to make
it a non-inline function to simplify things or replace it with
_Thread_Dispatch_direct() if possible.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
