Unable to build rtems-docs Was: Re: [PATCH] Update RMS documentation for overrun handling
Gedare Bloom
gedare at rtems.org
Tue Jan 17 15:30:25 UTC 2017
On Fri, Jan 13, 2017 at 5:51 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 14/1/17 8:21 am, Gedare Bloom wrote:
>> I was unable to compile rtems-docs (cleanly), so I have not committed
>> this patch yet.
> What is the problem?
It appears to be a problem in my distribution's texlive / latex
support I guess. I'm on an aging Ubuntu here. :)
$ uname -a
Linux gedare-pc 3.13.0-24-generic #47-Ubuntu SMP Fri May 2 23:30:00
UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
$ sphinx-build --version
Sphinx (sphinx-build) 1.5.1
$ python --version
Python 2.7.6
Relevant-seeming shell output below:
[ 24/101] Processing
/home/gedare/work/rtems/rtems-docs/build/c-user/html/index.html:
c-user/barrier_manager.rst c-user/board_support_packages.rst
c-user/chains.rst c-user/clock_manager.rst
c-user/configuring_a_system.rst c-user/constant_bandwidth_server.rst
c-user/cpu_usage_statistics.rst c-user/directive_status_codes.rst
c-user/dual_ports_memory_manager.rst c-user/event_manager.rst
c-user/example_application.rst c-user/fatal_error.rst
c-user/glossary.rst c-user/index.rst c-user/initialization.rst
c-user/interrupt_manager.rst c-user/io_manager.rst
c-user/key_concepts.rst c-user/linker_sets.rst
c-user/message_manager.rst c-user/multiprocessing.rst
c-user/object_services.rst c-user/overview.rst
c-user/partition_manager.rst c-user/pci_library.rst c-user/preface.rst
c-user/rate_monotonic_manager.rst c-user/red_black_trees.rst
c-user/region_manager.rst c-user/rtems_data_types.rst
c-user/scheduling_concepts.rst c-user/semaphore_manager.rst
c-user/signal_manager.rst c-user/stack_bounds_checker.rst
c-user/symmetric_multiprocessing_services.rst c-user/task_manager.rst
c-user/timer_manager.rst c-user/timespec_helpers.rst
c-user/user_extensions.rst -> build/c-user/html/index.html
16:19:18 runner ' /usr/local/bin/sphinx-build -Q -b html -c . -d
/home/gedare/work/rtems/rtems-docs/build/c-user/doctrees/html .
/home/gedare/work/rtems/rtems-docs/build/c-user/html '
/usr/local/lib/python2.7/dist-packages/sphinx/util/requests.py:33:
UserWarning: Some links may return broken results due to being unable
to check the Server Name Indication (SNI) in the returned SSL cert
against the hostname in the url requested. Recommended to install
"requests[security]" as a dependency or upgrade to a python version
with SNI support (Python 3 and Python 2.7.9+).
'Some links may return broken results due to being unable to '
Exception occurred:
File "/usr/local/lib/python2.7/dist-packages/sphinx/writers/latex.py",
line 366, in __init__
self.sectionnames.index(builder.config.latex_toplevel_sectioning)
ValueError: 'parts' is not in list
The full traceback has been saved in /tmp/sphinx-err-sQHg09.log, if
you want to report the issue to the developers.
Please also report this if it was a user error, so that a better error
message can be provided next time.
A bug report can be filed in the tracker at
<https://github.com/sphinx-doc/sphinx/issues>. Thanks!
Above warning and exception repeat 3 more times.
Traceback from /tmp/sphinx-err-sQHg09.log
Traceback (most recent call last):
File "/usr/local/lib/python2.7/dist-packages/sphinx/cmdline.py",
line 296, in main
app.build(opts.force_all, filenames)
File "/usr/local/lib/python2.7/dist-packages/sphinx/application.py",
line 333, in build
self.builder.build_update()
File "/usr/local/lib/python2.7/dist-packages/sphinx/builders/__init__.py",
line 246, in build_update
self.build(['__all__'], to_build)
line 322, in build
self.write(docnames, list(updated_docnames), method)
File "/usr/local/lib/python2.7/dist-packages/sphinx/builders/latex.py",
line 130, in write
docwriter.write(doctree, destination)
File "/usr/local/lib/python2.7/dist-packages/docutils/writers/__init__.py",
line 80, in write
self.translate()
line 159, in translate
visitor = self.translator_class(self.document, self.builder)
