[PATCH] rtems-test-check: Make exclude work again.
Stavros Passas
stavros.passas at movidius.com
Tue Jan 17 15:34:15 UTC 2017
Hi Joel,
Yesterday, with the creation of the ticket about the issue, (
https://devel.rtems.org/ticket/2867)
I also uploaded the patch that was fixing it -- after Chris's suggestion
over email.
The patch was created with my full credentials, so you can take them from
here:
https://devel.rtems.org/attachment/ticket/2867/fix-2867.patch
Best Regards,
Stavros
On 17 January 2017 at 14:08, Joel Sherrill <joel at rtems.org> wrote:
> On Mon, Jan 16, 2017 at 5:12 PM, Chris Johns <chrisj at rtems.org> wrote:
>> This change looks wrong. Moving test loop out of the if testdata block
>> means variables in the test loop are not defined. I consider it a script
>> bug to assume it is ok to reference a variable that is not declared
>> because it is ambiguous if this intended behavior or a bug.
>> Starvos sent me this change a few days ago and it looks good. I am
>> hoping he will make a patch we can merge so he can have the credit ..
>> diff --git a/tools/build/rtems-test-check b/tools/build/rtems-test-check
>> index e02f8e9..108b788 100755
>> --- a/tools/build/rtems-test-check
>> +++ b/tools/build/rtems-test-check
>> @@ -32,7 +32,11 @@ done
>> case ${mode} in
>> exclude)
>> - output=${tests}
>> + if test -f $testdata; then
>> + output=""
>> + else
>> + output="${tests}"
>> + fi
>> flags)
>> if [ $test_count != 1 ]; then
>> Are you in a position to test this change?
> I am starting a test sweep of this now. I will need Starvos's proper
> name and email to commit it though.
> --joel
>> Chris
>> On 17/1/17 6:24 am, Joel Sherrill wrote:
>> > closes #2867.
>> > tools/build/rtems-test-check | 90 ++++++++++++++++++++++--------
>> > 1 file changed, 45 insertions(+), 45 deletions(-)
>> > index e02f8e9..e8acde0 100755
>> > @@ -32,7 +32,6 @@ done
>> > case ${mode} in
>> > exclude)
>> > - output=${tests}
>> > flags)
>> > @@ -99,52 +98,53 @@ if test -f $testdata; then
>> > testdata=$ntd
>> > done
>> > - for t in ${tests};
>> > - do
>> > - case ${mode} in
>> > - exclude)
>> > - allow="yes"
>> > - for dt in ${excluded_tests};
>> > - do
>> > - if test ${t} = ${dt}; then
>> > - allow="no"
>> > - fi
>> > - done
>> > - if test ${allow} = yes; then
>> > - output="${output} ${t}"
>> > - fi
>> > - flags)
>> > - allow="no"
>> > - for et in ${expected_fails};
>> > - do
>> > - if test ${t} = ${et}; then
>> > - allow="yes"
>> > - fi
>> > - done
>> > - output="-DTEST_STATE_EXPECTED_FAIL=1"
>> > - fi
>> > - allow="no"
>> > - for it in ${indeterminates};
>> > - do
>> > - if test ${t} = ${it}; then
>> > - allow="yes"
>> > - fi
>> > - done
>> > - output="${output} -DTEST_STATE_INDETERMINATE=1"
>> > - fi
>> > - echo "error: invalid mode" 1>&2
>> > - echo "INVALID-TEST-DATA"
>> > - exit 1
>> > - esac
>> > - done
>> > fi
>> > +for t in ${tests};
>> > +do
>> > + case ${mode} in
>> > + exclude)
>> > + allow="yes"
>> > + for dt in ${excluded_tests};
>> > + do
>> > + if test ${t} = ${dt}; then
>> > + allow="no"
>> > + fi
>> > + done
>> > + if test ${allow} = yes; then
>> > + output="${output} ${t}"
>> > + fi
>> > + flags)
>> > + allow="no"
>> > + for et in ${expected_fails};
>> > + do
>> > + if test ${t} = ${et}; then
>> > + allow="yes"
>> > + fi
>> > + done
>> > + output="-DTEST_STATE_EXPECTED_FAIL=1"
>> > + fi
>> > + allow="no"
>> > + for it in ${indeterminates};
>> > + do
>> > + if test ${t} = ${it}; then
>> > + allow="yes"
>> > + fi
>> > + done
>> > + output="${output} -DTEST_STATE_INDETERMINATE=1"
>> > + fi
>> > + echo "error: invalid mode" 1>&2
>> > + echo "INVALID-TEST-DATA"
>> > + exit 1
>> > + esac
>> > +done
>> > echo ${output}
>> > exit 0
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170117/e4e35f63/attachment.html>
