[PATCH] rtems-test-check: Make exclude work again.
Joel Sherrill
joel at rtems.org
Tue Jan 17 18:51:54 UTC 2017
On Tue, Jan 17, 2017 at 9:34 AM, Stavros Passas <stavros.passas at movidius.com
> wrote:
> Hi Joel,
> Yesterday, with the creation of the ticket about the issue, (
> https://devel.rtems.org/ticket/2867)
> I also uploaded the patch that was fixing it -- after Chris's suggestion
> over email.
> The patch was created with my full credentials, so you can take them from
> here:
> https://devel.rtems.org/attachment/ticket/2867/fix-2867.patch
Thanks. I should have seen that but was working from home yesterday.
I am testing with that patch now along with a number of additions to .tcfg
files.
I will push when my build finishes.
--joel
> Best Regards,
> Stavros
> On 17 January 2017 at 14:08, Joel Sherrill <joel at rtems.org> wrote:
>> On Mon, Jan 16, 2017 at 5:12 PM, Chris Johns <chrisj at rtems.org> wrote:
>>> This change looks wrong. Moving test loop out of the if testdata block
>>> means variables in the test loop are not defined. I consider it a script
>>> bug to assume it is ok to reference a variable that is not declared
>>> because it is ambiguous if this intended behavior or a bug.
>>> Starvos sent me this change a few days ago and it looks good. I am
>>> hoping he will make a patch we can merge so he can have the credit ..
>>> diff --git a/tools/build/rtems-test-check b/tools/build/rtems-test-check
>>> index e02f8e9..108b788 100755
>>> --- a/tools/build/rtems-test-check
>>> +++ b/tools/build/rtems-test-check
>>> @@ -32,7 +32,11 @@ done
>>> case ${mode} in
>>> exclude)
>>> - output=${tests}
>>> + if test -f $testdata; then
>>> + output=""
>>> + else
>>> + output="${tests}"
>>> + fi
>>> flags)
>>> if [ $test_count != 1 ]; then
>>> Are you in a position to test this change?
>> I am starting a test sweep of this now. I will need Starvos's proper
>> name and email to commit it though.
>> --joel
>>> Chris
>>> On 17/1/17 6:24 am, Joel Sherrill wrote:
>>> > closes #2867.
>>> > tools/build/rtems-test-check | 90 ++++++++++++++++++++++--------
>>> > 1 file changed, 45 insertions(+), 45 deletions(-)
>>> > index e02f8e9..e8acde0 100755
>>> > @@ -32,7 +32,6 @@ done
>>> > case ${mode} in
>>> > exclude)
>>> > - output=${tests}
>>> > flags)
>>> > @@ -99,52 +98,53 @@ if test -f $testdata; then
>>> > testdata=$ntd
>>> > done
>>> > - for t in ${tests};
>>> > - do
>>> > - case ${mode} in
>>> > - exclude)
>>> > - allow="yes"
>>> > - for dt in ${excluded_tests};
>>> > - do
>>> > - if test ${t} = ${dt}; then
>>> > - allow="no"
>>> > - fi
>>> > - done
>>> > - if test ${allow} = yes; then
>>> > - output="${output} ${t}"
>>> > - fi
>>> > - flags)
>>> > - allow="no"
>>> > - for et in ${expected_fails};
>>> > - do
>>> > - if test ${t} = ${et}; then
>>> > - allow="yes"
>>> > - fi
>>> > - done
>>> > - output="-DTEST_STATE_EXPECTED_FAIL=1"
>>> > - fi
>>> > - allow="no"
>>> > - for it in ${indeterminates};
>>> > - do
>>> > - if test ${t} = ${it}; then
>>> > - allow="yes"
>>> > - fi
>>> > - done
>>> > - output="${output} -DTEST_STATE_INDETERMINATE=1"
>>> > - fi
>>> > - echo "error: invalid mode" 1>&2
>>> > - echo "INVALID-TEST-DATA"
>>> > - exit 1
>>> > - esac
>>> > - done
>>> > fi
>>> > +for t in ${tests};
>>> > +do
>>> > + case ${mode} in
>>> > + exclude)
>>> > + allow="yes"
>>> > + for dt in ${excluded_tests};
>>> > + do
>>> > + if test ${t} = ${dt}; then
>>> > + allow="no"
>>> > + fi
>>> > + done
>>> > + if test ${allow} = yes; then
>>> > + output="${output} ${t}"
>>> > + fi
>>> > + flags)
>>> > + allow="no"
>>> > + for et in ${expected_fails};
>>> > + do
>>> > + if test ${t} = ${et}; then
>>> > + allow="yes"
>>> > + fi
>>> > + done
>>> > + output="-DTEST_STATE_EXPECTED_FAIL=1"
>>> > + fi
>>> > + allow="no"
>>> > + for it in ${indeterminates};
>>> > + do
>>> > + if test ${t} = ${it}; then
>>> > + allow="yes"
>>> > + fi
>>> > + done
>>> > + output="${output} -DTEST_STATE_INDETERMINATE=1"
>>> > + fi
>>> > + echo "error: invalid mode" 1>&2
>>> > + echo "INVALID-TEST-DATA"
>>> > + exit 1
>>> > + esac
>>> > +done
>>> > echo ${output}
>>> > exit 0
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170117/b4f5690b/attachment.html>
