[rtems-docs commit] c-user: Add Ada support chapter
Sebastian Huber
Thu Jan 19 06:12:06 UTC 2017
On 18/01/17 01:35, Joel Sherrill wrote:
> +Exercise extreme caution when considering writing code in Ada which
> +will execute in the context of an interrupt handler. Hardware interrupts are
> +processed outside the context of any thread in RTEMS and this can lead
> +to violating assumptions in the GNAT run-time. Specifically a priority
> +ceiling mutex should never be used from an ISR and it is difficult to
> +predict when the Ada compiler or run-time will use a mutex.
Maybe we should mention the interrupt server.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
