Unable to build rtems-docs Was: Re: [PATCH] Update RMS documentation for overrun handling
Thu Jan 19 15:57:59 UTC 2017
On Tue, Jan 17, 2017 at 10:44 AM, Stavros Passas
<stavros.passas at movidius.com> wrote:
> On 17 January 2017 at 15:39, Joel Sherrill <joel at rtems.org> wrote:
>> On Tue, Jan 17, 2017 at 9:30 AM, Gedare Bloom <gedare at rtems.org> wrote:
>>> On Fri, Jan 13, 2017 at 5:51 PM, Chris Johns <chrisj at rtems.org> wrote:
>>> > On 14/1/17 8:21 am, Gedare Bloom wrote:
>>> >> I was unable to compile rtems-docs (cleanly), so I have not committed
>>> >> this patch yet.
>>> > What is the problem?
>>> It appears to be a problem in my distribution's texlive / latex
>>> support I guess. I'm on an aging Ubuntu here. :)
>> I don't recall my exact failure on CentOS and Fedora but it turned out
>> that
>> they didn't package the complete TexLive contents. I ended up removing
>> what came with the distribution and using the TexLive master distribution.
>> The README.txt file has details.
>> https://git.rtems.org/rtems-docs/tree/README.txt
>> I can now build the docs even on CentOS 6 which is as old a distribution
>> as anyone should be made to use. :)
>>> $ uname -a
>>> Linux gedare-pc 3.13.0-24-generic #47-Ubuntu SMP Fri May 2 23:30:00
>>> UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
>>> $ sphinx-build --version
>>> Sphinx (sphinx-build) 1.5.1
>>> $ python --version
>>> Python 2.7.6
>>> Relevant-seeming shell output below:
>>> [ 24/101] Processing
>>> /home/gedare/work/rtems/rtems-docs/build/c-user/html/index.html:
>>> c-user/barrier_manager.rst c-user/board_support_packages.rst
>>> c-user/chains.rst c-user/clock_manager.rst
>>> c-user/configuring_a_system.rst c-user/constant_bandwidth_server.rst
>>> c-user/cpu_usage_statistics.rst c-user/directive_status_codes.rst
>>> c-user/dual_ports_memory_manager.rst c-user/event_manager.rst
>>> c-user/example_application.rst c-user/fatal_error.rst
>>> c-user/glossary.rst c-user/index.rst c-user/initialization.rst
>>> c-user/interrupt_manager.rst c-user/io_manager.rst
>>> c-user/key_concepts.rst c-user/linker_sets.rst
>>> c-user/message_manager.rst c-user/multiprocessing.rst
>>> c-user/object_services.rst c-user/overview.rst
>>> c-user/partition_manager.rst c-user/pci_library.rst c-user/preface.rst
>>> c-user/rate_monotonic_manager.rst c-user/red_black_trees.rst
>>> c-user/region_manager.rst c-user/rtems_data_types.rst
>>> c-user/scheduling_concepts.rst c-user/semaphore_manager.rst
>>> c-user/signal_manager.rst c-user/stack_bounds_checker.rst
>>> c-user/symmetric_multiprocessing_services.rst c-user/task_manager.rst
>>> c-user/timer_manager.rst c-user/timespec_helpers.rst
>>> c-user/user_extensions.rst -> build/c-user/html/index.html
>>> 16:19:18 runner ' /usr/local/bin/sphinx-build -Q -b html -c . -d
>>> /home/gedare/work/rtems/rtems-docs/build/c-user/doctrees/html .
>>> /home/gedare/work/rtems/rtems-docs/build/c-user/html '
>>> /usr/local/lib/python2.7/dist-packages/sphinx/util/requests.py:33:
>>> UserWarning: Some links may return broken results due to being unable
>>> to check the Server Name Indication (SNI) in the returned SSL cert
>>> against the hostname in the url requested. Recommended to install
>>> "requests[security]" as a dependency or upgrade to a python version
>>> with SNI support (Python 3 and Python 2.7.9+).
>>>   'Some links may return broken results due to being unable to '
>>> Exception occurred:
>>>   File "/usr/local/lib/python2.7/dist-packages/sphinx/writers/latex.py",
>>> line 366, in __init__
>>>     self.sectionnames.index(builder.config.latex_toplevel_sectioning)
>>> ValueError: 'parts' is not in list
>>> The full traceback has been saved in /tmp/sphinx-err-sQHg09.log, if
>>> you want to report the issue to the developers.
>>> Please also report this if it was a user error, so that a better error
>>> message can be provided next time.
>>> A bug report can be filed in the tracker at
>>> <https://github.com/sphinx-doc/sphinx/issues>. Thanks!
>>> Above warning and exception repeat 3 more times.
> I've seen this issue, it was caused by latex_use_parts and was causing
> sphinx to crash.
> It has been fixed by
> https://github.com/sphinx-doc/sphinx/commit/12096b3b863f40d10fce94e03abc4b8d3f856eb1
> thus, I would either try to update sphinx, or if you feel brave enough you
> could manually patch sphinx, which should theoretically fix this issue too.
Thanks Stavros. I cherry-picked this change and it works. I guess
anyone that uses sphinx 1.5.1 will have this problem.
