[PATCH] bsps/sparc: Remove tlib clock driver
Sebastian Huber
Mon Jan 23 14:58:19 UTC 2017
This driver lacked several features and cannot support SMP
configurations. Use the standard clock driver instead.
c/src/lib/libbsp/sparc/leon3/Makefile.am | 5 +-
c/src/lib/libbsp/sparc/leon3/clock/ckinit.c | 10 -
c/src/lib/libbsp/sparc/shared/include/tlib.h | 8 -
c/src/lib/libbsp/sparc/shared/timer/tlib_ckinit.c | 290 ----------------------
4 files changed, 2 insertions(+), 311 deletions(-)
delete mode 100644 c/src/lib/libbsp/sparc/shared/timer/tlib_ckinit.c
diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
index f2f690e..42084c2 100644
--- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
@@ -68,13 +68,12 @@ libbsp_a_SOURCES += ../../sparc/shared/amba/ambapp_names.c
libbsp_a_SOURCES += ../../sparc/shared/amba/ambapp_show.c
libbsp_a_SOURCES += ../../sparc/shared/amba/ahbstat.c
-# Clock Driver and Timer Library
+# Timer Library
include_bsp_HEADERS += ../../sparc/shared/include/gptimer.h
include_bsp_HEADERS += ../../sparc/shared/include/tlib.h
libbsp_a_SOURCES += ../../sparc/shared/timer/gptimer.c
libbsp_a_SOURCES += ../../sparc/shared/timer/tlib.c
-libbsp_a_SOURCES += ../../sparc/shared/timer/tlib_ckinit.c
-# non-Driver Manager Clock Implementation
+# Clock Driver
libbsp_a_SOURCES += clock/ckinit.c
libbsp_a_SOURCES += ../../shared/clockdrv_shell.h
diff --git a/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c b/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
index f2372ec..ca0d0c7 100644
--- a/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
+++ b/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c
@@ -28,14 +28,6 @@
#include <rtems/score/profiling.h>
#include <rtems/timecounter.h>
-/* The LEON3 BSP Timer driver can rely on the Driver Manager if the
- * DrvMgr is initialized during startup. Otherwise the classic driver
- * must be used.
- * The DrvMgr Clock driver is located in the shared/timer directory
-#ifndef RTEMS_DRVMGR_STARTUP
/* LEON3 Timer system interrupt number */
static int clkirq;
@@ -281,5 +273,3 @@ static void leon3_clock_initialize(void)
#define Clock_driver_timecounter_tick() leon3_tc_do_tick()
#include "../../../shared/clockdrv_shell.h"
-#endif
diff --git a/c/src/lib/libbsp/sparc/shared/include/tlib.h b/c/src/lib/libbsp/sparc/shared/include/tlib.h
index 7e6c49a..118722b 100644
--- a/c/src/lib/libbsp/sparc/shared/include/tlib.h
+++ b/c/src/lib/libbsp/sparc/shared/include/tlib.h
@@ -54,14 +54,6 @@ struct tlib_dev {
struct tlib_drv *drv;
-#ifdef RTEMS_DRVMGR_STARTUP
-/* Clock Driver Timer register function. Only used when the TLIB-Clock
- * driver is used. A specific Timer is registered as the System Clock
- * timer.
-extern void Clock_timer_register(int timer_number);
-#endif
/* Register Timer. Called by Timer Drivers in order to register
* a Timer to the Timer Library. The registration order determines
* the Timer Number used in tlib_open() to identify a specific
diff --git a/c/src/lib/libbsp/sparc/shared/timer/tlib_ckinit.c b/c/src/lib/libbsp/sparc/shared/timer/tlib_ckinit.c
deleted file mode 100644
index 2848f4c..0000000
--- a/c/src/lib/libbsp/sparc/shared/timer/tlib_ckinit.c
+++ /dev/null
@@ -1,290 +0,0 @@
- * Clock Tick Device Driver using Timer Library implemented
- * by the GRLIB GPTIMER / LEON2 Timer drivers.
- * COPYRIGHT (c) 2010.
- * Cobham Gaisler AB.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#include <rtems.h>
-#include <rtems/timecounter.h>
-#include <rtems/score/percpu.h>
-#include <stdlib.h>
-#include <bsp.h>
-#include <bsp/tlib.h>
-/* Undefine this to save space in standard LEON configurations,
- * it will assume that Prescaler is running at 1MHz.
-#undef CLOCK_DRIVER_DONT_ASSUME_PRESCALER_1MHZ
-/* Set the below defines from bsp.h if function needed.
-#undef CLOCK_DRIVER_ISRS_PER_TICK
-#undef CLOCK_DRIVER_USE_FAST_IDLE
- * Number of Clock ticks since initialization
-volatile uint32_t Clock_driver_ticks;
- * Timer Number in Timer Library. Defaults to the first Timer in
- * the System.
-int Clock_timer = 0;
- * Timer Handle in Timer Library
-void *Clock_handle = NULL;
-#ifdef CLOCK_DRIVER_DONT_ASSUME_PRESCALER_1MHZ
-unsigned int Clock_basefreq;
-#endif
-void Clock_exit(void);
-void Clock_isr(void *arg_unused);
-static rtems_timecounter_simple tlib_tc;
-static uint32_t tlib_tc_get(rtems_timecounter_simple *tc)
- unsigned int clicks = 0;
- if (Clock_handle != NULL) {
- tlib_get_counter(Clock_handle, &clicks);
- return clicks;
-static bool tlib_tc_is_pending(rtems_timecounter_simple *tc)
- bool pending = false;
- pending = tlib_interrupt_pending(Clock_handle, 0) != 0;
- return pending;
-static uint32_t tlib_tc_get_timecount(struct timecounter *tc)
- return rtems_timecounter_simple_downcounter_get(
- tc,
- tlib_tc_get,
- tlib_tc_is_pending
-static void tlib_tc_at_tick(rtems_timecounter_simple *tc)
- /* Nothing to do? */
-static void tlib_tc_tick(void)
- rtems_timecounter_simple_downcounter_tick(
- &tlib_tc,
- tlib_tc_get,
- tlib_tc_at_tick
- * Clock_isr
- * This is the clock tick interrupt handler.
- * Input parameters:
- * vector - vector number
- * Output parameters: NONE
- * Return values: NONE
- * Support for shared interrupts. Ack IRQ at source, only handle
- * interrupts generated from the tick-timer.
- if ( tlib_interrupt_pending(Clock_handle, 1) == 0 )
- return;
- * Accurate count of ISRs
- Clock_driver_ticks += 1;
-#ifdef CLOCK_DRIVER_USE_FAST_IDLE
- do {
- tlib_tc_tick();
- } while ( _Thread_Heir == _Thread_Executing && _Thread_Executing->is_idle );
- return;
-#else
-#ifdef CLOCK_DRIVER_ISRS_PER_TICK
- * The driver is multiple ISRs per clock tick.
- if ( !Clock_driver_isrs ) {
- tlib_tc_tick();
- Clock_driver_isrs = CLOCK_DRIVER_ISRS_PER_TICK;
- Clock_driver_isrs--;
-#else
- * The driver is one ISR per clock tick.
- tlib_tc_tick();
-#endif
-#endif
- * Clock_exit
- * This routine allows the clock driver to exit by masking the interrupt and
- * disabling the clock's counter.
- * Input parameters: NONE
-void Clock_exit( void )
- /* Stop all activity of the Timer, no more ISRs.
- * We could be using tlib_close(), however tlib_stop() is quicker
- * and independent of IRQ unregister code.
- if ( Clock_handle ) {
- tlib_stop(Clock_handle);
- Clock_handle = NULL;
- * Clock_initialize
- * This routine initializes the clock driver and starts the Clock.
- * major - clock device major number
- * minor - clock device minor number
- * parg - pointer to optional device driver arguments
- * Return values:
- * rtems_device_driver status code
-rtems_device_driver Clock_initialize(
- rtems_device_major_number major,
- rtems_device_minor_number minor,
- void *pargp
- uint64_t frequency;
- unsigned int tick_hz;
- * Take Timer that should be used as system timer.
- Clock_handle = tlib_open(Clock_timer);
- if ( Clock_handle == NULL ) {
- /* System Clock Timer not found */
- return RTEMS_NOT_DEFINED;
- * Install Clock ISR before starting timer
- tlib_irq_register(Clock_handle, Clock_isr, NULL);
- /* Set Timer Frequency to tick at Configured value. The Timer
- * Frequency is set in multiples of the timer base frequency.
- * In standard LEON3 designs the base frequency is is 1MHz, to
- * save instructions undefine CLOCK_DRIVER_DONT_ASSUME_PRESCALER_1MHZ
- * to avoid 64-bit calculation.
- uint64_t tmp;
- tlib_get_freq(Clock_handle, &Clock_basefreq, NULL);
- frequency = Clock_basefreq
- tmp = frequency * (uint64_t)rtems_configuration_get_microseconds_per_tick();
- tick_hz = tmp / 1000000;
-#else
- frequency = 1000000;
- tick_hz = rtems_configuration_get_microseconds_per_tick();
-#endif
- tlib_set_freq(Clock_handle, tick_hz);
- rtems_timecounter_simple_install(
- &tlib_tc,
- frequency,
- tick_hz,
- tlib_tc_get_timecount
- * IRQ and Frequency is setup, now we start the Timer. IRQ is still
- * disabled globally during startup, so IRQ will hold for a while.
- tlib_start(Clock_handle, 0);
- * Register function called at system shutdown
- atexit( Clock_exit );
- * If we are counting ISRs per tick, then initialize the counter.
-#endif
- return RTEMS_SUCCESSFUL;
-/*** Timer Driver Interface ***/
-/* Set system clock timer instance */
-void Clock_timer_register(int timer_number)
- Clock_timer = timer_number;
-#endif
1.8.4.5
