Re: Help with RTEMS C User’s Guide
Tanu Hari Dixit
tokencolour at gmail.com
Tue Jan 24 11:24:57 UTC 2017
Hey,
Thank you for replying. Yes, the sample applications run (hello world and
ticker as given on https://devel.rtems.org/wiki/TBR/UserManual/Quick_Start).
Regards,
Tanu Hari Dixit.
On Tue, Jan 24, 2017 at 4:06 PM, Laurent Navet <laurent.navet at gmail.com>
wrote:
> Hi
> > I have made a file with the first example of printing object names (
> > https://docs.rtems.org/doc-current/share/rtems/html/c_
> > user/Key-Concepts-Object-Names.html#Key-Concepts-Object-Names) and i use
> > the following command to use sparc-rtems4.12-gcc to compile this program
> > sparc-rtems4.12-gcc --pipe -B/home/thd/development/rtems/
> > src/builds/erc32_1/sparc-rtems4.12/erc32/lib -specs bsp_specs -qrtems
> -Wall
> > -g -O2 -o rtems_object_try rtems_object_try.c
> > but when i do ./rtems_object_try I get:
> > ./rtems_object_try: Invalid argument
> Do you try to run an executable compiled for sparc architecture on
> your developement machine ?
> « On ne résout pas un problème avec les modes de pensée qui l’ont
> engendré. »
> « We cannot solve our problems with the same thinking we used when we
> created them. »
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170124/e3978433/attachment-0001.html>
