RTEMS master LEON test status
Daniel Hellstrom
daniel at gaisler.com
Tue Jan 24 12:25:04 UTC 2017
Hi,
We started some time ago to work with the RTEMS master again. Daniel C
has updated the toolchain to use GCC-7 which now seems to be working
fine. I just want to share the current status of the RTEMS test-suite on
the GR712RC with you. Please let me know if you expect something or a
particular tests to be failing before we go too deep into them.
In the SMP configuration there were a couple of tests hanging and GRMON
interrupted them after 4 minutes. sp20 for example resulted in a hang
while acquiring a SMP lock from the Clock interrupt handler:
CPU 0: Interrupted!
0x400102e8: 01000000 nop <_SMP_lock_Acquire+44>
CPU 1: Interrupted!
0x40000000: a1480000 mov %psr, %l0
grmon2> bt
%pc %sp
#0 0x400102e8 0x40029d50 <_SMP_lock_Acquire+0x2c>
#1 0x4000ba00 0x40029d50 <_Rate_monotonic_Timeout+0x18>
#2 0x40016080 0x40029db8 <_Watchdog_Do_tickle+0x88>
#3 0x40016158 0x40029e18 <_Watchdog_Tick+0x54>
#4 0x4000e664 0x40029e88 <_Timecounter_Tick+0x2c>
#5 0x40002564 0x40029ef0 <Clock_isr+0x1c>
#6 0x4000417c 0x40029f50 <bsp_isr_handler+0x60>
#7 0x40023c0c 0x40029fb0
#8 0x4001177c 0x4002f9f0 <_Thread_Entry_adaptor_idle+0x8>
#9 0x40017a6c 0x4002fb00 <_Thread_Handler+0x48>
#10 0x40017a24 0x4002fb60 <_Thread_Handler+0>
grmon2> inst
TIME ADDRESS INSTRUCTION RESULT
639576231 400102E4 bne 0x400102DC [00000016]
639576232 400102E8 nop [00000000]
639576233 400102DC ld [%o0], %g1 [00000015]
639576235 400102E0 cmp %g2, %g1 [00000001]
639576236 400102E4 bne 0x400102DC [00000016]
639576237 400102E8 nop [00000000]
639576238 400102DC ld [%o0], %g1 [00000015]
639576240 400102E0 cmp %g2, %g1 [00000001]
639576241 400102E4 bne 0x400102DC [00000016]
639576242 400102E8 nop [ TRAP ]
grmon2> reg
INS LOCALS OUTS GLOBALS
0: 4002E668 F3000FC0 4002E664 00000000
1: 4002E668 4000B9E8 40029DB4 00000015
2: 80000000 4000B9EC 400264A4 00000016
3: 00000001 F30000C0 40026490 4002E190
4: 4002D538 40003000 4002A0A8 00000000
5: 4002E650 00000080 400264A8 00000060
6: 40029DB8 00000000 40029D50 400284C0
7: 40016080 00000000 4000BA00 00000000
psr: F3000FE0 wim: 00000080 tbr: 40000890 y: 0007613F
pc: 400102E8 nop
npc: 400102DC ld [%o0], %g1
grmon2>
GR712RC, RTEMS Single-core configuration results:
# RTEMS TESTSUITE FAILURE SUMMARY
# Result Test ExecRes ConsoleRes ExitCode1 ExitCode2
# FAIL: ./fstests/fsdosfsname01 OK FAIL 5 0
# FAIL: ./psxtests/psxsem01 OK FAIL 5 11
# FAIL: ./sptests/spinternalerror01 OK N/A -559038737 1611526157
# FAIL: ./sptests/sptimecounter01 OK N/A 5 0
# SUMMARY
# Tests failing: 4
# Tests successful: 528
GR712RC, RTEMS SMP configuration results:
# FAIL: ./libtests/rtmonuse FAIL FAIL N/A N/A
# FAIL: ./psxtests/psxshm01 FAIL FAIL N/A N/A
# FAIL: ./psxtests/psxshm02 FAIL FAIL N/A N/A
# FAIL: ./sptests/sp20 FAIL FAIL N/A N/A
# FAIL: ./sptests/sp60 FAIL FAIL N/A N/A
# FAIL: ./sptests/sp69 FAIL FAIL N/A N/A
# FAIL: ./sptests/spcbssched03 FAIL FAIL N/A N/A
# FAIL: ./sptests/spedfsched02 FAIL FAIL N/A N/A
# FAIL: ./sptests/spedfsched04 OK FAIL 5 0
# FAIL: ./sptests/spintrcritical08 FAIL FAIL N/A N/A
# FAIL: ./sptests/spratemon_err01 FAIL FAIL N/A N/A
# FAIL: ./sptests/sprmsched01 OK FAIL 5 0
# SUMMARY
# Tests failing: 15
# Tests successful: 564
Best Regards,
Daniel Hellstrom
Type: application/x-lzma
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170124/77a83054/attachment-0001.bin>
