RTEMS master LEON test status
Tue Jan 24 12:51:33 UTC 2017
Hello Daniel,
for RTEMS 4.12 GCC 6.3 will be used (most likely). I did test runs with
https://git.rtems.org/rtems/commit/?id=b07e642a2b1249cd64048c5e9f5e45254df7ae65
on the GR740 with no unexpected test failures.
On 24/01/17 13:25, Daniel Hellstrom wrote:
> Hi,
> We started some time ago to work with the RTEMS master again. Daniel C
> has updated the toolchain to use GCC-7 which now seems to be working
> fine. I just want to share the current status of the RTEMS test-suite
> on the GR712RC with you. Please let me know if you expect something or
> a particular tests to be failing before we go too deep into them.
> In the SMP configuration there were a couple of tests hanging and
> GRMON interrupted them after 4 minutes. sp20 for example resulted in a
> hang while acquiring a SMP lock from the Clock interrupt handler:
A change in the rate-monotonic manager did break several tests:
https://devel.rtems.org/ticket/2795
> GR712RC, RTEMS Single-core configuration results:
>   # RTEMS TESTSUITE FAILURE SUMMARY
>   # Result Test ExecRes ConsoleRes ExitCode1 ExitCode2
>   # FAIL: ./fstests/fsdosfsname01 OK FAIL 5 0
>   # FAIL: ./psxtests/psxsem01 OK FAIL 5 11
>   # FAIL: ./sptests/spinternalerror01 OK N/A -559038737 1611526157
>   # FAIL: ./sptests/sptimecounter01 OK N/A 5 0
>   # SUMMARY
>   #  Tests failing:    4
>   #  Tests successful: 528
It would be good to investigate these issues.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
