RTEMS master LEON test status
Kuan Hsun Chen
kuan-hsun.chen at tu-dortmund.de
Tue Jan 24 14:11:03 UTC 2017
Hello Sebastian,
I shouldn't do those ISR lock and _Thread_Dispatch_disable, right?
Does this patch solve some of the original test fails?
I'm trying the latest version now.
Best,
Kuan-Hsun
2017-01-24 14:46 GMT+01:00 Sebastian Huber <
sebastian.huber at embedded-brains.de>:
> Hello Kuan-Hsun,
> thanks for your prompt feedback. I checked in a patch that fixes one issue:
> https://devel.rtems.org/changeset/1240aade5a35c4e8c43d5409e2
> 329eeb6a173299/rtems
> On 24/01/17 14:27, Kuan Hsun Chen wrote:
>> Hi Sebastian,
>> I will check again the test on SMP target, though I only have QEMU-SMP to
>> simulate at the moment.
>> Is it okay to only test on QEMU?
>> Interestingly, why only sprmsched01 fails? How about spedfsched04?
>> I will start from this observation and see why SMP fails.
>> Best,
>> Kuan-Hsun
>> 2017-01-24 13:51 GMT+01:00 Sebastian Huber <sebastian.huber at embedded-brai
>> ns.de <mailto:sebastian.huber at embedded-brains.de>>:
>> Hello Daniel,
>> for RTEMS 4.12 GCC 6.3 will be used (most likely). I did test runs
>> with
>> https://git.rtems.org/rtems/commit/?id=b07e642a2b1249cd64048
>> c5e9f5e45254df7ae65
>> <https://git.rtems.org/rtems/commit/?id=b07e642a2b1249cd6404
>> 8c5e9f5e45254df7ae65>
>> on the GR740 with no unexpected test failures.
>> On 24/01/17 13:25, Daniel Hellstrom wrote:
>> Hi,
>> We started some time ago to work with the RTEMS master again.
>> Daniel C has updated the toolchain to use GCC-7 which now
>> seems to be working fine. I just want to share the current
>> status of the RTEMS test-suite on the GR712RC with you. Please
>> let me know if you expect something or a particular tests to
>> be failing before we go too deep into them.
>> In the SMP configuration there were a couple of tests hanging
>> and GRMON interrupted them after 4 minutes. sp20 for example
>> resulted in a hang while acquiring a SMP lock from the Clock
>> interrupt handler:
>> A change in the rate-monotonic manager did break several tests:
>> https://devel.rtems.org/ticket/2795
>> <https://devel.rtems.org/ticket/2795>
>> GR712RC, RTEMS Single-core configuration results:
>> # RTEMS TESTSUITE FAILURE SUMMARY
>> # Result Test ExecRes ConsoleRes ExitCode1 ExitCode2
>> # FAIL: ./fstests/fsdosfsname01 OK FAIL 5 0
>> # FAIL: ./psxtests/psxsem01 OK FAIL 5 11
>> # FAIL: ./sptests/spinternalerror01 OK N/A -559038737 1611526157
>> # FAIL: ./sptests/sptimecounter01 OK N/A 5 0
>> # SUMMARY
>> # Tests failing: 4
>> # Tests successful: 528
>> It would be good to investigate these issues.
>> -- Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone : +49 89 189 47 41-16 <tel:%2B49%2089%20189%2047%2041-16>
>> Fax : +49 89 189 47 41-09 <tel:%2B49%2089%20189%2047%2041-09>
>> E-Mail : sebastian.huber at embedded-brains.de
>> PGP : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> devel mailing list
>> devel at rtems.org <mailto:devel at rtems.org>
>> <http://lists.rtems.org/mailman/listinfo/devel>
>> M.Sc. Kuan-Hsun Chen
>> TU Dortmund
>> Department of Computer Science 12
>> Design Automation of Embedded Systems
>> Otto-Hahn-Strasse 16, Room 102
>> 44227 Dortmund
>> Germany
>> Phone: _+49 231 755 6124 <tel:+49%20231%207556124>_
>> Mail: kuan-hsun.chen at tu-dortmund.de <mailto:kuan-hsun.chen at tu-dortmund.de
TU Dortmund
44227 Dortmund
Germany
Phone: *+49 231 755 6124*
Mail: kuan-hsun.chen at tu-dortmund.de <kuan-hsun.chen at tu-dortmund.de>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170124/93772c15/attachment.html>
