psxshm01 and psxshm02 fail on SPARC/erc32
Wed Jan 25 03:00:43 UTC 2017
On Tue, Jan 24, 2017 at 7:25 PM, Joel Sherrill <joel at rtems.org> wrote:
> On Tue, Jan 24, 2017 at 6:23 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> Yes. They should fail with MAP_FAILED until we get a proper mmap().
>> This can be either detected, or the test can be augmented until we get
>> mmap support for shm objects done.
> When you say augmented, you mean with an implementation of the
> adapter layer you defined that uses malloc() and knows a few names?
I mean to ignore/expect the MAP_FAILED return from mmap and terminate
gracefully.
> --joel
>> On Tue, Jan 24, 2017 at 9:45 AM, Sebastian Huber
>> <sebastian.huber at embedded-brains.de> wrote:
>> > Hello,
>> > psxshm01 and psxshm02 fail on SPARC/erc32. Is this expected?
>> > Sebastian Huber, embedded brains GmbH
>> > Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> > Phone   : +49 89 189 47 41-16
>> > Fax     : +49 89 189 47 41-09
>> > E-Mail  : sebastian.huber at embedded-brains.de
>> > PGP     : Public key available on request.
>> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> devel mailing list
>> devel at rtems.org
