[PATCH] score: Delete _CPU_Context_Fp_start()
Wed Jan 25 13:35:12 UTC 2017
Since the FP area pointer is passed by reference in
_CPU_Context_Initialize_fp() the optional FP area adjustment via
_CPU_Context_Fp_start() is superfluous.  It is also wrong with respect
to memory management, e.g. pointer passed to _Workspace_Free() may be
not the one returned by _Workspace_Allocate().
Close #1400.
 cpukit/score/cpu/arm/rtems/score/cpu.h      |  3 ---
 cpukit/score/cpu/bfin/rtems/score/cpu.h     | 25 -------------------------
 cpukit/score/cpu/epiphany/rtems/score/cpu.h | 18 ------------------
 cpukit/score/cpu/i386/rtems/score/cpu.h     |  3 ---
 cpukit/score/cpu/lm32/rtems/score/cpu.h     | 27 ---------------------------
 cpukit/score/cpu/m32c/rtems/score/cpu.h     | 26 --------------------------
 cpukit/score/cpu/m68k/rtems/score/cpu.h     | 20 ++------------------
 cpukit/score/cpu/mips/rtems/score/cpu.h     | 17 -----------------
 cpukit/score/cpu/moxie/rtems/score/cpu.h    | 20 --------------------
 cpukit/score/cpu/no_cpu/rtems/score/cpu.h   | 26 --------------------------
 cpukit/score/cpu/or1k/rtems/score/cpu.h     | 18 +++++++-----------
 cpukit/score/cpu/powerpc/rtems/score/cpu.h  | 17 -----------------
 cpukit/score/cpu/sh/rtems/score/cpu.h       | 17 -----------------
 cpukit/score/cpu/sparc/rtems/score/cpu.h    |  7 -------
 cpukit/score/cpu/sparc64/rtems/score/cpu.h  |  8 --------
 cpukit/score/cpu/v850/rtems/score/cpu.h     | 28 ----------------------------
 cpukit/score/include/rtems/score/context.h  | 16 ----------------
 cpukit/score/src/threadinitialize.c         |  1 -
 18 files changed, 9 insertions(+), 288 deletions(-)
diff --git a/cpukit/score/cpu/arm/rtems/score/cpu.h b/cpukit/score/cpu/arm/rtems/score/cpu.h
index cdffc9c..9f321ac 100644
--- a/cpukit/score/cpu/arm/rtems/score/cpu.h
+++ b/cpukit/score/cpu/arm/rtems/score/cpu.h
@@ -458,9 +458,6 @@ void _CPU_Context_Initialize(
 #define _CPU_Context_Restart_self( _the_context ) \
    _CPU_Context_restore( (_the_context) );
-#define _CPU_Context_Fp_start( _base, _offset ) \
-   ( (void *) _Addresses_Add_offset( (_base), (_offset) ) )
 #define _CPU_Context_Initialize_fp( _destination ) \
   do { \
     *(*(_destination)) = _CPU_Null_fp_context; \
diff --git a/cpukit/score/cpu/bfin/rtems/score/cpu.h b/cpukit/score/cpu/bfin/rtems/score/cpu.h
index cdefedf..7c90fc6 100644
--- a/cpukit/score/cpu/bfin/rtems/score/cpu.h
+++ b/cpukit/score/cpu/bfin/rtems/score/cpu.h
@@ -734,31 +734,6 @@ void _CPU_Context_Initialize(
- * @ingroup CPUContext
- * The purpose of this macro is to allow the initial pointer into
- * a floating point context area (used to save the floating point
- * context) to be at an arbitrary place in the floating point
- * context area.
- * This is necessary because some FP units are designed to have
- * their context saved as a stack which grows into lower addresses.
- * Other FP units can be saved by simply moving registers into offsets
- * from the base of the context area.  Finally some FP units provide
- * a "dump context" instruction which could fill in from high to low
- * or low to high based on the whim of the CPU designers.
- * @param[in] _base is the lowest physical address of the floating point
- *        context area
- * @param[in] _offset is the offset into the floating point area
- * Port Specific Information:
- * XXX document implementation including references if appropriate
   memset( *( _destination ), 0, CPU_CONTEXT_FP_SIZE );
diff --git a/cpukit/score/cpu/epiphany/rtems/score/cpu.h b/cpukit/score/cpu/epiphany/rtems/score/cpu.h
index 55faefa..020d949 100644
--- a/cpukit/score/cpu/epiphany/rtems/score/cpu.h
+++ b/cpukit/score/cpu/epiphany/rtems/score/cpu.h
@@ -624,24 +624,6 @@ void _CPU_Context_Initialize(
- *  context area.
diff --git a/cpukit/score/cpu/i386/rtems/score/cpu.h b/cpukit/score/cpu/i386/rtems/score/cpu.h
index 052e53f..ace26f3 100644
--- a/cpukit/score/cpu/i386/rtems/score/cpu.h
+++ b/cpukit/score/cpu/i386/rtems/score/cpu.h
@@ -508,9 +508,6 @@ uint32_t   _CPU_ISR_Get_level( void );
 #endif
 #define _CPU_Context_Initialize_fp( _fp_area ) \
     memcpy( *_fp_area, &_CPU_Null_fp_context, CPU_CONTEXT_FP_SIZE ); \
diff --git a/cpukit/score/cpu/lm32/rtems/score/cpu.h b/cpukit/score/cpu/lm32/rtems/score/cpu.h
index 87cfd9e..9d22994 100644
--- a/cpukit/score/cpu/lm32/rtems/score/cpu.h
+++ b/cpukit/score/cpu/lm32/rtems/score/cpu.h
@@ -749,33 +749,6 @@ extern char _gp[];
- * context area.
- *        context area
-#if 0
-#endif
  * This routine initializes the FP context area passed to it to.
  * There are a few standard ways in which to initialize the
  * floating point context.  The code included for this macro assumes
diff --git a/cpukit/score/cpu/m32c/rtems/score/cpu.h b/cpukit/score/cpu/m32c/rtems/score/cpu.h
index 8dd8c41..af1c341 100644
--- a/cpukit/score/cpu/m32c/rtems/score/cpu.h
+++ b/cpukit/score/cpu/m32c/rtems/score/cpu.h
@@ -740,32 +740,6 @@ void _CPU_Context_Restart_self(
 ) RTEMS_NO_RETURN;
- * context area.
- *        context area
diff --git a/cpukit/score/cpu/m68k/rtems/score/cpu.h b/cpukit/score/cpu/m68k/rtems/score/cpu.h
index 0b9aa2d..ec6fd2e 100644
--- a/cpukit/score/cpu/m68k/rtems/score/cpu.h
+++ b/cpukit/score/cpu/m68k/rtems/score/cpu.h
@@ -172,12 +172,6 @@ typedef struct {
     } _operand2;
   } Context_Control_fp;
-   *  This software FP implementation is only for GCC.
-  #define _CPU_Context_Fp_start( _base, _offset ) \
-     ((void *) _Addresses_Add_offset( (_base), (_offset) ) )
        Context_Control_fp *_fp; \
@@ -234,9 +228,6 @@ typedef struct {
       #endif
-      ((void *) _Addresses_Add_offset( (_base), (_offset) ))
      * The reset value for all context relevant registers except the FP data
      * registers is zero.  The reset value of the FP data register is NAN.  The
@@ -260,17 +251,10 @@ typedef struct {
       uint8_t fp_save_area [M68K_FP_STATE_SIZE + 112];
-         (void *) _Addresses_Add_offset( \
-            (_base), \
-            (_offset) + CPU_CONTEXT_FP_SIZE - 4 \
-         uint32_t   *_fp_context = (uint32_t *)*(_fp_area); \
+         uint32_t *_fp_context = _Addresses_Add_offset( \
+           *(_fp_area), CPU_CONTEXT_FP_SIZE - 4); \
          *(--(_fp_context)) = 0; \
          *(_fp_area) = (void *)(_fp_context); \
diff --git a/cpukit/score/cpu/mips/rtems/score/cpu.h b/cpukit/score/cpu/mips/rtems/score/cpu.h
index 9a45d0b..74afc80 100644
--- a/cpukit/score/cpu/mips/rtems/score/cpu.h
+++ b/cpukit/score/cpu/mips/rtems/score/cpu.h
@@ -792,23 +792,6 @@ void _CPU_Context_Initialize(
- *  A floating point context area (used to save the floating point
- *  context area.
diff --git a/cpukit/score/cpu/moxie/rtems/score/cpu.h b/cpukit/score/cpu/moxie/rtems/score/cpu.h
index b77083d..a8b2263 100644
--- a/cpukit/score/cpu/moxie/rtems/score/cpu.h
+++ b/cpukit/score/cpu/moxie/rtems/score/cpu.h
@@ -608,26 +608,6 @@ uint32_t   _CPU_ISR_Get_level( void );
- *  context area.
- *  MOXIE Specific Information:
- *  XXX
-   ( (void *) (_base) + (_offset) )
diff --git a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
index 372b01f..62e1a91 100644
--- a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
+++ b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
@@ -876,32 +876,6 @@ uint32_t   _CPU_ISR_Get_level( void );
- *context area.
- *        context area
diff --git a/cpukit/score/cpu/or1k/rtems/score/cpu.h b/cpukit/score/cpu/or1k/rtems/score/cpu.h
index 4a643c7..3d4a6e0 100644
--- a/cpukit/score/cpu/or1k/rtems/score/cpu.h
+++ b/cpukit/score/cpu/or1k/rtems/score/cpu.h
@@ -620,10 +620,11 @@ void _CPU_Context_Initialize(
- *  context area.
+ *  This routine is responsible to initialize the FP context.
+ *  The FP area pointer is passed by reference to allow the initial pointer
+ *  into a floating point context area (used to save the floating point
+ *  context) to be at an arbitrary place in the floating point context area.
@@ -631,14 +632,9 @@ void _CPU_Context_Initialize(
-#define _CPU_Context_Initialize_fp( _destination ) \
-  memset( *( _destination ), 0, CPU_CONTEXT_FP_SIZE );
+#define _CPU_Context_Initialize_fp( _fp_area_p ) \
+  memset( *( _fp_area_p ), 0, CPU_CONTEXT_FP_SIZE )
 /* end of Context handler macros */
diff --git a/cpukit/score/cpu/powerpc/rtems/score/cpu.h b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
index 93d620e..a847667 100644
--- a/cpukit/score/cpu/powerpc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
@@ -831,23 +831,6 @@ void _CPU_Context_Initialize(
- *  context area.
diff --git a/cpukit/score/cpu/sh/rtems/score/cpu.h b/cpukit/score/cpu/sh/rtems/score/cpu.h
index 0ad3829..c2b7081 100644
--- a/cpukit/score/cpu/sh/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sh/rtems/score/cpu.h
@@ -550,23 +550,6 @@ void _CPU_Context_Initialize(
- *  context area.
diff --git a/cpukit/score/cpu/sparc/rtems/score/cpu.h b/cpukit/score/cpu/sparc/rtems/score/cpu.h
index a59fc36..7c81f07 100644
--- a/cpukit/score/cpu/sparc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc/rtems/score/cpu.h
@@ -956,13 +956,6 @@ void _CPU_Context_Initialize(
- * The FP context area for the SPARC is a simple structure and nothing
- * special is required to find the "starting load point"
  * The SPARC allows us to use the simple initialization model
diff --git a/cpukit/score/cpu/sparc64/rtems/score/cpu.h b/cpukit/score/cpu/sparc64/rtems/score/cpu.h
index 9926ebb..47041e7 100644
--- a/cpukit/score/cpu/sparc64/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc64/rtems/score/cpu.h
@@ -824,14 +824,6 @@ void _CPU_Context_Initialize(
diff --git a/cpukit/score/cpu/v850/rtems/score/cpu.h b/cpukit/score/cpu/v850/rtems/score/cpu.h
index 6c77f51..d3cdf05 100644
--- a/cpukit/score/cpu/v850/rtems/score/cpu.h
+++ b/cpukit/score/cpu/v850/rtems/score/cpu.h
@@ -699,34 +699,6 @@ void _CPU_Context_Initialize(
 /* XXX this should be possible to remove */
 #if 0
- * context area.
- *        context area
-#endif
-/* XXX this should be possible to remove */
-#if 0
diff --git a/cpukit/score/include/rtems/score/context.h b/cpukit/score/include/rtems/score/context.h
index 7e59f05..46cb460 100644
--- a/cpukit/score/include/rtems/score/context.h
+++ b/cpukit/score/include/rtems/score/context.h
@@ -111,22 +111,6 @@ extern "C" {
- *  @brief Return starting address of floating point context.
- *  This function returns the starting address of the floating
- *  point context save area.  It is assumed that the are reserved
- *  for the floating point save area is large enough.
- *  @param[in] _base is lowest physical address of the floating point
- *         context save area.
- *  @retval the initial FP context pointer
-#define _Context_Fp_start( _base, _offset ) \
-   _CPU_Context_Fp_start( (_base), (_offset) )
  *  @brief Initialize floating point context area.
  *  This routine initializes the floating point context save
diff --git a/cpukit/score/src/threadinitialize.c b/cpukit/score/src/threadinitialize.c
index 9ae2acb..5725c6e 100644
--- a/cpukit/score/src/threadinitialize.c
+++ b/cpukit/score/src/threadinitialize.c
@@ -137,7 +137,6 @@ bool _Thread_Initialize(
       fp_area = _Workspace_Allocate( CONTEXT_FP_SIZE );
       if ( !fp_area )
         goto failed;
-      fp_area = _Context_Fp_start( fp_area, 0 );
     the_thread->fp_context       = fp_area;
     the_thread->Start.fp_context = fp_area;
1.8.4.5
