[PATCH] Remove rtems_rate_monotonic_postponed_job_count() Add a variable named "count" in rtems_rate_monotonic_period_status structure Revise rtems_rate_monotonic_get_status() for the postponed job count.
Kuan-Hsun Chen c0066c at gmail.com
Wed Jan 25 14:04:36 UTC 2017
sptests/sp69: Revise
Add in the verification of the postponed job count for rtems_rate_monotonic_get_status().
 cpukit/rtems/include/rtems/rtems/ratemon.h | 24 +++++-------------------
 cpukit/rtems/src/ratemongetstatus.c        |  2 ++
 cpukit/rtems/src/ratemonperiod.c           | 14 --------------
 testsuites/sptests/sp69/init.c             |  8 ++++++++
 testsuites/sptests/sp69/sp69.doc           |  2 ++
 testsuites/sptests/sp69/sp69.scn           |  5 +++--
 6 files changed, 20 insertions(+), 35 deletions(-)
diff --git a/cpukit/rtems/include/rtems/rtems/ratemon.h b/cpukit/rtems/include/rtems/rtems/ratemon.h
index 54ddd05..59512c5 100644
--- a/cpukit/rtems/include/rtems/rtems/ratemon.h
+++ b/cpukit/rtems/include/rtems/rtems/ratemon.h
@@ -182,6 +182,11 @@ typedef struct {
    *  then this field has no meaning.
   rtems_thread_cpu_usage_t             executed_since_last_period;
+  /** This is the number of postponed jobs. This number
+   * is only increased by the corresponding watchdog,
+   * and is decreased by RMS manager with the postponed job releasing. */
+  uint32_t                             postponed_jobs_count;
 }  rtems_rate_monotonic_period_status;
@@ -417,25 +422,6 @@ rtems_status_code rtems_rate_monotonic_period(
   rtems_interval  length
- * @brief Return the number of postponed jobs
- * This is a helper function for runtime monitoring to return
- * the number of postponed jobs in this given period. This number
- * is only increased by the corresponding watchdog,
- * and is decreased by RMS manager with the postponed job releasing.
- * @param[in] id is the period id
- * @retval This helper function returns the number of postponed
- * jobs with a given period_id.
-uint32_t rtems_rate_monotonic_postponed_job_count(
-  rtems_id        period_id
 #ifdef __cplusplus
diff --git a/cpukit/rtems/src/ratemongetstatus.c b/cpukit/rtems/src/ratemongetstatus.c
index 403c6ed..8bd3613 100644
--- a/cpukit/rtems/src/ratemongetstatus.c
+++ b/cpukit/rtems/src/ratemongetstatus.c
@@ -9,6 +9,7 @@
  *  COPYRIGHT (c) 1989-2009.
  *  On-Line Applications Research Corporation (OAR).
  *  Copyright (c) 2016 embedded brains GmbH.
+ *  Copyright (c) 2016 Kuan-Hsun Chen.
  *  The license and distribution terms for this file may be
  *  found in the file LICENSE in this distribution or at
@@ -43,6 +44,7 @@ rtems_status_code rtems_rate_monotonic_get_status(
   period_status->owner = the_period->owner->Object.id;
   period_status->state = the_period->state;
+  period_status->postponed_jobs_count = the_period->postponed_jobs;
   if ( the_period->state == RATE_MONOTONIC_INACTIVE ) {
diff --git a/cpukit/rtems/src/ratemonperiod.c b/cpukit/rtems/src/ratemonperiod.c
index 97547e2..efcd121 100644
--- a/cpukit/rtems/src/ratemonperiod.c
+++ b/cpukit/rtems/src/ratemonperiod.c
@@ -302,20 +302,6 @@ static rtems_status_code _Rate_monotonic_Block_while_expired(
   return RTEMS_TIMEOUT;
-uint32_t rtems_rate_monotonic_postponed_job_count( rtems_id period_id )
-  Rate_monotonic_Control *the_period;
-  ISR_lock_Context        lock_context;
-  uint32_t                jobs;
-  the_period = _Rate_monotonic_Get( period_id, &lock_context );
-  _Assert( the_period != NULL );
-  jobs = the_period->postponed_jobs;
-  _Rate_monotonic_Release( the_period, &lock_context );
-  return jobs;
   rtems_id       id,
diff --git a/testsuites/sptests/sp69/init.c b/testsuites/sptests/sp69/init.c
index ac6f58c..c38beb8 100644
--- a/testsuites/sptests/sp69/init.c
+++ b/testsuites/sptests/sp69/init.c
@@ -162,6 +162,14 @@ rtems_task Init(
     rtems_test_assert( statistics.missed_count == i );
+  /* Check the status */
+  status = rtems_rate_monotonic_get_status( period_id, &period_status );
+  directive_failed( status, "rate_monotonic_get_status" );
+  puts(
+    "rtems_rate_monotonic_get_status - verify value of a postponed jobs count"
+  rtems_test_assert( period_status.postponed_jobs_count == 3 );
   TEST_END();
diff --git a/testsuites/sptests/sp69/sp69.doc b/testsuites/sptests/sp69/sp69.doc
index fbf0e4e..e881a19 100644
--- a/testsuites/sptests/sp69/sp69.doc
+++ b/testsuites/sptests/sp69/sp69.doc
@@ -1,5 +1,6 @@
 #  COPYRIGHT (c) 1989-2009.
 #  On-Line Applications Research Corporation (OAR).
+#  COPYRIGHT (c) Kuan-Hsun Chen.
 #  The license and distribution terms for this file may be
 #  found in the file LICENSE in this distribution or at
@@ -21,3 +22,4 @@ concepts:
   a period is initiated.
 + Verify the correctness of the status values returned on an active period.
 + Ensure the missed period count is properly maintained.
++ Verify the correctness of the postponed job count.
diff --git a/testsuites/sptests/sp69/sp69.scn b/testsuites/sptests/sp69/sp69.scn
index 654eea0..e102d22 100644
--- a/testsuites/sptests/sp69/sp69.scn
+++ b/testsuites/sptests/sp69/sp69.scn
@@ -2,8 +2,9 @@
 rtems_rate_monotonic_get_status - verify values of an inactive period
 rtems_rate_monotonic_get_status - check RTEMS_NOT_DEFINED
 rtems_rate_monotonic_get_status - verify values of an active period
-wall time should be ~600000000 is 609216000
-cpu time should be ~100000000 is 109217000
+wall time should be ~600000000 is 609402399
+cpu time should be ~100000000 is 109612659
 rtems_rate_monotonic_cancel -  OK
 Testing statistics on missed periods
+rtems_rate_monotonic_get_status - verify value of a postponed jobs count
 *** END OF TEST 69 ***
1.9.1
