[PATCH] Remove rtems_rate_monotonic_postponed_job_count() Add a variable named "count" in rtems_rate_monotonic_period_status structure Revise rtems_rate_monotonic_get_status() for the postponed job count.
Wed Jan 25 14:10:21 UTC 2017
Please use the standard Git commit message format.
On 25/01/17 15:04, Kuan-Hsun Chen wrote:
> sptests/sp69: Revise
> Add in the verification of the postponed job count for rtems_rate_monotonic_get_status().
>   cpukit/rtems/include/rtems/rtems/ratemon.h | 24 +++++-------------------
>   cpukit/rtems/src/ratemongetstatus.c        |  2 ++
>   cpukit/rtems/src/ratemonperiod.c           | 14 --------------
>   testsuites/sptests/sp69/init.c             |  8 ++++++++
>   testsuites/sptests/sp69/sp69.doc           |  2 ++
>   testsuites/sptests/sp69/sp69.scn           |  5 +++--
>   6 files changed, 20 insertions(+), 35 deletions(-)
> diff --git a/cpukit/rtems/include/rtems/rtems/ratemon.h b/cpukit/rtems/include/rtems/rtems/ratemon.h
> index 54ddd05..59512c5 100644
> --- a/cpukit/rtems/include/rtems/rtems/ratemon.h
> +++ b/cpukit/rtems/include/rtems/rtems/ratemon.h
> @@ -182,6 +182,11 @@ typedef struct {
>      *  then this field has no meaning.
>     rtems_thread_cpu_usage_t             executed_since_last_period;
> +  /** This is the number of postponed jobs. This number
> +   * is only increased by the corresponding watchdog,
> +   * and is decreased by RMS manager with the postponed job releasing. */
> +  uint32_t                             postponed_jobs_count;
>   }  rtems_rate_monotonic_period_status;
Number in comment vs. count in member. I prefer count. Please clarify
this a bit and avoid the watchdog. The watchdog is an implementation
detail. The mentioning of RMS manager is redundant.
> @@ -417,25 +422,6 @@ rtems_status_code rtems_rate_monotonic_period(
>     rtems_interval  length
> - * @brief Return the number of postponed jobs
> - * This is a helper function for runtime monitoring to return
> - * the number of postponed jobs in this given period. This number
> - * is only increased by the corresponding watchdog,
> - * and is decreased by RMS manager with the postponed job releasing.
> - * @param[in] id is the period id
> - * @retval This helper function returns the number of postponed
> - * jobs with a given period_id.
> -uint32_t rtems_rate_monotonic_postponed_job_count(
> -  rtems_id        period_id
>   #ifdef __cplusplus
> diff --git a/cpukit/rtems/src/ratemongetstatus.c b/cpukit/rtems/src/ratemongetstatus.c
> index 403c6ed..8bd3613 100644
> --- a/cpukit/rtems/src/ratemongetstatus.c
> +++ b/cpukit/rtems/src/ratemongetstatus.c
> @@ -9,6 +9,7 @@
>    *  COPYRIGHT (c) 1989-2009.
>    *  On-Line Applications Research Corporation (OAR).
>    *  Copyright (c) 2016 embedded brains GmbH.
> + *  Copyright (c) 2016 Kuan-Hsun Chen.
We have 2017.
>    *  The license and distribution terms for this file may be
>    *  found in the file LICENSE in this distribution or at
> @@ -43,6 +44,7 @@ rtems_status_code rtems_rate_monotonic_get_status(
>     period_status->owner = the_period->owner->Object.id;
>     period_status->state = the_period->state;
> +  period_status->postponed_jobs_count = the_period->postponed_jobs;
>     if ( the_period->state == RATE_MONOTONIC_INACTIVE ) {
> diff --git a/cpukit/rtems/src/ratemonperiod.c b/cpukit/rtems/src/ratemonperiod.c
> index 97547e2..efcd121 100644
> --- a/cpukit/rtems/src/ratemonperiod.c
> +++ b/cpukit/rtems/src/ratemonperiod.c
> @@ -302,20 +302,6 @@ static rtems_status_code _Rate_monotonic_Block_while_expired(
>     return RTEMS_TIMEOUT;
> -uint32_t rtems_rate_monotonic_postponed_job_count( rtems_id period_id )
> -  Rate_monotonic_Control *the_period;
> -  ISR_lock_Context        lock_context;
> -  uint32_t                jobs;
> -  the_period = _Rate_monotonic_Get( period_id, &lock_context );
> -  _Assert( the_period != NULL );
> -  jobs = the_period->postponed_jobs;
> -  _Rate_monotonic_Release( the_period, &lock_context );
> -  return jobs;
>     rtems_id       id,
> diff --git a/testsuites/sptests/sp69/init.c b/testsuites/sptests/sp69/init.c
> index ac6f58c..c38beb8 100644
> --- a/testsuites/sptests/sp69/init.c
> +++ b/testsuites/sptests/sp69/init.c
Missing copyright?
> @@ -162,6 +162,14 @@ rtems_task Init(
>       rtems_test_assert( statistics.missed_count == i );
> +  /* Check the status */
> +  status = rtems_rate_monotonic_get_status( period_id, &period_status );
> +  directive_failed( status, "rate_monotonic_get_status" );
> +  puts(
> +    "rtems_rate_monotonic_get_status - verify value of a postponed jobs count"
> +  rtems_test_assert( period_status.postponed_jobs_count == 3 );
>     TEST_END();
> diff --git a/testsuites/sptests/sp69/sp69.doc b/testsuites/sptests/sp69/sp69.doc
> index fbf0e4e..e881a19 100644
> --- a/testsuites/sptests/sp69/sp69.doc
> +++ b/testsuites/sptests/sp69/sp69.doc
> @@ -1,5 +1,6 @@
>   #  COPYRIGHT (c) 1989-2009.
>   #  On-Line Applications Research Corporation (OAR).
> +#  COPYRIGHT (c) Kuan-Hsun Chen.
Missing year.
>   #  The license and distribution terms for this file may be
>   #  found in the file LICENSE in this distribution or at
> @@ -21,3 +22,4 @@ concepts:
>     a period is initiated.
>   + Verify the correctness of the status values returned on an active period.
>   + Ensure the missed period count is properly maintained.
> ++ Verify the correctness of the postponed job count.
> diff --git a/testsuites/sptests/sp69/sp69.scn b/testsuites/sptests/sp69/sp69.scn
> index 654eea0..e102d22 100644
> --- a/testsuites/sptests/sp69/sp69.scn
> +++ b/testsuites/sptests/sp69/sp69.scn
> @@ -2,8 +2,9 @@
>   rtems_rate_monotonic_get_status - verify values of an inactive period
>   rtems_rate_monotonic_get_status - check RTEMS_NOT_DEFINED
>   rtems_rate_monotonic_get_status - verify values of an active period
> -wall time should be ~600000000 is 609216000
> -cpu time should be ~100000000 is 109217000
> +wall time should be ~600000000 is 609402399
> +cpu time should be ~100000000 is 109612659
>   rtems_rate_monotonic_cancel -  OK
>   Testing statistics on missed periods
> +rtems_rate_monotonic_get_status - verify value of a postponed jobs count
>   *** END OF TEST 69 ***
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
