[PATCH] rtems: Fix _Rate_monotonic_Renew_deadline()
Kuan Hsun Chen
kuan-hsun.chen at tu-dortmund.de
Wed Jan 25 15:10:40 UTC 2017
Hi Sebastian,
Should I test the overflow condition together with sp69 or prepare a new
test for this matter?
Best,
Kuan-Hsun
2017-01-25 15:53 GMT+01:00 Sebastian Huber <
sebastian.huber at embedded-brains.de>:
> On 25/01/17 15:48, Kuan-Hsun Chen wrote:
>> cpukit/rtems/src/ratemontimeout.c | 7 +++++--
>> 1 file changed, 5 insertions(+), 2 deletions(-)
>> diff --git a/cpukit/rtems/src/ratemontimeout.c
>> b/cpukit/rtems/src/ratemontimeout.c
>> index bcc4ccf..079ad41 100644
>> --- a/cpukit/rtems/src/ratemontimeout.c
>> +++ b/cpukit/rtems/src/ratemontimeout.c
>> @@ -9,7 +9,7 @@
>> * COPYRIGHT (c) 1989-2009.
>> * On-Line Applications Research Corporation (OAR).
>> - * COPYRIGHT (c) 2016 Kuan-Hsun Chen.
>> + * COPYRIGHT (c) 2017 Kuan-Hsun Chen.
> This should be 2016, 2017 or 2016-2017.
>> * The license and distribution terms for this file may be
>> * found in the file LICENSE in this distribution or at
>> @@ -30,7 +30,10 @@ static void _Rate_monotonic_Renew_deadline(
>> uint64_t deadline;
>> - ++the_period->postponed_jobs;
>> + /** stay at 0xffffffff if postponed_jobs is going to overflow */
> /** is a Doxygen comment.
> + if ( the_period->postponed_jobs != UINT_MAX ) {
>> + ++the_period->postponed_jobs;
> Type is uint32_t, not unsigned int. So, use UINT32_MAX. Maybe
> Empty lines between blocks.
> the_period->state = RATE_MONOTONIC_EXPIRED;
>> deadline = _Watchdog_Per_CPU_insert_relative(
> We need a test case for this overflow condition. You probably have to
> modify the_period->postponed_jobs by hand in the test case to avoid
> extremely long test run times.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> devel mailing list
> devel at rtems.org
M.Sc. Kuan-Hsun Chen
TU Dortmund
Department of Computer Science 12
Design Automation of Embedded Systems
Otto-Hahn-Strasse 16, Room 102
44227 Dortmund
Germany
Phone: *+49 231 755 6124*
Mail: kuan-hsun.chen at tu-dortmund.de <kuan-hsun.chen at tu-dortmund.de>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170125/18e1bc9a/attachment.html>
