[PATCH] score: Delete _CPU_Context_Fp_start()
Joel Sherrill
joel at rtems.org
Wed Jan 25 16:18:51 UTC 2017
On Wed, Jan 25, 2017 at 10:13 AM, Gedare Bloom <gedare at rtems.org> wrote:
> I guess the CPU Supplement must be updated too.
Equally likely to impact the porting guide as well.
--joel
> On Wed, Jan 25, 2017 at 8:35 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
> > Since the FP area pointer is passed by reference in
> > _CPU_Context_Initialize_fp() the optional FP area adjustment via
> > _CPU_Context_Fp_start() is superfluous. It is also wrong with respect
> > to memory management, e.g. pointer passed to _Workspace_Free() may be
> > not the one returned by _Workspace_Allocate().
> > Close #1400.
> > cpukit/score/cpu/arm/rtems/score/cpu.h | 3 ---
> > cpukit/score/cpu/bfin/rtems/score/cpu.h | 25
> > cpukit/score/cpu/epiphany/rtems/score/cpu.h | 18 ------------------
> > cpukit/score/cpu/i386/rtems/score/cpu.h | 3 ---
> > cpukit/score/cpu/lm32/rtems/score/cpu.h | 27
> > cpukit/score/cpu/m32c/rtems/score/cpu.h | 26
> > cpukit/score/cpu/m68k/rtems/score/cpu.h | 20 ++------------------
> > cpukit/score/cpu/mips/rtems/score/cpu.h | 17 -----------------
> > cpukit/score/cpu/moxie/rtems/score/cpu.h | 20 --------------------
> > cpukit/score/cpu/no_cpu/rtems/score/cpu.h | 26
> > cpukit/score/cpu/or1k/rtems/score/cpu.h | 18 +++++++-----------
> > cpukit/score/cpu/powerpc/rtems/score/cpu.h | 17 -----------------
> > cpukit/score/cpu/sh/rtems/score/cpu.h | 17 -----------------
> > cpukit/score/cpu/sparc/rtems/score/cpu.h | 7 -------
> > cpukit/score/cpu/sparc64/rtems/score/cpu.h | 8 --------
> > cpukit/score/cpu/v850/rtems/score/cpu.h | 28
> > cpukit/score/include/rtems/score/context.h | 16 ----------------
> > cpukit/score/src/threadinitialize.c | 1 -
> > 18 files changed, 9 insertions(+), 288 deletions(-)
> > diff --git a/cpukit/score/cpu/arm/rtems/score/cpu.h
> b/cpukit/score/cpu/arm/rtems/score/cpu.h
> > index cdffc9c..9f321ac 100644
> > --- a/cpukit/score/cpu/arm/rtems/score/cpu.h
> > +++ b/cpukit/score/cpu/arm/rtems/score/cpu.h
> > @@ -458,9 +458,6 @@ void _CPU_Context_Initialize(
> > #define _CPU_Context_Restart_self( _the_context ) \
> > _CPU_Context_restore( (_the_context) );
> > -#define _CPU_Context_Fp_start( _base, _offset ) \
> > - ( (void *) _Addresses_Add_offset( (_base), (_offset) ) )
> > #define _CPU_Context_Initialize_fp( _destination ) \
> > do { \
> > *(*(_destination)) = _CPU_Null_fp_context; \
> > diff --git a/cpukit/score/cpu/bfin/rtems/score/cpu.h
> b/cpukit/score/cpu/bfin/rtems/score/cpu.h
> > index cdefedf..7c90fc6 100644
> > --- a/cpukit/score/cpu/bfin/rtems/score/cpu.h
> > +++ b/cpukit/score/cpu/bfin/rtems/score/cpu.h
> > @@ -734,31 +734,6 @@ void _CPU_Context_Initialize(
> > - * @ingroup CPUContext
> > - * The purpose of this macro is to allow the initial pointer into
> > - * a floating point context area (used to save the floating point
> > - * context) to be at an arbitrary place in the floating point
> > - * context area.
> > - * This is necessary because some FP units are designed to have
> > - * their context saved as a stack which grows into lower addresses.
> > - * Other FP units can be saved by simply moving registers into offsets
> > - * from the base of the context area. Finally some FP units provide
> > - * a "dump context" instruction which could fill in from high to low
> > - * or low to high based on the whim of the CPU designers.
> > - * @param[in] _base is the lowest physical address of the floating point
> > - * context area
> > - * @param[in] _offset is the offset into the floating point area
> > - * Port Specific Information:
> > - * XXX document implementation including references if appropriate
> > memset( *( _destination ), 0, CPU_CONTEXT_FP_SIZE );
> > diff --git a/cpukit/score/cpu/epiphany/rtems/score/cpu.h
> b/cpukit/score/cpu/epiphany/rtems/score/cpu.h
> > index 55faefa..020d949 100644
> > --- a/cpukit/score/cpu/epiphany/rtems/score/cpu.h
> > +++ b/cpukit/score/cpu/epiphany/rtems/score/cpu.h
> > @@ -624,24 +624,6 @@ void _CPU_Context_Initialize(
> > - * context area.
> > diff --git a/cpukit/score/cpu/i386/rtems/score/cpu.h
> b/cpukit/score/cpu/i386/rtems/score/cpu.h
> > index 052e53f..ace26f3 100644
> > --- a/cpukit/score/cpu/i386/rtems/score/cpu.h
> > +++ b/cpukit/score/cpu/i386/rtems/score/cpu.h
> > @@ -508,9 +508,6 @@ uint32_t _CPU_ISR_Get_level( void );
> > #endif
> > #define _CPU_Context_Initialize_fp( _fp_area ) \
> > memcpy( *_fp_area, &_CPU_Null_fp_context, CPU_CONTEXT_FP_SIZE ); \
> > diff --git a/cpukit/score/cpu/lm32/rtems/score/cpu.h
> b/cpukit/score/cpu/lm32/rtems/score/cpu.h
> > index 87cfd9e..9d22994 100644
> > --- a/cpukit/score/cpu/lm32/rtems/score/cpu.h
> > +++ b/cpukit/score/cpu/lm32/rtems/score/cpu.h
> > @@ -749,33 +749,6 @@ extern char _gp[];
> > - * context area.
> > - * context area
> > -#if 0
> > -#endif
> > * This routine initializes the FP context area passed to it to.
> > * There are a few standard ways in which to initialize the
> > * floating point context. The code included for this macro assumes
> > diff --git a/cpukit/score/cpu/m32c/rtems/score/cpu.h
> b/cpukit/score/cpu/m32c/rtems/score/cpu.h
> > index 8dd8c41..af1c341 100644
> > --- a/cpukit/score/cpu/m32c/rtems/score/cpu.h
> > +++ b/cpukit/score/cpu/m32c/rtems/score/cpu.h
> > @@ -740,32 +740,6 @@ void _CPU_Context_Restart_self(
> > ) RTEMS_NO_RETURN;
> > - * context area.
> > - * context area
> > diff --git a/cpukit/score/cpu/m68k/rtems/score/cpu.h
> b/cpukit/score/cpu/m68k/rtems/score/cpu.h
> > index 0b9aa2d..ec6fd2e 100644
> > --- a/cpukit/score/cpu/m68k/rtems/score/cpu.h
> > +++ b/cpukit/score/cpu/m68k/rtems/score/cpu.h
> > @@ -172,12 +172,6 @@ typedef struct {
> > } _operand2;
> > } Context_Control_fp;
> > - * This software FP implementation is only for GCC.
> > - #define _CPU_Context_Fp_start( _base, _offset ) \
> > - ((void *) _Addresses_Add_offset( (_base), (_offset) ) )
> > Context_Control_fp *_fp; \
> > @@ -234,9 +228,6 @@ typedef struct {
> > #endif
> > - ((void *) _Addresses_Add_offset( (_base), (_offset) ))
> > * The reset value for all context relevant registers except the FP
> data
> > * registers is zero. The reset value of the FP data register is
> NAN. The
> > @@ -260,17 +251,10 @@ typedef struct {
> > uint8_t fp_save_area [M68K_FP_STATE_SIZE + 112];
> > - (void *) _Addresses_Add_offset( \
> > - (_base), \
> > - (_offset) + CPU_CONTEXT_FP_SIZE - 4 \
> > - uint32_t *_fp_context = (uint32_t *)*(_fp_area); \
> > + uint32_t *_fp_context = _Addresses_Add_offset( \
> > + *(_fp_area), CPU_CONTEXT_FP_SIZE - 4); \
> > *(--(_fp_context)) = 0; \
> > *(_fp_area) = (void *)(_fp_context); \
> > diff --git a/cpukit/score/cpu/mips/rtems/score/cpu.h
> b/cpukit/score/cpu/mips/rtems/score/cpu.h
> > index 9a45d0b..74afc80 100644
> > --- a/cpukit/score/cpu/mips/rtems/score/cpu.h
> > +++ b/cpukit/score/cpu/mips/rtems/score/cpu.h
> > @@ -792,23 +792,6 @@ void _CPU_Context_Initialize(
> > - * A floating point context area (used to save the floating point
> > - * context area.
> > diff --git a/cpukit/score/cpu/moxie/rtems/score/cpu.h
> b/cpukit/score/cpu/moxie/rtems/score/cpu.h
> > index b77083d..a8b2263 100644
> > --- a/cpukit/score/cpu/moxie/rtems/score/cpu.h
> > +++ b/cpukit/score/cpu/moxie/rtems/score/cpu.h
> > @@ -608,26 +608,6 @@ uint32_t _CPU_ISR_Get_level( void );
> > - * context area.
> > - * MOXIE Specific Information:
> > - * XXX
> > - ( (void *) (_base) + (_offset) )
> > diff --git a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
> b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
> > index 372b01f..62e1a91 100644
> > --- a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
> > +++ b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
> > @@ -876,32 +876,6 @@ uint32_t _CPU_ISR_Get_level( void );
> > - *context area.
> > - * context area
> > diff --git a/cpukit/score/cpu/or1k/rtems/score/cpu.h
> b/cpukit/score/cpu/or1k/rtems/score/cpu.h
> > index 4a643c7..3d4a6e0 100644
> > --- a/cpukit/score/cpu/or1k/rtems/score/cpu.h
> > +++ b/cpukit/score/cpu/or1k/rtems/score/cpu.h
> > @@ -620,10 +620,11 @@ void _CPU_Context_Initialize(
> > - * context area.
> > + * This routine is responsible to initialize the FP context.
> > + * The FP area pointer is passed by reference to allow the initial
> pointer
> > + * into a floating point context area (used to save the floating point
> > + * context) to be at an arbitrary place in the floating point context
> area.
> > @@ -631,14 +632,9 @@ void _CPU_Context_Initialize(
> > -#define _CPU_Context_Initialize_fp( _destination ) \
> > - memset( *( _destination ), 0, CPU_CONTEXT_FP_SIZE );
> > +#define _CPU_Context_Initialize_fp( _fp_area_p ) \
> > + memset( *( _fp_area_p ), 0, CPU_CONTEXT_FP_SIZE )
> > /* end of Context handler macros */
> > diff --git a/cpukit/score/cpu/powerpc/rtems/score/cpu.h
> b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
> > index 93d620e..a847667 100644
> > --- a/cpukit/score/cpu/powerpc/rtems/score/cpu.h
> > +++ b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
> > @@ -831,23 +831,6 @@ void _CPU_Context_Initialize(
> > - * context area.
> > diff --git a/cpukit/score/cpu/sh/rtems/score/cpu.h
> b/cpukit/score/cpu/sh/rtems/score/cpu.h
> > index 0ad3829..c2b7081 100644
> > --- a/cpukit/score/cpu/sh/rtems/score/cpu.h
> > +++ b/cpukit/score/cpu/sh/rtems/score/cpu.h
> > @@ -550,23 +550,6 @@ void _CPU_Context_Initialize(
> > - * context area.
> > diff --git a/cpukit/score/cpu/sparc/rtems/score/cpu.h
> b/cpukit/score/cpu/sparc/rtems/score/cpu.h
> > index a59fc36..7c81f07 100644
> > --- a/cpukit/score/cpu/sparc/rtems/score/cpu.h
> > +++ b/cpukit/score/cpu/sparc/rtems/score/cpu.h
> > @@ -956,13 +956,6 @@ void _CPU_Context_Initialize(
> > - * The FP context area for the SPARC is a simple structure and nothing
> > - * special is required to find the "starting load point"
> > * The SPARC allows us to use the simple initialization model
> > diff --git a/cpukit/score/cpu/sparc64/rtems/score/cpu.h
> b/cpukit/score/cpu/sparc64/rtems/score/cpu.h
> > index 9926ebb..47041e7 100644
> > --- a/cpukit/score/cpu/sparc64/rtems/score/cpu.h
> > +++ b/cpukit/score/cpu/sparc64/rtems/score/cpu.h
> > @@ -824,14 +824,6 @@ void _CPU_Context_Initialize(
> > diff --git a/cpukit/score/cpu/v850/rtems/score/cpu.h
> b/cpukit/score/cpu/v850/rtems/score/cpu.h
> > index 6c77f51..d3cdf05 100644
> > --- a/cpukit/score/cpu/v850/rtems/score/cpu.h
> > +++ b/cpukit/score/cpu/v850/rtems/score/cpu.h
> > @@ -699,34 +699,6 @@ void _CPU_Context_Initialize(
> > /* XXX this should be possible to remove */
> > #if 0
> > - * context area.
> > - * context area
> > -#endif
> > -/* XXX this should be possible to remove */
> > -#if 0
> > diff --git a/cpukit/score/include/rtems/score/context.h
> b/cpukit/score/include/rtems/score/context.h
> > index 7e59f05..46cb460 100644
> > --- a/cpukit/score/include/rtems/score/context.h
> > +++ b/cpukit/score/include/rtems/score/context.h
> > @@ -111,22 +111,6 @@ extern "C" {
> > - * @brief Return starting address of floating point context.
> > - * This function returns the starting address of the floating
> > - * point context save area. It is assumed that the are reserved
> > - * for the floating point save area is large enough.
> > - * @param[in] _base is lowest physical address of the floating point
> > - * context save area.
> > - * @retval the initial FP context pointer
> > -#define _Context_Fp_start( _base, _offset ) \
> > - _CPU_Context_Fp_start( (_base), (_offset) )
> > * @brief Initialize floating point context area.
> > * This routine initializes the floating point context save
> > diff --git a/cpukit/score/src/threadinitialize.c b/cpukit/score/src/
> threadinitialize.c
> > index 9ae2acb..5725c6e 100644
> > --- a/cpukit/score/src/threadinitialize.c
> > +++ b/cpukit/score/src/threadinitialize.c
> > @@ -137,7 +137,6 @@ bool _Thread_Initialize(
> > fp_area = _Workspace_Allocate( CONTEXT_FP_SIZE );
> > if ( !fp_area )
> > goto failed;
> > - fp_area = _Context_Fp_start( fp_area, 0 );
> > the_thread->fp_context = fp_area;
> > the_thread->Start.fp_context = fp_area;
> > 1.8.4.5
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170125/1a03399b/attachment-0001.html>
