Help
Wed Jan 25 16:33:25 UTC 2017
Hello Aditya Upadhyay,
What is your goal for working on / contributing to RTEMS?
POSIX Compliance is a reasonably good project to chip away at. Joel
should have a likely list of candidates to investigate.
Update the TCP/IP Stack is basically done. There are however projects
within the networking area to look into.
I'm not sure about the condition variables project. I think there is
still some small amount of work there.
You should be using RTEMS version 4.12 for any new development effort.
Can you confirm that?
Gedare
On Wed, Jan 25, 2017 at 9:07 AM, aditya upadhyay <aadit0402 at gmail.com> wrote:
> Hello Developers,
> I am new in Open Source and willing to contribute.I have seen these projects
> in " Embedded with RTEMS " page like Condition Variables, POSIX
> Compliance,Update the RTEMS TCP/IP Stack.I have build the tool chain for
> SPARC Instruction Simulator (SIS) BSP and modified the Hello World command
> as described in the "GSOC Getting Started" page.Please point me to the
> document for the above projects so that i can start contributing. Please
> tell me the status of these projects and which of the above projects are
> still open and feasible for a beginner according to you.
> Thanks & Regards,
> Aditya Upadhyay
> Master Of Technology,
> Dept. of Computer Science & Engg.,
> Indian Institute of Technology(ISM), Dhanbad
> Email id: aadit4194 at gmail.com
> devel mailing list
> devel at rtems.org
