[PATCH] rtems: Remove rtems_rate_monotonic_postponed_job_count()
Wed Jan 25 17:51:11 UTC 2017
Include in the commit message either
Updates #2885.
or
Closes #2885.
Depending on what impact the commit has on the ticke.t
On Wed, Jan 25, 2017 at 11:56 AM, Kuan Hsun Chen <c0066c at gmail.com> wrote:
> This is the patch for #2885 ticket.
> 2017-01-25 16:18 GMT+01:00 Kuan-Hsun Chen <c0066c at gmail.com>:
>> Add a variable named "count" in rtems_rate_monotonic_period_status
>> structure
>> Revise rtems_rate_monotonic_get_status() for the postponed job count.
>> sptests/sp69: Revise
>> Add in the verification of the postponed job count for
>> rtems_rate_monotonic_get_status().
>>  cpukit/rtems/include/rtems/rtems/ratemon.h | 24 ++++--------------------
>>  cpukit/rtems/src/ratemongetstatus.c        |  2 ++
>>  cpukit/rtems/src/ratemonperiod.c           | 16 +---------------
>>  testsuites/sptests/sp69/init.c             |  8 ++++++++
>>  testsuites/sptests/sp69/sp69.doc           |  2 ++
>>  testsuites/sptests/sp69/sp69.scn           |  5 +++--
>>  6 files changed, 20 insertions(+), 37 deletions(-)
>> diff --git a/cpukit/rtems/include/rtems/rtems/ratemon.h
>> b/cpukit/rtems/include/rtems/rtems/ratemon.h
>> index 54ddd05..5616ee9 100644
>> --- a/cpukit/rtems/include/rtems/rtems/ratemon.h
>> +++ b/cpukit/rtems/include/rtems/rtems/ratemon.h
>> @@ -23,7 +23,7 @@
>>  /* COPYRIGHT (c) 1989-2009, 2016.
>>   * On-Line Applications Research Corporation (OAR).
>> - * COPYRIGHT (c) 2016 Kuan-Hsun Chen.
>> + * COPYRIGHT (c) 2016-2017 Kuan-Hsun Chen.
>>   * The license and distribution terms for this file may be
>>   * found in the file LICENSE in this distribution or at
>> @@ -182,6 +182,9 @@ typedef struct {
>>     *  then this field has no meaning.
>>    rtems_thread_cpu_usage_t             executed_since_last_period;
>> +  /** This is the count of postponed jobs of this period. */
>> +  uint32_t                             postponed_jobs_count;
>>  }  rtems_rate_monotonic_period_status;
>> @@ -417,25 +420,6 @@ rtems_status_code rtems_rate_monotonic_period(
>>    rtems_interval  length
>> - * @brief Return the number of postponed jobs
>> - * This is a helper function for runtime monitoring to return
>> - * the number of postponed jobs in this given period. This number
>> - * is only increased by the corresponding watchdog,
>> - * and is decreased by RMS manager with the postponed job releasing.
>> - * @param[in] id is the period id
>> - * @retval This helper function returns the number of postponed
>> - * jobs with a given period_id.
>> -uint32_t rtems_rate_monotonic_postponed_job_count(
>> -  rtems_id        period_id
>>  #ifdef __cplusplus
>> diff --git a/cpukit/rtems/src/ratemongetstatus.c
>> b/cpukit/rtems/src/ratemongetstatus.c
>> index 403c6ed..4e6b964 100644
>> --- a/cpukit/rtems/src/ratemongetstatus.c
>> +++ b/cpukit/rtems/src/ratemongetstatus.c
>> @@ -9,6 +9,7 @@
>>   *  COPYRIGHT (c) 1989-2009.
>>   *  Copyright (c) 2016 embedded brains GmbH.
>> + *  Copyright (c) 2017 Kuan-Hsun Chen.
>> @@ -43,6 +44,7 @@ rtems_status_code rtems_rate_monotonic_get_status(
>>    period_status->owner = the_period->owner->Object.id;
>>    period_status->state = the_period->state;
>> +  period_status->postponed_jobs_count = the_period->postponed_jobs;
>>    if ( the_period->state == RATE_MONOTONIC_INACTIVE ) {
>> diff --git a/cpukit/rtems/src/ratemonperiod.c
>> b/cpukit/rtems/src/ratemonperiod.c
>> index 97547e2..5b5d1dc 100644
>> --- a/cpukit/rtems/src/ratemonperiod.c
>> +++ b/cpukit/rtems/src/ratemonperiod.c
>> @@ -9,7 +9,7 @@
>>   *  COPYRIGHT (c) 1989-2010.
>> @@ -302,20 +302,6 @@ static rtems_status_code
>> _Rate_monotonic_Block_while_expired(
>>    return RTEMS_TIMEOUT;
>> -uint32_t rtems_rate_monotonic_postponed_job_count( rtems_id period_id )
>> -  Rate_monotonic_Control *the_period;
>> -  ISR_lock_Context        lock_context;
>> -  uint32_t                jobs;
>> -  the_period = _Rate_monotonic_Get( period_id, &lock_context );
>> -  _Assert( the_period != NULL );
>> -  jobs = the_period->postponed_jobs;
>> -  _Rate_monotonic_Release( the_period, &lock_context );
>> -  return jobs;
>>    rtems_id       id,
>> diff --git a/testsuites/sptests/sp69/init.c
>> b/testsuites/sptests/sp69/init.c
>> index ac6f58c..c38beb8 100644
>> --- a/testsuites/sptests/sp69/init.c
>> +++ b/testsuites/sptests/sp69/init.c
>> @@ -162,6 +162,14 @@ rtems_task Init(
>>      rtems_test_assert( statistics.missed_count == i );
>> +  /* Check the status */
>> +  status = rtems_rate_monotonic_get_status( period_id, &period_status );
>> +  directive_failed( status, "rate_monotonic_get_status" );
>> +  puts(
>> +    "rtems_rate_monotonic_get_status - verify value of a postponed jobs
>> count"
>> +  rtems_test_assert( period_status.postponed_jobs_count == 3 );
>>    TEST_END();
>> diff --git a/testsuites/sptests/sp69/sp69.doc
>> b/testsuites/sptests/sp69/sp69.doc
>> index fbf0e4e..60aacb8 100644
>> --- a/testsuites/sptests/sp69/sp69.doc
>> +++ b/testsuites/sptests/sp69/sp69.doc
>> @@ -1,5 +1,6 @@
>>  #  COPYRIGHT (c) 1989-2009.
>>  #  On-Line Applications Research Corporation (OAR).
>> +#  COPYRIGHT (c) 2017 Kuan-Hsun Chen.
>>  #  The license and distribution terms for this file may be
>>  #  found in the file LICENSE in this distribution or at
>> @@ -21,3 +22,4 @@ concepts:
>>    a period is initiated.
>>  + Verify the correctness of the status values returned on an active
>> period.
>>  + Ensure the missed period count is properly maintained.
>> ++ Verify the correctness of the postponed job count.
>> diff --git a/testsuites/sptests/sp69/sp69.scn
>> b/testsuites/sptests/sp69/sp69.scn
>> index 654eea0..e102d22 100644
>> --- a/testsuites/sptests/sp69/sp69.scn
>> +++ b/testsuites/sptests/sp69/sp69.scn
>> @@ -2,8 +2,9 @@
>>  rtems_rate_monotonic_get_status - verify values of an inactive period
>>  rtems_rate_monotonic_get_status - check RTEMS_NOT_DEFINED
>>  rtems_rate_monotonic_get_status - verify values of an active period
>> -wall time should be ~600000000 is 609216000
>> -cpu time should be ~100000000 is 109217000
>> +wall time should be ~600000000 is 609402399
>> +cpu time should be ~100000000 is 109612659
>>  rtems_rate_monotonic_cancel -  OK
>>  Testing statistics on missed periods
>> +rtems_rate_monotonic_get_status - verify value of a postponed jobs count
>>  *** END OF TEST 69 ***
>> 1.9.1
> devel mailing list
> devel at rtems.org
