[PATCH] score: Delete _CPU_Context_Fp_start()
Thu Jan 26 06:32:38 UTC 2017
On 25/01/17 17:24, Joel Sherrill wrote:
> I had another thought that we need to be sure that the
> reason for adjusting the starting FP context pointer
> to not be the base address of the FP context area
> should be clear.
> For architectures where you are just linearly saving the FPU
> registers, it is just a normal structure.
> For architectures like the m68k where the FPU state is saved
> as a stack which grows down, the adjustment should have
> a comment to explain it. Even if it is done inline in the
> context initialization.
Thanks for the review. I added a comment for m68k:
      * The floating-point context is saved/restored via FSAVE/FRESTORE
which
      * use a growing down stack.  Initialize the stack and adjust the
FP area
      * pointer accordingly.
     #define _CPU_Context_Initialize_fp( _fp_area ) \
          uint32_t *_fp_context = _Addresses_Add_offset( \
            *(_fp_area), CPU_CONTEXT_FP_SIZE - 4); \
          *(--(_fp_context)) = 0; \
          *(_fp_area) = (void *)(_fp_context); \
It is the only architecture supported by RTEMS that uses this model.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
