[PATCH] rtems: Fix _Rate_monotonic_Renew_deadline()
Thu Jan 26 17:59:57 UTC 2017
send -v2 without the acinclude.
On Thu, Jan 26, 2017 at 12:00 PM, Kuan Hsun Chen <c0066c at gmail.com> wrote:
> I accidentally add c/src/lib/libbsp/powerpc/acinclude.m4 into the comment.
> Now ticket 2885 should be close. The previous patch has a typo in the
> comment I hotfix in this patch.
> 2017-01-26 18:02 GMT+01:00 Kuan-Hsun Chen <c0066c at gmail.com>:
>> Prepare a precondition to prevent the potential integer overflow.
>> Remove one redundant parameter in _Rate_monotonic_Renew_deadline().
>> sptests/sp78: Create
>> A test case for checking the overflow condition of postponed_jobs
>> in rtems_rate_monotonic_period_status.
>> Close #2885.
>>  c/src/lib/libbsp/powerpc/acinclude.m4 |   4 +-
>>  cpukit/rtems/src/ratemontimeout.c     |  11 ++--
>>  testsuites/sptests/Makefile.am        |   2 +-
>>  testsuites/sptests/configure.ac       |   1 +
>>  testsuites/sptests/sp78/Makefile.am   |  22 +++++++
>>  testsuites/sptests/sp78/init.c        | 120
>>  testsuites/sptests/sp78/sp78.doc      |  18 +++++
>>  testsuites/sptests/sp78/sp78.scn      |   9 +++
>>  8 files changed, 180 insertions(+), 7 deletions(-)
>>  create mode 100644 testsuites/sptests/sp78/Makefile.am
>>  create mode 100644 testsuites/sptests/sp78/init.c
>>  create mode 100644 testsuites/sptests/sp78/sp78.doc
>>  create mode 100644 testsuites/sptests/sp78/sp78.scn
>> diff --git a/c/src/lib/libbsp/powerpc/acinclude.m4
>> b/c/src/lib/libbsp/powerpc/acinclude.m4
>> index 4c83475..edc67b5 100644
>> --- a/c/src/lib/libbsp/powerpc/acinclude.m4
>> +++ b/c/src/lib/libbsp/powerpc/acinclude.m4
>> @@ -32,12 +32,12 @@ AC_DEFUN([RTEMS_CHECK_BSPDIR],
>>      AC_CONFIG_SUBDIRS([t32mppc]);;
>>    tqm8xx )
>>      AC_CONFIG_SUBDIRS([tqm8xx]);;
>> -  virtex )
>> -    AC_CONFIG_SUBDIRS([virtex]);;
>>    virtex4 )
>>      AC_CONFIG_SUBDIRS([virtex4]);;
>>    virtex5 )
>>      AC_CONFIG_SUBDIRS([virtex5]);;
>> +  virtex )
>> +    AC_CONFIG_SUBDIRS([virtex]);;
>>      AC_MSG_ERROR([Invalid BSP]);;
>>    esac
>> diff --git a/cpukit/rtems/src/ratemontimeout.c
>> b/cpukit/rtems/src/ratemontimeout.c
>> index bcc4ccf..5a838fd 100644
>> --- a/cpukit/rtems/src/ratemontimeout.c
>> +++ b/cpukit/rtems/src/ratemontimeout.c
>> @@ -9,7 +9,7 @@
>>   *  COPYRIGHT (c) 1989-2009.
>>   *  On-Line Applications Research Corporation (OAR).
>> - *  COPYRIGHT (c) 2016 Kuan-Hsun Chen.
>> + *  COPYRIGHT (c) 2016-2017 Kuan-Hsun Chen.
>>   *  The license and distribution terms for this file may be
>>   *  found in the file LICENSE in this distribution or at
>> @@ -24,13 +24,16 @@
>>  static void _Rate_monotonic_Renew_deadline(
>>    Rate_monotonic_Control *the_period,
>> -  Thread_Control         *owner,
>>    ISR_lock_Context       *lock_context
>>    uint64_t deadline;
>> -  ++the_period->postponed_jobs;
>> +  /* stay at 0xffffffff if postponed_jobs is going to overflow */
>> +  if ( the_period->postponed_jobs != UINT32_MAX ) {
>> +    ++the_period->postponed_jobs;
>>    the_period->state = RATE_MONOTONIC_EXPIRED;
>>    deadline = _Watchdog_Per_CPU_insert_relative(
>> @@ -85,6 +88,6 @@ void _Rate_monotonic_Timeout( Watchdog_Control
>> *the_watchdog )
>>        _Thread_Unblock( owner );
>>    } else {
>> -    _Rate_monotonic_Renew_deadline( the_period, owner, &lock_context );
>> +    _Rate_monotonic_Renew_deadline( the_period, &lock_context );
>> diff --git a/testsuites/sptests/Makefile.am
>> b/testsuites/sptests/Makefile.am
>> index 5ef87a0..11e9bcd 100644
>> --- a/testsuites/sptests/Makefile.am
>> +++ b/testsuites/sptests/Makefile.am
>> @@ -10,7 +10,7 @@ _SUBDIRS = \
>>      sp40 sp41 sp42 sp43 sp44 sp45 sp46 sp47 sp48 sp49 \
>>      sp50 sp51 sp52 sp53 sp54 sp55 sp56 sp57 sp58 sp59 \
>>      sp60      sp62 sp63 sp64 sp65 sp66 sp67 sp68 sp69 \
>> -    sp70 sp71 sp72 sp73 sp74 sp75 sp76 sp77 sp2038 \
>> +    sp70 sp71 sp72 sp73 sp74 sp75 sp76 sp77 sp78 sp2038 \
>>      spassoc01 spchain spcoverage spobjgetnext \
>>      spprintk spprivenv01 sprbtree01 spsize spstkalloc \
>>      spstkalloc02 spthreadq01 spwatchdog spwkspace \
>> diff --git a/testsuites/sptests/configure.ac
>> b/testsuites/sptests/configure.ac
>> index 77ec512..a2af200 100644
>> --- a/testsuites/sptests/configure.ac
>> +++ b/testsuites/sptests/configure.ac
>> @@ -144,6 +144,7 @@ sp74/Makefile
>>  sp75/Makefile
>>  sp76/Makefile
>>  sp77/Makefile
>> +sp78/Makefile
>>  sp2038/Makefile
>>  spassoc01/Makefile
>>  spcbssched01/Makefile
>> diff --git a/testsuites/sptests/sp78/Makefile.am
>> b/testsuites/sptests/sp78/Makefile.am
>> new file mode 100644
>> index 0000000..3e59f3d
>> --- /dev/null
>> +++ b/testsuites/sptests/sp78/Makefile.am
>> @@ -0,0 +1,22 @@
>> +rtems_tests_PROGRAMS = sp78
>> +sp78_SOURCES = init.c ../../support/src/spin.c
>> +dist_rtems_tests_DATA = sp78.scn
>> +dist_rtems_tests_DATA += sp78.doc
>> +include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
>> +include $(top_srcdir)/../automake/compile.am
>> +include $(top_srcdir)/../automake/leaf.am
>> +AM_CPPFLAGS += -I$(top_srcdir)/../support/include
>> +LINK_OBJS = $(sp78_OBJECTS)
>> +LINK_LIBS = $(sp78_LDLIBS)
>> +sp78$(EXEEXT): $(sp78_OBJECTS) $(sp78_DEPENDENCIES)
>> +       @rm -f sp69$(EXEEXT)
>> +       $(make-exe)
>> +include $(top_srcdir)/../automake/local.am
>> diff --git a/testsuites/sptests/sp78/init.c
>> b/testsuites/sptests/sp78/init.c
>> index 0000000..99eec27
>> --- /dev/null
>> +++ b/testsuites/sptests/sp78/init.c
>> @@ -0,0 +1,120 @@
>> + *  COPYRIGHT (c) 2017 Kuan-Hsun Chen.
>> + *  The license and distribution terms for this file may be
>> + *  found in the file LICENSE in this distribution or at
>> + *  http://www.rtems.org/license/LICENSE.
>> +#ifdef HAVE_CONFIG_H
>> +#include "config.h"
>> +#endif
>> +#include <rtems/cpuuse.h>
>> +#include <tmacros.h>
>> +#include <rtems/rtems/ratemonimpl.h>
>> +#include "test_support.h"
>> +const char rtems_test_name[] = "SP 78";
>> +/* forward declarations to avoid warnings */
>> +rtems_task Init( rtems_task_argument argument );
>> +static void modify_count( rtems_id id );
>> +  rtems_id            id
>> +  Rate_monotonic_Control                  *the_period;
>> +  ISR_lock_Context                        lock_context;
>> +  the_period = _Rate_monotonic_Get( id, &lock_context );
>> +  _Rate_monotonic_Acquire_critical( the_period, &lock_context );
>> +  the_period->postponed_jobs = UINT32_MAX;
>> +  _Rate_monotonic_Release( the_period, &lock_context );
>> +rtems_task Init(
>> +  rtems_task_argument argument
>> +  rtems_id                                period_id;
>> +  rtems_name                              period_name;
>> +  rtems_rate_monotonic_period_status      period_status;
>> +  rtems_status_code                       status;
>> +  int                                     i;
>> +  period_name = rtems_build_name('P','E','R','1');
>> +  TEST_BEGIN();
>> +  /* create period */
>> +  status = rtems_rate_monotonic_create(
>> +      period_name,
>> +      &period_id
>> +  directive_failed( status, "rate_monotonic_create" );
>> +  /* modify the count to UINT32_MAX and attempt to miss deadline*/
>> +  puts( "Testing overflow condition" );
>> +  rtems_test_spin_until_next_tick();
>> +  status = rtems_rate_monotonic_period( period_id, 50 );
>> +  directive_failed( status, "rate_monotonic_period above loop" );
>> +  puts( "Modify the count of postponed_job manually" );
>> +  modify_count( period_id );
>> +  /* Check the status */
>> +  status = rtems_rate_monotonic_get_status( period_id, &period_status );
>> +  directive_failed( status, "rate_monotonic_get_status" );
>> +  printf( "Init Postponed jobs = %"PRIu32", and expected %"PRIu32"\n",
>> period_status.postponed_jobs_count, UINT32_MAX );
>> +  rtems_test_assert( period_status.postponed_jobs_count == UINT32_MAX );
>> +  for ( i=1 ; i <= 2 ; i++ ) {
>> +    status = rtems_task_wake_after( 100 );
>> +    directive_failed( status, "rtems_task_wake_after(100)" );
>> +    puts( "Task misses its deadline." );
>> +    /* print out the count which should keep in UINT32_MAX, since the
>> period still misses its deadline */
>> +    printf( "Count = %"PRIu32", and expected %"PRIu32"\n",
>> period_status.postponed_jobs_count, UINT32_MAX);
>> +    rtems_test_assert( period_status.postponed_jobs_count == UINT32_MAX);
>> +    fatal_directive_status(
>> +      status,
>> +      RTEMS_TIMEOUT,
>> +      "rtems_rate_monotonic_period 2-n"
>> +  TEST_END();
>> +  rtems_test_exit(0);
>> +/* configuration information */
>> +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>> +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>> +#define CONFIGURE_MILLISECONDS_PER_TICK 1
>> +#define CONFIGURE_MAXIMUM_TASKS             1
>> +#define CONFIGURE_MAXIMUM_PERIODS           1
>> +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
>> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>> +#include <rtems/confdefs.h>
>> +/* end of file */
>> diff --git a/testsuites/sptests/sp78/sp78.doc
>> b/testsuites/sptests/sp78/sp78.doc
>> index 0000000..ad64e4b
>> --- /dev/null
>> +++ b/testsuites/sptests/sp78/sp78.doc
>> @@ -0,0 +1,18 @@
>> +#  COPYRIGHT (c) 2017 Kuan-Hsun Chen.
>> +#  The license and distribution terms for this file may be
>> +#  found in the file LICENSE in this distribution or at
>> +#  http://www.rtems.org/license/LICENSE.
>> +This file describes the directives and concepts tested by this test set.
>> +test set name:  sp78
>> +directives:
>> +  rtems_rate_monotonic_get_status
>> +concepts:
>> ++ Test the overflow condition for postponed_jobs.
>> diff --git a/testsuites/sptests/sp78/sp78.scn
>> b/testsuites/sptests/sp78/sp78.scn
>> index 0000000..4cb71db
>> --- /dev/null
>> +++ b/testsuites/sptests/sp78/sp78.scn
>> @@ -0,0 +1,9 @@
>> +*** BEGIN OF TEST SP 78 ***
>> +Testing overflow condition
>> +Modify the count of postponed_job manually
>> +Init Postponed jobs = 4294967295, and expected 4294967295
>> +Task misses its deadline.
>> +Count = 4294967295, and expected 4294967295
>> +*** END OF TEST SP 78 ***
>> 1.9.1
> devel mailing list
> devel at rtems.org
