[PATCH 09/10] Add nexus device entries
Kevin Kirspel kevin-kirspel at idexx.com
Mon Jan 30 16:58:23 UTC 2017
 rtemsbsd/include/bsp/nexus-devices.h           | 12 +++++
 rtemsbsd/include/machine/rtems-bsd-nexus-bus.h | 75 ++++++++++++++++++++++++++
 2 files changed, 87 insertions(+)
 mode change 100644 => 100755 rtemsbsd/include/bsp/nexus-devices.h
 mode change 100644 => 100755 rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
diff --git a/rtemsbsd/include/bsp/nexus-devices.h b/rtemsbsd/include/bsp/nexus-devices.h
old mode 100644
new mode 100755
index 0b4ec62..b681434
--- a/rtemsbsd/include/bsp/nexus-devices.h
+++ b/rtemsbsd/include/bsp/nexus-devices.h
@@ -46,6 +46,18 @@
 RTEMS_BSD_DRIVER_SMC0(0x4e000000,  RVPBXA9_IRQ_ETHERNET);
+#elif defined(LIBBSP_ARM_LPC32XX_BSP_H)
+#include <bsp/irq.h>
+RTEMS_BSD_DRIVER_LPC32XX_PWR;
+RTEMS_BSD_DRIVER_LPC32XX_LPE;
+RTEMS_BSD_DRIVER_ICSPHY;
+RTEMS_BSD_DRIVER_LPC32XX_OHCI;
+SYSINIT_DRIVER_REFERENCE(usbus, ohci);
+RTEMS_BSD_DRIVER_USB;
+RTEMS_BSD_DRIVER_USB_MASS;
 #elif defined(LIBBSP_M68K_GENMCF548X_BSP_H)
 RTEMS_BSD_DRIVER_FEC;
diff --git a/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h b/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
old mode 100644
new mode 100755
index a408c17..299221c
--- a/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
+++ b/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
@@ -38,6 +38,7 @@
  *  Devices:
  *   RTEMS_BSD_DRIVER_XILINX_ZYNQ_SLCR
+ *   RTEMS_BSD_DRIVER_LPC32XX_PWR
  *  Buses:
  *   RTEMS_BSD_DRIVER_PC_LEGACY
@@ -46,6 +47,7 @@
  *   RTEMS_BSD_DRIVER_DWCOTG0
  *   RTEMS_BSD_DRIVER_DWCOTG0_BASE_ADDR
  *    RTEMS_BSD_DRIVER_DWCOTG0_IRQ
+ *   RTEMS_BSD_DRIVER_LPC32XX_OHCI
  *   RTEMS_BSD_DRIVER_DWC_MMC
  *   RTEMS_BSD_DRIVER_MMC
  *   RTEMS_BSD_DRIVER_USB
@@ -55,6 +57,7 @@
  *   RTEMS_BSD_DRIVER_SMC0
  *    RTEMS_BSD_DRIVER_SMC0_BASE_ADDR
  *    RTEMS_BSD_DRIVER_SMC0_IRQ
+ *   RTEMS_BSD_DRIVER_LPC32XX_LPE
  *   RTEMS_BSD_DRIVER_FEC
  *   RTEMS_BSD_DRIVER_XILINX_ZYNQ_CGEM0
  *    RTEMS_BSD_DRIVER_CGEM0_IRQ
@@ -73,6 +76,7 @@
  *  MMI PHY:
  *   RTEMS_BSD_DRIVER_E1000PHY
+ *   RTEMS_BSD_DRIVER_ICSPHY
  *   RTEMS_BSD_DRIVER_REPHY
  *   RTEMS_BSD_DRIVER_MIPHY
@@ -115,6 +119,23 @@ extern "C" {
                                   &zy7_slcr_res[0])
 #endif /* RTEMS_BSD_DRIVER_XILINX_ZYNQ_SLCR */
+ * LPC32XX Power Control (PWR).
+#if !defined(RTEMS_BSD_DRIVER_LPC32XX_PWR)
+  #define RTEMS_BSD_DRIVER_LPC32XX_PWR                                        \
+    static const rtems_bsd_device_resource lpc_pwr0_res[] = {                 \
+        .type = RTEMS_BSD_RES_MEMORY,                                         \
+        .start_request = 0,                                                   \
+        .start_actual = LPC32XX_BASE_SYSCON                                   \
+    RTEMS_BSD_DEFINE_NEXUS_DEVICE_ORDERED(pwr, 0, RTEMS_SYSINIT_ORDER_FIRST,  \
+                                  RTEMS_ARRAY_SIZE(lpc_pwr0_res),             \
+                                  &lpc_pwr0_res[0])
+#endif /* RTEMS_BSD_DRIVER_LPC32XX_PWR */
  ** Physical Buses
@@ -155,6 +176,31 @@ extern "C" {
 #endif /* RTEMS_BSD_DRIVER_DWCOTG0 */
+ * LPC32XX OHCI.
+#if !defined(RTEMS_BSD_DRIVER_LPC32XX_OHCI)
+  #define RTEMS_BSD_DRIVER_LPC32XX_OHCI                                     \
+    static const rtems_bsd_device_resource lpc_ohci0_res[] = {              \
+        .start_actual = LPC32XX_BASE_USB                                    \
+        .start_actual = (unsigned long)(&LPC32XX_I2C_RX)                    \
+        .type = RTEMS_BSD_RES_IRQ,                                          \
+        .start_actual = LPC32XX_IRQ_USB_HOST                                \
+    RTEMS_BSD_DEFINE_NEXUS_DEVICE(ohci, 0,                                  \
+                                  RTEMS_ARRAY_SIZE(lpc_ohci0_res),          \
+                                  &lpc_ohci0_res[0])
+#endif /* RTEMS_BSD_DRIVER_LPC32XX_OHCI */
  * Designware/Synopsys MMC.
 #if !defined(RTEMS_BSD_DRIVER_DWC_MMC)
@@ -214,6 +260,27 @@ extern "C" {
 #endif /* RTEMS_BSD_DRIVER_SMC */
+ * LPC32XX LPE driver
+#if !defined(RTEMS_BSD_DRIVER_LPC32XX_LPE)
+  #define RTEMS_BSD_DRIVER_LPC32XX_LPE                           \
+    static const rtems_bsd_device_resource lpc_lpe0_res[] = {    \
+        .start_actual = LPC32XX_BASE_ETHERNET                    \
+        .start_actual = LPC32XX_IRQ_ETHERNET                     \
+    RTEMS_BSD_DEFINE_NEXUS_DEVICE(lpe, 0,                        \
+                                  RTEMS_ARRAY_SIZE(lpc_lpe0_res),    \
+                                  &lpc_lpe0_res[0])
+#endif /* RTEMS_BSD_DRIVER_LPC32XX_LPE */
  * Coldfire Fast Ethernet Controller (FEC) driver.
 #if !defined(RTEMS_BSD_DRIVER_FEC)
@@ -345,6 +412,14 @@ extern "C" {
 #endif /* RTEMS_BSD_DRIVER_E1000PHY */
+ * ICS PHY
+#if !defined(RTEMS_BSD_DRIVER_ICSPHY)
+  #define RTEMS_BSD_DRIVER_ICSPHY               \
+    SYSINIT_DRIVER_REFERENCE(icsphy, miibus);
+#endif /* RTEMS_BSD_DRIVER_ICSPHY */
  * Reltek PHY
 #if !defined(RTEMS_BSD_DRIVER_REPHY)
1.9.1
