[PATCH] rtems: Revise tests: sprmsched01 and spedfsched04
Mon Jan 30 23:15:00 UTC 2017
Does this fix a deficiency in the current tests?
On Mon, Jan 30, 2017 at 1:34 PM, Kuan-Hsun Chen <c0066c at gmail.com> wrote:
> Instead of using the target time and console driver,
> both tests now use assertions and rtems_rate_monotonic_get_status() to verify the count of postponed jobs.
> The setting of spedfsched04 is slightly changed.
> Update #2795
>  testsuites/sptests/spedfsched04/Makefile.am      |  2 +-
>  testsuites/sptests/spedfsched04/init.c           | 89 ++++++++++++------------
>  testsuites/sptests/spedfsched04/spedfsched04.scn | 27 ++-----
>  testsuites/sptests/sprmsched01/Makefile.am       |  4 +-
>  testsuites/sptests/sprmsched01/init.c            | 74 ++++++++++----------
>  testsuites/sptests/sprmsched01/sprmsched01.scn   | 55 ++-------------
>  6 files changed, 97 insertions(+), 154 deletions(-)
> diff --git a/testsuites/sptests/spedfsched04/Makefile.am b/testsuites/sptests/spedfsched04/Makefile.am
> index 39f8210..a39519a 100644
> --- a/testsuites/sptests/spedfsched04/Makefile.am
> +++ b/testsuites/sptests/spedfsched04/Makefile.am
> @@ -1,6 +1,6 @@
>  rtems_tests_PROGRAMS = spedfsched04
> -spedfsched04_SOURCES = init.c
> +spedfsched04_SOURCES = init.c ../../support/src/spin.c
>  dist_rtems_tests_DATA = spedfsched04.scn
>  dist_rtems_tests_DATA += spedfsched04.doc
> diff --git a/testsuites/sptests/spedfsched04/init.c b/testsuites/sptests/spedfsched04/init.c
> index f80883d..8dd93db 100644
> --- a/testsuites/sptests/spedfsched04/init.c
> +++ b/testsuites/sptests/spedfsched04/init.c
> @@ -1,24 +1,25 @@
> - * @brief A heuristic example to demonstrate how the postponed jobs are handled.
> + * @brief A heuristic example to demonstrate how the postponed jobs are handled in EDF.
>   * Given two tasks with implicit deadline under EDF policy.
> - * Task 1 has (4, 5) and task 2 has (4, 6), where (execution time, period/deadline).
> - * For the simplicity, we only execute the first task twice.
> + * Task 1 has (400, 500) and task 2 has (450, 550), where (required ticks, period/deadline).
> + * For the simplicity, we only execute the first task three times.
>   * In the original implementation in v4.11, no matter how many periods are
>   * expired, only one job will be released with a shifted deadline assignment.
> - * In this example, the first job of task 2 will be blocked by the second job
> - * of task 1, so that there at least one following job is postponed.
> - * Due to overhead/delay, the second following job will be postponed as well.
> + * In this example, task 2 will be blocked by the second and third jobs
> + * of task 1, so that there are two jobs are postponed.
> + * Due to the domino effects, the following jobs of task 2 will be postponed until Job 9.
>   * If the overrun handling is correct, the period of task 2 changes back to
> - * normal status at time 22.
> - * Otherwise, the release time of job 3 is no longer periodic.
> + * normal status at Job 9.
> + * Otherwise, the release time of job 3 is no longer periodic
> + * and there is no more postponed jobs.
> - *  COPYRIGHT (c) 2016 Kuan-Hsun Chen.
> + *  COPYRIGHT (c) 2016-2017 Kuan-Hsun Chen.
>   *  The license and distribution terms for this file may be
>   *  found in the file LICENSE in this distribution or at
> @@ -30,23 +31,19 @@
>  #endif
>  #include <rtems/cpuuse.h>
> -#include <rtems/counter.h>
> -#include <stdio.h>
> -#include <inttypes.h>
> -#include "tmacros.h"
> +#include <tmacros.h>
> +#include "test_support.h"
>  const char rtems_test_name[] = "SPEDFSCHED 4";
> -static const uint32_t Periods[] = { 5000, 6000 };
> -static const uint32_t Iterations[] = { 4000, 4000 };
> +static const uint32_t Periods[] = { 500, 550 };
> +static const uint32_t Iterations[] = { 400, 450 };
>  static const rtems_name Task_name[] = {
>    rtems_build_name( 'T', 'A', '1', ' ' ),
>    rtems_build_name( 'T', 'A', '2', ' ' )
>  static const rtems_task_priority Prio[3] = { 2, 5 };
> -static const uint32_t testnumber = 11; /* stop condition */
> +static const uint32_t testnumber = 9; /* stop condition */
>  static uint32_t tsk_counter[] = { 0, 0 };
>  static rtems_id   Task_id[ 2 ];
> @@ -58,35 +55,42 @@ static rtems_task Task(
>    rtems_task_argument argument
> -  rtems_status_code status;
> -  rtems_id    RM_period;
> -  rtems_id    selfid=rtems_task_self();
> -  uint32_t    start, end, flag=0, index;
> -  rtems_counter_ticks t0;
> +  rtems_status_code                         status;
> +  rtems_id                                  RM_period;
> +  rtems_id                                  selfid=rtems_task_self();
> +  rtems_rate_monotonic_period_status        period_status;
> +  uint32_t                                  flag=0;
> -  t0 = rtems_counter_nanoseconds_to_ticks( 1000000 ); //1ms ticks counter
> -  /*create period*/
> +  /* create period */
>    status = rtems_rate_monotonic_create( Task_name[ argument ], &RM_period );
>    directive_failed( status, "rtems_rate_monotonic_create" );
>    while ( FOREVER ) {
>      status = rtems_rate_monotonic_period( RM_period, Periods[ argument ] );
> -    if( flag == 0 && status == RTEMS_TIMEOUT ){
> -      flag = 1;
> -      printf( "RTEMS_TIMEOUT\n" );
> -    } else if ( flag == 1 && status == RTEMS_SUCCESSFUL ) {
> -      flag = 0;
> -      printf( "RTEMS_SUCCESSFUL\n" );
> -    start = rtems_clock_get_ticks_since_boot();
> -    printf( "Job %" PRIu32 " Task %" PRIuPTR " starts at tick %" PRIu32 ".\n", tsk_counter[ argument ]+1, argument, start );
> -    for( index = 0; index < Iterations[ argument ]; index++ ){
> -      rtems_counter_delay_ticks( t0 );
> -    end = rtems_clock_get_ticks_since_boot();
> -    printf( "                                  Job %" PRIu32" Task %" PRIuPTR " ends at tick %" PRIu32".\n", tsk_counter[ argument ]+1, argument, end );
> +    /* Do some work */
> +    rtems_test_spin_for_ticks( Iterations[ argument ] );
>      if( argument == 1 ){
> +      if( status == RTEMS_TIMEOUT ){
> +        if( flag == 0 ){
> +          puts( "First time RTEMS_TIMEOUT" );
> +          puts( "Task 2 should have 2 postponed job due to preemption." );
> +          rtems_test_assert( period_status.postponed_jobs_count == 2 );
> +          flag = 1;
> +      } else if ( flag == 1 && status == RTEMS_SUCCESSFUL ) {
> +        puts( "RTEMS_SUCCESSFUL" );
> +        puts( "Overrun handling is finished, now Task 2 becomes normal." );
> +        rtems_test_assert( period_status.postponed_jobs_count == 0 );
> +        flag = 0;
> +      /* Check the status */
> +      status = rtems_rate_monotonic_get_status( RM_period, &period_status );
> +      directive_failed( status, "rate_monotonic_get_status" );
> +      //printf( "Count = %"PRIu32"\n", period_status.postponed_jobs_count);
>        if( tsk_counter[ argument ] == testnumber ){
>          TEST_END();
>          status = rtems_rate_monotonic_delete( RM_period );
> @@ -97,7 +101,8 @@ static rtems_task Task(
>      tsk_counter[ argument ]+=1;
>      if ( argument == 0 ){
> -      if( tsk_counter[ argument ] == 2 ){
> +      if( tsk_counter[ argument ] == 3 ){
> +        puts("Task 1 has released 3 jobs and finished.");
>          directive_failed( status, "rtems_rate_monotonic_delete" );
>          status = rtems_task_delete( selfid );
> @@ -116,7 +121,6 @@ static rtems_task Init(
>    TEST_BEGIN();
> -  printf( "\nTicks per second in your system: %" PRIu32 "\n", rtems_clock_get_ticks_per_second() );
>    /* Create two tasks */
>    for ( index = 0; index < RTEMS_ARRAY_SIZE(Task_name); ++index ){
> @@ -127,7 +131,6 @@ static rtems_task Init(
>      directive_failed( status, "rtems_task_create loop" );
>    /* After creating the periods for tasks, start to run them sequencially. */
>      status = rtems_task_start( Task_id[ index ], Task, index);
> @@ -139,7 +142,7 @@ static rtems_task Init(
>  #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>  #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> -#define CONFIGURE_MICROSECONDS_PER_TICK     1000
> +#define CONFIGURE_MICROSECONDS_PER_TICK     100
>  #define CONFIGURE_MAXIMUM_TASKS             3
>  #define CONFIGURE_MAXIMUM_PERIODS           2
> diff --git a/testsuites/sptests/spedfsched04/spedfsched04.scn b/testsuites/sptests/spedfsched04/spedfsched04.scn
> index 6d8060be..f1c41c4 100644
> --- a/testsuites/sptests/spedfsched04/spedfsched04.scn
> +++ b/testsuites/sptests/spedfsched04/spedfsched04.scn
> @@ -1,24 +1,7 @@
>  *** BEGIN OF TEST SPEDFSCHED 4 ***
> -Ticks per second in your system: 1000
> -Job 1 Task 1 starts at tick 14.
> -                                        Job 1 Task 1 ends at tick 4023.
> -Job 1 Task 2 starts at tick 4025.
> -Job 2 Task 1 starts at tick 5013.
> -                                        Job 2 Task 1 ends at tick 9023.
> -                                        Job 1 Task 2 ends at tick 12045.
> -System TIMEOUT
> -Job 2 Task 2 starts at tick 12045.
> -                                        Job 2 Task 2 ends at tick 16054.
> -Job 3 Task 2 starts at tick 16054.
> -                                        Job 3 Task 2 ends at tick 20061.
> -System SUCCESSFUL
> -Job 4 Task 2 starts at tick 22025.
> -                                        Job 4 Task 2 ends at tick 26033.
> -Job 5 Task 2 starts at tick 28025.
> -                                        Job 5 Task 2 ends at tick 32033.
> -Job 6 Task 2 starts at tick 34025.
> -                                        Job 6 Task 2 ends at tick 38033.
> +Task 1 has released 3 jobs and finished.
> +First time RTEMS_TIMEOUT
> +Task 2 should have 2 postponed job due to preemption.
> +RTEMS_SUCCESSFUL
> +Overrun handling is finished, now Task 2 becomes normal.
>  *** END OF TEST SPEDFSCHED 4 ***
> diff --git a/testsuites/sptests/sprmsched01/Makefile.am b/testsuites/sptests/sprmsched01/Makefile.am
> index 068bb19..a8cf788 100644
> --- a/testsuites/sptests/sprmsched01/Makefile.am
> +++ b/testsuites/sptests/sprmsched01/Makefile.am
> @@ -1,7 +1,7 @@
>  rtems_tests_PROGRAMS = sprmsched01
> -sprmsched01_SOURCES = init.c
> +sprmsched01_SOURCES = init.c ../../support/src/spin.c
>  dist_rtems_tests_DATA = sprmsched01.scn
>  dist_rtems_tests_DATA += sprmsched01.doc
> diff --git a/testsuites/sptests/sprmsched01/init.c b/testsuites/sptests/sprmsched01/init.c
> index 2332920..6bc7ddd 100644
> --- a/testsuites/sptests/sprmsched01/init.c
> +++ b/testsuites/sptests/sprmsched01/init.c
> @@ -1,5 +1,5 @@
> + * @brief A heuristic example to demonstrate how the postponed jobs are handled in RMS.
>   * Given two tasks with implicit deadline under fixed-priority scheudling.
>   * Task 1 has (6, 10) and task 2 has (1, 2), where (execution time, deadline/period).
> @@ -20,7 +20,7 @@
> @@ -32,23 +32,19 @@
>  #endif
> -#include <stdio.h>
>  const char rtems_test_name[] = "SPRMSCHED 1";
> -static const uint32_t Periods[] = { 10000, 2000 };
> -static const uint32_t Iterations[] = { 6000, 1000 };
> +static const uint32_t Periods[] = { 1000, 200 };
> +static const uint32_t Iterations[] = { 600, 100 };
> @@ -60,13 +56,12 @@ static rtems_task Task(
> +  uint32_t                                   flag=0;
>    /*create period*/
> @@ -74,26 +69,30 @@ static rtems_task Task(
>    while ( FOREVER ) {
>      //directive_failed( status, "rtems_rate_monotonic_period" ); let TIMEOUT pass
> -    if( argument == 1 && flag == 0 && status == RTEMS_TIMEOUT ){
> -      flag = 1;
> -      flag = 0;
> -    if ( argument == 1 )
> -    else
> -      printf( "Task %" PRIuPTR " starts at tick %" PRIu32 ".\n", argument, start );
> -      if( tsk_counter[ argument ] == testnumber ){
> +        if( flag == 0 ){
> +          puts( "Task 2 should have 3 postponed jobs due to preemption." );
> +          rtems_test_assert( period_status.postponed_jobs_count == 3 );
> +          flag = 1;
> +        flag = 0;
> +      if( tsk_counter[ argument ] == testnumber ){
>          TEST_END();
> @@ -104,6 +103,7 @@ static rtems_task Task(
> +        puts( "Task 1 has released two jobs" );
> @@ -122,7 +122,7 @@ static rtems_task Init(
>    TEST_BEGIN();
> +  //printf( "\nTicks per second in your system: %" PRIu32 "\n", rtems_clock_get_ticks_per_second() );
> @@ -145,7 +145,7 @@ static rtems_task Init(
> diff --git a/testsuites/sptests/sprmsched01/sprmsched01.scn b/testsuites/sptests/sprmsched01/sprmsched01.scn
> index 9205a59..e01712c 100644
> --- a/testsuites/sptests/sprmsched01/sprmsched01.scn
> +++ b/testsuites/sptests/sprmsched01/sprmsched01.scn
> @@ -1,50 +1,7 @@
> -*** BEGIN OF TEST Rate Monotonic 01 - Overrun Test ***
> -Job 1 Task 1 starts at tick 13.
> -                                        Job 1 Task 1 ends at tick 6021.
> -Job 1 Task 2 starts at tick 6022.
> -                                        Job 1 Task 2 ends at tick 7024.
> -Job 2 Task 2 starts at tick 8022.
> -                                        Job 2 Task 2 ends at tick 9023.
> -Job 2 Task 1 starts at tick 10013.
> -                                        Job 2 Task 1 ends at tick 16021.
> -Job 3 Task 2 starts at tick 16023.
> -                                        Job 3 Task 2 ends at tick 17024.
> -RTEMS_TIMEOUT
> -Job 4 Task 2 starts at tick 17025.
> -                                        Job 4 Task 2 ends at tick 18026.
> -Job 5 Task 2 starts at tick 18026.
> -                                        Job 5 Task 2 ends at tick 19027.
> -Job 6 Task 2 starts at tick 19028.
> -                                        Job 6 Task 2 ends at tick 20029.
> -Job 7 Task 2 starts at tick 20029.
> -                                        Job 7 Task 2 ends at tick 21031.
> -Job 8 Task 2 starts at tick 21031.
> -                                        Job 8 Task 2 ends at tick 22033.
> -Job 9 Task 2 starts at tick 22033.
> -                                        Job 9 Task 2 ends at tick 23035.
> +*** BEGIN OF TEST SPRMSCHED 1 ***
> +Task 1 has released two jobs
> +Task 2 should have 3 postponed jobs due to preemption.
>  RTEMS_SUCCESSFUL
> -Job 10 Task 2 starts at tick 24022.
> -                                        Job 10 Task 2 ends at tick 25023.
> -Job 11 Task 2 starts at tick 26022.
> -                                        Job 11 Task 2 ends at tick 27024.
> -Job 12 Task 2 starts at tick 28022.
> -                                        Job 12 Task 2 ends at tick 29024.
> -Job 13 Task 2 starts at tick 30022.
> -                                        Job 13 Task 2 ends at tick 31023.
> -Job 14 Task 2 starts at tick 32022.
> -                                        Job 14 Task 2 ends at tick 33023.
> -Job 15 Task 2 starts at tick 34022.
> -                                        Job 15 Task 2 ends at tick 35023.
> -Job 16 Task 2 starts at tick 36022.
> -                                        Job 16 Task 2 ends at tick 37023.
> -Period information by period
> ---- CPU times are in seconds ---
> ---- Wall times are in seconds ---
> -   ID     OWNER COUNT MISSED          CPU TIME                  WALL TIME
> -                                    MIN/MAX/AVG                MIN/MAX/AVG
> -0x42010002 TA2     15      6 1.001686/7.012146/2.404131 1.001698/13.013378/5.204723
> -*** END OF TEST Rate Monotonic 01 ***
> +*** END OF TEST SPRMSCHED 1 ***
> 1.9.1
> devel mailing list
> devel at rtems.org
