Desirable Application Stacks (Add-On Library Collections)
Joel Sherrill
joel at rtems.org
Mon Jan 9 22:42:42 UTC 2017
On Sun, Jan 8, 2017 at 7:52 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 09/01/2017 11:02, groups at chichak.ca wrote:
>> I ended up writing my own web page server. It sucks, I wish there was a
>> better way, and I’m certain that it’s going to bite me really soon now.
> The mhttpd server in the legacy and libbsd stack allows for hooks to get
> at data. I have a client with a product that has uploading and downloading,
> web sockets and JSON exported data with JS code to handle the interface.
> The interface is nice to use.
mhttpd is Mongoose. Mongoose moved to GPL with a dual license for
commercial use.
As Christian mentioned, we should move to civitweb which took the last
non-GPL
version of Mongoose and forked.
https://github.com/civetweb/civetweb
I agree that it would be nice if this were an RSB package.
Chris and I saw a presentation on XMPP and IoT. Apparently, xmpp.org has
some standard protocols
defined related to IoT which seem to have some standardization. I don't
know enough to know if
the device side is worth hosting on RTEMS, but it seems promising.
I have also been curious if there is a Linux or Arduino i2c device library
which should be ported to
RTEMS. We have the Linux compatible API so that is an option. I assume that
the Arduino has
a bottom adapter layer we could provide and get their i2c device library to
work.
--joel
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170109/eea662e3/attachment-0002.html>
