[PATCH] configure: Add RTEMS_TOOL_CHAIN_ERROR
Thu Jan 12 13:37:07 UTC 2017
I am OK with this and think it will give a more helpful message.
Did you notice any other grossly out of date, unneeded tests
that generated conditionals for the code?
We have been very nice about not hard forcing people to update
and things like the sys/cpuset.h tests should just be removed now
that your toolset would have to be over a year old.
--joel
On Thu, Jan 12, 2017 at 3:01 AM, Sebastian Huber <
> Stop the build with a common error message in case the tool chain is
> seriously out of date.
>  cpukit/configure.ac | 27 +++++++++++++--------------
>  1 file changed, 13 insertions(+), 14 deletions(-)
> diff --git a/cpukit/configure.ac b/cpukit/configure.ac
> index 4410bf1..4aad929 100644
> --- a/cpukit/configure.ac
> +++ b/cpukit/configure.ac
> @@ -23,6 +23,8 @@ RTEMS_ENABLE_DRVMGR
>  RTEMS_ENV_RTEMSCPU
>  RTEMS_CHECK_RTEMS_DEBUG
> +AC_DEFUN([RTEMS_TOOL_CHAIN_ERROR],AC_MSG_ERROR([please update your tool
> chain via the RSB (https://devel.rtems.org/wiki/Developer/Tools/RSB)]))
>  # Is this a supported CPU?
>  AC_MSG_CHECKING([if cpu $RTEMS_CPU is supported])
>  if test -d "$srcdir/score/cpu/$RTEMS_CPU"; then
> @@ -57,9 +59,7 @@ AC_CHECK_FUNCS([creat \
>    sleep \
>    telldir \
>    usleep],,
> -  [rtems_missing_func="$ac_func";break])
> -AS_IF([test -n "$rtems_missing_func"],
> -  AC_MSG_ERROR([Missing function $rtems_missing_func in libc])])
> +  [RTEMS_TOOL_CHAIN_ERROR])
>  AC_CHECK_FUNCS([__assert])
>  AC_CHECK_FUNCS([execl execlp execle execv execvp execve])
>  AC_CHECK_FUNCS([regcomp regexec regerror regfree])
> @@ -75,10 +75,11 @@ AC_CHECK_DECLS([__env_lock],,,[#include <envlock.h>])
>  AC_CHECK_DECLS([__env_unlock],,,[#include <envlock.h>])
>  AC_CHECK_TYPES([struct _Thread_queue_Queue],[],[],[#include
> <sys/lock.h>])
>  AC_CHECK_SIZEOF([pthread_spinlock_t],[],[],[#include <pthread.h>])
> +AC_CHECK_MEMBER([struct _Thread_queue_Queue._name],[],
> [RTEMS_TOOL_CHAIN_ERROR],[#include <sys/lock.h>])
>  # Mandated by POSIX, older newlibs bogusly provided
> CLOCK_PROCESS_CPUTIME+CLOCK_THREAD_CPUTIME
> -AC_CHECK_DECL([CLOCK_PROCESS_CPUTIME_ID],[],[AC_MSG_ERROR([missing
> define CLOCK_PROCESS_CPUTIME_ID])],[#include <time.h>])
> -AC_CHECK_DECL([CLOCK_THREAD_CPUTIME_ID],[],[AC_MSG_ERROR([missing define
> CLOCK_THREAD_CPUTIME_ID])],[#include <time.h>])
> +AC_CHECK_DECL([CLOCK_PROCESS_CPUTIME_ID],[],[RTEMS_TOOL_CHAIN_ERROR],[#include
> <time.h>])
> +AC_CHECK_DECL([CLOCK_THREAD_CPUTIME_ID],[],[RTEMS_TOOL_CHAIN_ERROR],[#include
> <time.h>])
>  # Mandated by POSIX, decls not present in some versions of newlib,
>  # some versions stubbed in newlib's rtems crt0
> @@ -136,9 +137,7 @@ AC_CHECK_FUNCS([ttyname getcwd])
>  # Check if the installed toolchain provides these headers
>  # and error out if not.
>  AC_CHECK_HEADERS([tar.h errno.h sched.h sys/cdefs.h sys/queue.h],,
> -  [rtems_missing_header="$ac_header";break])
> -AS_IF([test -n "$rtems_missing_header"],
> -  AC_MSG_ERROR([Missing required header $rtems_missing_header])])
>  AC_CHECK_HEADERS([semaphore.h])
>  AM_CONDITIONAL([HAVE_SEMAPHORE_H],[test x"$ac_cv_header_semaphore_h" =
> x"yes"])
> @@ -148,15 +147,15 @@ AM_CONDITIONAL([HAVE_THREADS_H],[test
> x"$ac_cv_header_threads_h" = x"yes"])
>  ## error out if libc doesn't provide stdint.h
>  AS_IF([test x"${ac_cv_header_stdint_h}" != xyes],
> -[AC_MSG_ERROR([Required header stdint.h not found])])
> +[RTEMS_TOOL_CHAIN_ERROR])
>  ## error out if libc doesn't provide inttypes.h
>  AS_IF([test x"${ac_cv_header_inttypes_h}" != xyes],
> -[AC_MSG_ERROR([Required header inttypes.h not found])])
>  AC_HEADER_STDBOOL
>  AS_IF([test x"${ac_cv_header_stdbool_h}" != xyes],
> -[AC_MSG_ERROR([No sufficient stdbool.h found])])
>  AC_CHECK_TYPES([ uint8_t,  int8_t])
>  AC_CHECK_TYPES([uint16_t, int16_t])
> @@ -175,7 +174,7 @@ AC_CHECK_HEADER([pthread.h],[
>    AC_CHECK_TYPES([pthread_rwlock_t])
>    AC_CHECK_TYPES([pthread_barrier_t])
>    AC_CHECK_TYPES([pthread_spinlock_t])
> -  AC_CHECK_TYPES([struct _pthread_cleanup_context],[],[AC_MSG_ERROR([struct
> _pthread_cleanup_context in <pthread.h> is mandatory])],[#include
> <pthread.h>])
> +  AC_CHECK_TYPES([struct _pthread_cleanup_context],[],[
> RTEMS_TOOL_CHAIN_ERROR],[#include <pthread.h>])
>  AC_CHECK_HEADER([signal.h],[
> @@ -183,7 +182,7 @@ AC_CHECK_HEADER([signal.h],[
>  if test x"$RTEMS_USE_NEWLIB" = xyes ; then
> -  AC_CHECK_DECLS([__getreent],[],[AC_MSG_ERROR([__getreent() in
> <sys/reent.h> is mandatory])],[#include <sys/reent.h>])
> +  AC_CHECK_DECLS([__getreent],[],[RTEMS_TOOL_CHAIN_ERROR],[#include
> <sys/reent.h>])
>  fi
>  RTEMS_CHECK_MULTIPROCESSING
> @@ -191,7 +190,7 @@ RTEMS_CHECK_POSIX_API
>  RTEMS_CHECK_NETWORKING
>  RTEMS_CHECK_SMP
>  if test "${RTEMS_HAS_SMP}" = "yes"; then
> -  AC_CHECK_HEADERS([stdatomic.h],[],[AC_MSG_ERROR([<stdatomic.h> is
> required for SMP support])])
> +  AC_CHECK_HEADERS([stdatomic.h],[],[RTEMS_TOOL_CHAIN_ERROR])
>  fi
>  rtems_major=`echo _RTEMS_VERSION | sed "s/\..*//"`
> 1.8.4.5
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170112/45cbbc80/attachment-0002.html>
