[PATCH] configure: Add RTEMS_TOOL_CHAIN_ERROR
Joel Sherrill
joel at rtems.org
Thu Jan 12 21:44:31 UTC 2017
On Thu, Jan 12, 2017 at 3:34 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 13/01/2017 00:37, Joel Sherrill wrote:
>> I am OK with this and think it will give a more helpful message.
> I am OK with the change however I would like the patch to wait until
> docs.rtems.org is up and a permanent link can be used for ....
+1 for permanent URLs for a number of things. :)
I repeat that I would like to purge old tests that result in conditionals in
source code we no longer need. So any HAVE_XXX that are a side
effect of transitioning newlib additions should be removed.
--joel
> +AC_DEFUN([RTEMS_TOOL_CHAIN_ERROR],AC_MSG_ERROR([please update your
>> tool chain via the RSB
>> (https://devel.rtems.org/wiki/Developer/Tools/RSB)]
>> <https://devel.rtems.org/wiki/Developer/Tools/RSB)]>))
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170112/af1f81f7/attachment-0002.html>
