[PATCH] Update RMS documentation for overrun handling
Joel Sherrill
joel at rtems.org
Fri Jan 13 22:50:54 UTC 2017
I have committed this.
If there are academic references that a user should know or this
is theoretically based on, I would like to see them listed. Anything
that strengthens the user's understanding of where this originated.
It doesn't look like Chris has automatic updates on docs working yet
but it should show up before too long at https://docs.rtems.org/.
Thanks.
--joel
On Fri, Jan 13, 2017 at 3:21 PM, Gedare Bloom <gedare at rtems.org> wrote:
> I was unable to compile rtems-docs (cleanly), so I have not committed
> this patch yet. If someone else who can compile docs can build with
> this patch, please commit. I need to debug my baseline build still...
> On Wed, Dec 21, 2016 at 11:44 AM, Kuan-Hsun Chen <c0066c at gmail.com> wrote:
> > c-user/rate_monotonic_manager.rst | 30 +++++++++++++++++-------------
> > 1 file changed, 17 insertions(+), 13 deletions(-)
> > diff --git a/c-user/rate_monotonic_manager.rst b/c-user/rate_monotonic_
> manager.rst
> > index 8ad74e5..9ba22a5 100644
> > --- a/c-user/rate_monotonic_manager.rst
> > +++ b/c-user/rate_monotonic_manager.rst
> > @@ -132,7 +132,7 @@ milliseconds every 100 (10 percent of the CPU). As
> a general rule of thumb,
> > the higher frequency at which a task executes, the more important it is
> to
> > optimize that task.
> > -Rate Monotonic Manager Definitions
> > +Periodicity Definitions
> > .. index:: periodic task, definition
> > @@ -170,7 +170,7 @@ Rate Monotonic Scheduling Algorithm
> > .. index:: RMS Algorithm, definition
> > The Rate Monotonic Scheduling Algorithm (RMS) is important to real-time
> systems
> > -designers because it allows one to guarantee that a set of tasks is
> > +designers because it allows one to sufficiently guarantee that a set of
> tasks is
> > schedulable. A set of tasks is said to be schedulable if all of the
> tasks can
> > meet their deadlines. RMS provides a set of rules which can be used to
> perform
> > a guaranteed schedulability analysis for a task set. This analysis
> determines
> > @@ -179,11 +179,11 @@ the predictability of the system's behavior. It
> has been proven that:
> > .. sidebar:: *RMS*
> > - RMS is an optimal static priority algorithm for scheduling
> independent,
> > + RMS is an optimal fixed-priority algorithm for scheduling independent,
> > preemptible, periodic tasks on a single processor.
> > RMS is optimal in the sense that if a set of tasks can be scheduled by
> any
> > -static priority algorithm, then RMS will be able to schedule that task
> set.
> > +fixed-priority algorithm, then RMS will be able to schedule that task
> set.
> > RMS bases it schedulability analysis on the processor utilization level
> below
> > which all deadlines can be met.
> > @@ -230,7 +230,7 @@ Schedulability Analysis
> > .. index:: RMS schedulability analysis
> > -RMS allows application designers to ensure that tasks can meet all
> deadlines,
> > +RMS allows application designers to ensure that tasks can meet all
> deadlines under fixed-priority assignment,
> > even under transient overload, without knowing exactly when any given
> task will
> > execute by applying proven schedulability analysis rules.
> > @@ -468,9 +468,10 @@ monotonic period results in one of the following
> scenarios:
> > immediately.
> > - If the rate monotonic period has expired before the task invokes the
> > - ``rtems_rate_monotonic_period`` directive, the period will be
> initiated with
> > - a length of period ticks and the calling task returns immediately
> with a
> > - timeout error status.
> > + ``rtems_rate_monotonic_period`` directive, the postponed job will be
> released
> > + until there is no more postponed jobs. The calling task returns
> immediately
> > + with a timeout error status. In the watchdog routine, the period will
> still
> > + be updated periodically and track the number of the postponed periods.
> > Obtaining the Status of a Period
> > @@ -560,8 +561,8 @@ Subsequent invocations of the
> ``rtems_rate_monotonic_period`` directive will
> > result in the task blocking for the remainder of the 100 tick period.
> If, for
> > any reason, the body of the loop takes more than 100 ticks to execute,
> the
> > ``rtems_rate_monotonic_period`` directive will return the
> ``RTEMS_TIMEOUT``
> > -status. If the above task misses its deadline, it will delete the rate
> > -monotonic period and itself.
> > +status and the postponed job will be released. If the above task misses
> > +its deadline, it will delete the rate monotonic period and itself.
> > Task with Multiple Periods
> > @@ -629,8 +630,8 @@ will not block.
> > If, for any reason, the task misses any deadline, the
> ``RTEMS_TIMEOUT``
> > -directive status. If the above task misses its deadline, it will
> delete the
> > -rate monotonic periods and itself.
> > +directive status and the postponed job will be released. If the above
> task misses
> > +its deadline, it will delete the rate monotonic periods and itself.
> > Directives
> > @@ -839,7 +840,10 @@ DESCRIPTION:
> > period ticks. If id is running, then the calling task will block
> for the
> > remainder of the period before reinitiating the period with the
> specified
> > period. If id was not running (either expired or never initiated),
> the
> > - period is immediately initiated and the directive returns
> immediately.
> > + period is immediately initiated and the directive returns
> immediately.
> > + If id has expired its period, the postponed job will be released
> immediately
> > + and the following calls of this directive will release postponed
> > + jobs until there is no more deadline miss.
> > If invoked with a period of ``RTEMS_PERIOD_STATUS`` ticks, the
> current
> > state of id will be returned. The directive status indicates the
> current
> > 1.9.1
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170113/03cd717f/attachment-0002.html>
