[PATCH] rtems-test-check: Make exclude work again.
Tue Jan 17 14:08:16 UTC 2017
On Mon, Jan 16, 2017 at 5:12 PM, Chris Johns <chrisj at rtems.org> wrote:
> This change looks wrong. Moving test loop out of the if testdata block
> means variables in the test loop are not defined. I consider it a script
> bug to assume it is ok to reference a variable that is not declared
> because it is ambiguous if this intended behavior or a bug.
> Starvos sent me this change a few days ago and it looks good. I am
> hoping he will make a patch we can merge so he can have the credit ..
> diff --git a/tools/build/rtems-test-check b/tools/build/rtems-test-check
> index e02f8e9..108b788 100755
> --- a/tools/build/rtems-test-check
> +++ b/tools/build/rtems-test-check
> @@ -32,7 +32,11 @@ done
>  case ${mode} in
>   exclude)
> -   output=${tests}
> +   if test -f $testdata; then
> +     output=""
> +   else
> +     output="${tests}"
> +   fi
>   flags)
>     if [ $test_count != 1 ]; then
> Are you in a position to test this change?
I am starting a test sweep of this now. I will need Starvos's proper
name and email to commit it though.
--joel
> Chris
> On 17/1/17 6:24 am, Joel Sherrill wrote:
> > closes #2867.
> >  tools/build/rtems-test-check | 90 ++++++++++++++++++++++--------
> >  1 file changed, 45 insertions(+), 45 deletions(-)
> > index e02f8e9..e8acde0 100755
> > @@ -32,7 +32,6 @@ done
> >  case ${mode} in
> >   exclude)
> > -   output=${tests}
> >   flags)
> > @@ -99,52 +98,53 @@ if test -f $testdata; then
> >      testdata=$ntd
> >    done
> > -  for t in ${tests};
> > -  do
> > -    case ${mode} in
> > -      exclude)
> > -        allow="yes"
> > -        for dt in ${excluded_tests};
> > -        do
> > -          if test ${t} = ${dt}; then
> > -            allow="no"
> > -          fi
> > -        done
> > -        if test ${allow} = yes; then
> > -          output="${output} ${t}"
> > -        fi
> > -      flags)
> > -        allow="no"
> > -        for et in ${expected_fails};
> > -        do
> > -          if test ${t} = ${et}; then
> > -            allow="yes"
> > -          fi
> > -        done
> > -          output="-DTEST_STATE_EXPECTED_FAIL=1"
> > -        fi
> > -        allow="no"
> > -        for it in ${indeterminates};
> > -        do
> > -          if test ${t} = ${it}; then
> > -            allow="yes"
> > -          fi
> > -        done
> > -          output="${output} -DTEST_STATE_INDETERMINATE=1"
> > -        fi
> > -        echo "error: invalid mode" 1>&2
> > -        echo "INVALID-TEST-DATA"
> > -        exit 1
> > -    esac
> > -  done
> >  fi
> > +for t in ${tests};
> > +do
> > +  case ${mode} in
> > +    exclude)
> > +      allow="yes"
> > +      for dt in ${excluded_tests};
> > +      do
> > +     if test ${t} = ${dt}; then
> > +       allow="no"
> > +     fi
> > +      done
> > +      if test ${allow} = yes; then
> > +     output="${output} ${t}"
> > +      fi
> > +    flags)
> > +      allow="no"
> > +      for et in ${expected_fails};
> > +      do
> > +     if test ${t} = ${et}; then
> > +       allow="yes"
> > +     fi
> > +      done
> > +     output="-DTEST_STATE_EXPECTED_FAIL=1"
> > +      fi
> > +      allow="no"
> > +      for it in ${indeterminates};
> > +      do
> > +     if test ${t} = ${it}; then
> > +       allow="yes"
> > +     fi
> > +      done
> > +     output="${output} -DTEST_STATE_INDETERMINATE=1"
> > +      fi
> > +      echo "error: invalid mode" 1>&2
> > +      echo "INVALID-TEST-DATA"
> > +      exit 1
> > +  esac
> > +done
> >  echo ${output}
> >  exit 0
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170117/f937deb8/attachment-0002.html>
