RTEMS master LEON test status
Kuan Hsun Chen
kuan-hsun.chen at tu-dortmund.de
Tue Jan 24 13:27:28 UTC 2017
Hi Sebastian,
I will check again the test on SMP target, though I only have QEMU-SMP to
simulate at the moment.
Is it okay to only test on QEMU?
Interestingly, why only sprmsched01 fails? How about spedfsched04?
I will start from this observation and see why SMP fails.
Best,
Kuan-Hsun
2017-01-24 13:51 GMT+01:00 Sebastian Huber <sebastian.huber at embedded-
brains.de>:
> Hello Daniel,
> for RTEMS 4.12 GCC 6.3 will be used (most likely). I did test runs with
> https://git.rtems.org/rtems/commit/?id=b07e642a2b1249cd64048
> c5e9f5e45254df7ae65
> on the GR740 with no unexpected test failures.
> On 24/01/17 13:25, Daniel Hellstrom wrote:
>> Hi,
>> We started some time ago to work with the RTEMS master again. Daniel C
>> has updated the toolchain to use GCC-7 which now seems to be working fine.
>> I just want to share the current status of the RTEMS test-suite on the
>> GR712RC with you. Please let me know if you expect something or a
>> particular tests to be failing before we go too deep into them.
>> In the SMP configuration there were a couple of tests hanging and GRMON
>> interrupted them after 4 minutes. sp20 for example resulted in a hang while
>> acquiring a SMP lock from the Clock interrupt handler:
> A change in the rate-monotonic manager did break several tests:
> https://devel.rtems.org/ticket/2795
>> GR712RC, RTEMS Single-core configuration results:
>> # RTEMS TESTSUITE FAILURE SUMMARY
>> # Result Test ExecRes ConsoleRes ExitCode1 ExitCode2
>> # FAIL: ./fstests/fsdosfsname01 OK FAIL 5 0
>> # FAIL: ./psxtests/psxsem01 OK FAIL 5 11
>> # FAIL: ./sptests/spinternalerror01 OK N/A -559038737 1611526157
>> # FAIL: ./sptests/sptimecounter01 OK N/A 5 0
>> # SUMMARY
>> # Tests failing: 4
>> # Tests successful: 528
> It would be good to investigate these issues.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> devel mailing list
> devel at rtems.org
M.Sc. Kuan-Hsun Chen
TU Dortmund
Department of Computer Science 12
Design Automation of Embedded Systems
Otto-Hahn-Strasse 16, Room 102
44227 Dortmund
Germany
Phone: *+49 231 755 6124 <+49%20231%207556124>*
Mail: kuan-hsun.chen at tu-dortmund.de <kuan-hsun.chen at tu-dortmund.de>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170124/372d8b49/attachment-0002.html>
