RTEMS master LEON test status
Kuan Hsun Chen kuan-hsun.chen at tu-dortmund.de
Tue Jan 24 14:11:03 UTC 2017
Hello Sebastian,
I shouldn't do those ISR lock and _Thread_Dispatch_disable, right?
Does this patch solve some of the original test fails?
I'm trying the latest version now.
Best,
Kuan-Hsun
2017-01-24 14:46 GMT+01:00 Sebastian Huber <
sebastian.huber at embedded-brains.de>:
> Hello Kuan-Hsun,
> thanks for your prompt feedback. I checked in a patch that fixes one issue:
> https://devel.rtems.org/changeset/1240aade5a35c4e8c43d5409e2
> 329eeb6a173299/rtems
> On 24/01/17 14:27, Kuan Hsun Chen wrote:
>> Hi Sebastian,
>> I will check again the test on SMP target, though I only have QEMU-SMP to
>> simulate at the moment.
>> Is it okay to only test on QEMU?
>> Interestingly, why only sprmsched01 fails? How about spedfsched04?
>> I will start from this observation and see why SMP fails.
>> Best,
>> Kuan-Hsun
>> 2017-01-24 13:51 GMT+01:00 Sebastian Huber <sebastian.huber at embedded-brai
>> ns.de <mailto:sebastian.huber at embedded-brains.de>>:
>>     Hello Daniel,
>>     for RTEMS 4.12 GCC 6.3 will be used (most likely). I did test runs
>>     with
>>     https://git.rtems.org/rtems/commit/?id=b07e642a2b1249cd64048
>> c5e9f5e45254df7ae65
>>     <https://git.rtems.org/rtems/commit/?id=b07e642a2b1249cd6404
>> 8c5e9f5e45254df7ae65>
>>     on the GR740 with no unexpected test failures.
>>     On 24/01/17 13:25, Daniel Hellstrom wrote:
>>         Hi,
>>         We started some time ago to work with the RTEMS master again.
>>         Daniel C has updated the toolchain to use GCC-7 which now
>>         seems to be working fine. I just want to share the current
>>         status of the RTEMS test-suite on the GR712RC with you. Please
>>         let me know if you expect something or a particular tests to
>>         be failing before we go too deep into them.
>>         In the SMP configuration there were a couple of tests hanging
>>         and GRMON interrupted them after 4 minutes. sp20 for example
>>         resulted in a hang while acquiring a SMP lock from the Clock
>>         interrupt handler:
>>     A change in the rate-monotonic manager did break several tests:
>>     https://devel.rtems.org/ticket/2795
>>     <https://devel.rtems.org/ticket/2795>
>>         GR712RC, RTEMS Single-core configuration results:
>>           # RTEMS TESTSUITE FAILURE SUMMARY
>>           # Result Test ExecRes ConsoleRes ExitCode1 ExitCode2
>>           # FAIL: ./fstests/fsdosfsname01 OK FAIL 5 0
>>           # FAIL: ./psxtests/psxsem01 OK FAIL 5 11
>>           # FAIL: ./sptests/spinternalerror01 OK N/A -559038737 1611526157
>>           # FAIL: ./sptests/sptimecounter01 OK N/A 5 0
>>           # SUMMARY
>>           #  Tests failing:    4
>>           #  Tests successful: 528
>>     It would be good to investigate these issues.
>>     --     Sebastian Huber, embedded brains GmbH
>>     Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>     Phone   : +49 89 189 47 41-16 <tel:%2B49%2089%20189%2047%2041-16>
>>     Fax     : +49 89 189 47 41-09 <tel:%2B49%2089%20189%2047%2041-09>
>>     E-Mail  : sebastian.huber at embedded-brains.de
>>     PGP     : Public key available on request.
>>     Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>>     _______________________________________________
>>     devel mailing list
>>     devel at rtems.org <mailto:devel at rtems.org>
>>     http://lists.rtems.org/mailman/listinfo/devel
>>     <http://lists.rtems.org/mailman/listinfo/devel>
>> M.Sc. Kuan-Hsun Chen
>> TU Dortmund
>> Department of Computer Science 12
>> Design Automation of Embedded Systems
>> Otto-Hahn-Strasse 16, Room 102
>> 44227 Dortmund
>> Germany
>> Phone: _+49 231 755 6124 <tel:+49%20231%207556124>_
>> Mail: kuan-hsun.chen at tu-dortmund.de <mailto:kuan-hsun.chen at tu-dortmund.de
TU Dortmund
44227 Dortmund
Germany
Phone:  *+49 231 755 6124*
Mail:   kuan-hsun.chen at tu-dortmund.de <kuan-hsun.chen at tu-dortmund.de>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170124/93772c15/attachment-0002.html>
