[PATCH] rtems: Remove rtems_rate_monotonic_postponed_job_count()
Kuan Hsun Chen
c0066c at gmail.com
Wed Jan 25 16:56:03 UTC 2017
This is the patch for #2885 ticket.
2017-01-25 16:18 GMT+01:00 Kuan-Hsun Chen <c0066c at gmail.com>:
> Add a variable named "count" in rtems_rate_monotonic_period_status
> structure
> Revise rtems_rate_monotonic_get_status() for the postponed job count.
> sptests/sp69: Revise
> Add in the verification of the postponed job count for
> rtems_rate_monotonic_get_status().
> cpukit/rtems/include/rtems/rtems/ratemon.h | 24 ++++--------------------
> cpukit/rtems/src/ratemongetstatus.c | 2 ++
> cpukit/rtems/src/ratemonperiod.c | 16 +---------------
> testsuites/sptests/sp69/init.c | 8 ++++++++
> testsuites/sptests/sp69/sp69.doc | 2 ++
> testsuites/sptests/sp69/sp69.scn | 5 +++--
> 6 files changed, 20 insertions(+), 37 deletions(-)
> diff --git a/cpukit/rtems/include/rtems/rtems/ratemon.h
> b/cpukit/rtems/include/rtems/rtems/ratemon.h
> index 54ddd05..5616ee9 100644
> --- a/cpukit/rtems/include/rtems/rtems/ratemon.h
> +++ b/cpukit/rtems/include/rtems/rtems/ratemon.h
> @@ -23,7 +23,7 @@
> /* COPYRIGHT (c) 1989-2009, 2016.
> * On-Line Applications Research Corporation (OAR).
> - * COPYRIGHT (c) 2016 Kuan-Hsun Chen.
> + * COPYRIGHT (c) 2016-2017 Kuan-Hsun Chen.
> * The license and distribution terms for this file may be
> * found in the file LICENSE in this distribution or at
> @@ -182,6 +182,9 @@ typedef struct {
> * then this field has no meaning.
> rtems_thread_cpu_usage_t executed_since_last_period;
> + /** This is the count of postponed jobs of this period. */
> + uint32_t postponed_jobs_count;
> } rtems_rate_monotonic_period_status;
> @@ -417,25 +420,6 @@ rtems_status_code rtems_rate_monotonic_period(
> rtems_interval length
> - * @brief Return the number of postponed jobs
> - * This is a helper function for runtime monitoring to return
> - * the number of postponed jobs in this given period. This number
> - * is only increased by the corresponding watchdog,
> - * and is decreased by RMS manager with the postponed job releasing.
> - * @param[in] id is the period id
> - * @retval This helper function returns the number of postponed
> - * jobs with a given period_id.
> -uint32_t rtems_rate_monotonic_postponed_job_count(
> - rtems_id period_id
> #ifdef __cplusplus
> diff --git a/cpukit/rtems/src/ratemongetstatus.c b/cpukit/rtems/src/
> ratemongetstatus.c
> index 403c6ed..4e6b964 100644
> --- a/cpukit/rtems/src/ratemongetstatus.c
> +++ b/cpukit/rtems/src/ratemongetstatus.c
> @@ -9,6 +9,7 @@
> * COPYRIGHT (c) 1989-2009.
> * Copyright (c) 2016 embedded brains GmbH.
> + * Copyright (c) 2017 Kuan-Hsun Chen.
> @@ -43,6 +44,7 @@ rtems_status_code rtems_rate_monotonic_get_status(
> period_status->owner = the_period->owner->Object.id;
> period_status->state = the_period->state;
> + period_status->postponed_jobs_count = the_period->postponed_jobs;
> if ( the_period->state == RATE_MONOTONIC_INACTIVE ) {
> diff --git a/cpukit/rtems/src/ratemonperiod.c b/cpukit/rtems/src/
> ratemonperiod.c
> index 97547e2..5b5d1dc 100644
> --- a/cpukit/rtems/src/ratemonperiod.c
> +++ b/cpukit/rtems/src/ratemonperiod.c
> @@ -9,7 +9,7 @@
> * COPYRIGHT (c) 1989-2010.
> @@ -302,20 +302,6 @@ static rtems_status_code _Rate_monotonic_Block_while_
> expired(
> return RTEMS_TIMEOUT;
> -uint32_t rtems_rate_monotonic_postponed_job_count( rtems_id period_id )
> - Rate_monotonic_Control *the_period;
> - ISR_lock_Context lock_context;
> - uint32_t jobs;
> - the_period = _Rate_monotonic_Get( period_id, &lock_context );
> - _Assert( the_period != NULL );
> - jobs = the_period->postponed_jobs;
> - _Rate_monotonic_Release( the_period, &lock_context );
> - return jobs;
> rtems_id id,
> diff --git a/testsuites/sptests/sp69/init.c b/testsuites/sptests/sp69/
> init.c
> index ac6f58c..c38beb8 100644
> --- a/testsuites/sptests/sp69/init.c
> +++ b/testsuites/sptests/sp69/init.c
> @@ -162,6 +162,14 @@ rtems_task Init(
> rtems_test_assert( statistics.missed_count == i );
> + /* Check the status */
> + status = rtems_rate_monotonic_get_status( period_id, &period_status );
> + directive_failed( status, "rate_monotonic_get_status" );
> + puts(
> + "rtems_rate_monotonic_get_status - verify value of a postponed jobs
> count"
> + rtems_test_assert( period_status.postponed_jobs_count == 3 );
> TEST_END();
> diff --git a/testsuites/sptests/sp69/sp69.doc b/testsuites/sptests/sp69/
> sp69.doc
> index fbf0e4e..60aacb8 100644
> --- a/testsuites/sptests/sp69/sp69.doc
> +++ b/testsuites/sptests/sp69/sp69.doc
> @@ -1,5 +1,6 @@
> # COPYRIGHT (c) 1989-2009.
> # On-Line Applications Research Corporation (OAR).
> +# COPYRIGHT (c) 2017 Kuan-Hsun Chen.
> # The license and distribution terms for this file may be
> # found in the file LICENSE in this distribution or at
> @@ -21,3 +22,4 @@ concepts:
> a period is initiated.
> + Verify the correctness of the status values returned on an active
> period.
> + Ensure the missed period count is properly maintained.
> ++ Verify the correctness of the postponed job count.
> diff --git a/testsuites/sptests/sp69/sp69.scn b/testsuites/sptests/sp69/
> sp69.scn
> index 654eea0..e102d22 100644
> --- a/testsuites/sptests/sp69/sp69.scn
> +++ b/testsuites/sptests/sp69/sp69.scn
> @@ -2,8 +2,9 @@
> rtems_rate_monotonic_get_status - verify values of an inactive period
> rtems_rate_monotonic_get_status - check RTEMS_NOT_DEFINED
> rtems_rate_monotonic_get_status - verify values of an active period
> -wall time should be ~600000000 is 609216000
> -cpu time should be ~100000000 is 109217000
> +wall time should be ~600000000 is 609402399
> +cpu time should be ~100000000 is 109612659
> rtems_rate_monotonic_cancel - OK
> Testing statistics on missed periods
> +rtems_rate_monotonic_get_status - verify value of a postponed jobs count
> *** END OF TEST 69 ***
> 1.9.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170125/50e57d9b/attachment-0002.html>
