[PATCH] rtems: Fix _Rate_monotonic_Renew_deadline()
Kuan Hsun Chen c0066c at gmail.com
Thu Jan 26 17:00:47 UTC 2017
I accidentally add c/src/lib/libbsp/powerpc/acinclude.m4 into the comment.
Now ticket 2885 should be close. The previous patch has a typo in the
comment I hotfix in this patch.
2017-01-26 18:02 GMT+01:00 Kuan-Hsun Chen <c0066c at gmail.com>:
> Prepare a precondition to prevent the potential integer overflow.
> Remove one redundant parameter in _Rate_monotonic_Renew_deadline().
> sptests/sp78: Create
> A test case for checking the overflow condition of postponed_jobs
> in rtems_rate_monotonic_period_status.
> Close #2885.
>  c/src/lib/libbsp/powerpc/acinclude.m4 |   4 +-
>  cpukit/rtems/src/ratemontimeout.c     |  11 ++--
>  testsuites/sptests/Makefile.am        |   2 +-
>  testsuites/sptests/configure.ac       |   1 +
>  testsuites/sptests/sp78/Makefile.am   |  22 +++++++
>  testsuites/sptests/sp78/init.c        | 120 ++++++++++++++++++++++++++++++
>  testsuites/sptests/sp78/sp78.doc      |  18 +++++
>  testsuites/sptests/sp78/sp78.scn      |   9 +++
>  8 files changed, 180 insertions(+), 7 deletions(-)
>  create mode 100644 testsuites/sptests/sp78/Makefile.am
>  create mode 100644 testsuites/sptests/sp78/init.c
>  create mode 100644 testsuites/sptests/sp78/sp78.doc
>  create mode 100644 testsuites/sptests/sp78/sp78.scn
> diff --git a/c/src/lib/libbsp/powerpc/acinclude.m4
> b/c/src/lib/libbsp/powerpc/acinclude.m4
> index 4c83475..edc67b5 100644
> --- a/c/src/lib/libbsp/powerpc/acinclude.m4
> +++ b/c/src/lib/libbsp/powerpc/acinclude.m4
> @@ -32,12 +32,12 @@ AC_DEFUN([RTEMS_CHECK_BSPDIR],
>      AC_CONFIG_SUBDIRS([t32mppc]);;
>    tqm8xx )
>      AC_CONFIG_SUBDIRS([tqm8xx]);;
> -  virtex )
> -    AC_CONFIG_SUBDIRS([virtex]);;
>    virtex4 )
>      AC_CONFIG_SUBDIRS([virtex4]);;
>    virtex5 )
>      AC_CONFIG_SUBDIRS([virtex5]);;
> +  virtex )
> +    AC_CONFIG_SUBDIRS([virtex]);;
>      AC_MSG_ERROR([Invalid BSP]);;
>    esac
> diff --git a/cpukit/rtems/src/ratemontimeout.c b/cpukit/rtems/src/
> ratemontimeout.c
> index bcc4ccf..5a838fd 100644
> --- a/cpukit/rtems/src/ratemontimeout.c
> +++ b/cpukit/rtems/src/ratemontimeout.c
> @@ -9,7 +9,7 @@
>   *  COPYRIGHT (c) 1989-2009.
>   *  On-Line Applications Research Corporation (OAR).
> - *  COPYRIGHT (c) 2016 Kuan-Hsun Chen.
> + *  COPYRIGHT (c) 2016-2017 Kuan-Hsun Chen.
>   *  The license and distribution terms for this file may be
>   *  found in the file LICENSE in this distribution or at
> @@ -24,13 +24,16 @@
>  static void _Rate_monotonic_Renew_deadline(
>    Rate_monotonic_Control *the_period,
> -  Thread_Control         *owner,
>    ISR_lock_Context       *lock_context
>    uint64_t deadline;
> -  ++the_period->postponed_jobs;
> +  /* stay at 0xffffffff if postponed_jobs is going to overflow */
> +  if ( the_period->postponed_jobs != UINT32_MAX ) {
> +    ++the_period->postponed_jobs;
>    the_period->state = RATE_MONOTONIC_EXPIRED;
>    deadline = _Watchdog_Per_CPU_insert_relative(
> @@ -85,6 +88,6 @@ void _Rate_monotonic_Timeout( Watchdog_Control
> *the_watchdog )
>        _Thread_Unblock( owner );
>    } else {
> -    _Rate_monotonic_Renew_deadline( the_period, owner, &lock_context );
> +    _Rate_monotonic_Renew_deadline( the_period, &lock_context );
> diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.
> am
> index 5ef87a0..11e9bcd 100644
> --- a/testsuites/sptests/Makefile.am
> +++ b/testsuites/sptests/Makefile.am
> @@ -10,7 +10,7 @@ _SUBDIRS = \
>      sp40 sp41 sp42 sp43 sp44 sp45 sp46 sp47 sp48 sp49 \
>      sp50 sp51 sp52 sp53 sp54 sp55 sp56 sp57 sp58 sp59 \
>      sp60      sp62 sp63 sp64 sp65 sp66 sp67 sp68 sp69 \
> -    sp70 sp71 sp72 sp73 sp74 sp75 sp76 sp77 sp2038 \
> +    sp70 sp71 sp72 sp73 sp74 sp75 sp76 sp77 sp78 sp2038 \
>      spassoc01 spchain spcoverage spobjgetnext \
>      spprintk spprivenv01 sprbtree01 spsize spstkalloc \
>      spstkalloc02 spthreadq01 spwatchdog spwkspace \
> diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/
> configure.ac
> index 77ec512..a2af200 100644
> --- a/testsuites/sptests/configure.ac
> +++ b/testsuites/sptests/configure.ac
> @@ -144,6 +144,7 @@ sp74/Makefile
>  sp75/Makefile
>  sp76/Makefile
>  sp77/Makefile
> +sp78/Makefile
>  sp2038/Makefile
>  spassoc01/Makefile
>  spcbssched01/Makefile
> diff --git a/testsuites/sptests/sp78/Makefile.am
> b/testsuites/sptests/sp78/Makefile.am
> new file mode 100644
> index 0000000..3e59f3d
> --- /dev/null
> +++ b/testsuites/sptests/sp78/Makefile.am
> @@ -0,0 +1,22 @@
> +rtems_tests_PROGRAMS = sp78
> +sp78_SOURCES = init.c ../../support/src/spin.c
> +dist_rtems_tests_DATA = sp78.scn
> +dist_rtems_tests_DATA += sp78.doc
> +include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
> +include $(top_srcdir)/../automake/compile.am
> +include $(top_srcdir)/../automake/leaf.am
> +AM_CPPFLAGS += -I$(top_srcdir)/../support/include
> +LINK_OBJS = $(sp78_OBJECTS)
> +LINK_LIBS = $(sp78_LDLIBS)
> +sp78$(EXEEXT): $(sp78_OBJECTS) $(sp78_DEPENDENCIES)
> +       @rm -f sp69$(EXEEXT)
> +       $(make-exe)
> +include $(top_srcdir)/../automake/local.am
> diff --git a/testsuites/sptests/sp78/init.c b/testsuites/sptests/sp78/
> init.c
> index 0000000..99eec27
> --- /dev/null
> +++ b/testsuites/sptests/sp78/init.c
> @@ -0,0 +1,120 @@
> + *  COPYRIGHT (c) 2017 Kuan-Hsun Chen.
> + *  The license and distribution terms for this file may be
> + *  found in the file LICENSE in this distribution or at
> + *  http://www.rtems.org/license/LICENSE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <rtems/cpuuse.h>
> +#include <tmacros.h>
> +#include <rtems/rtems/ratemonimpl.h>
> +#include "test_support.h"
> +const char rtems_test_name[] = "SP 78";
> +/* forward declarations to avoid warnings */
> +rtems_task Init( rtems_task_argument argument );
> +static void modify_count( rtems_id id );
> +  rtems_id            id
> +  Rate_monotonic_Control                  *the_period;
> +  ISR_lock_Context                        lock_context;
> +  the_period = _Rate_monotonic_Get( id, &lock_context );
> +  _Rate_monotonic_Acquire_critical( the_period, &lock_context );
> +  the_period->postponed_jobs = UINT32_MAX;
> +  _Rate_monotonic_Release( the_period, &lock_context );
> +rtems_task Init(
> +  rtems_task_argument argument
> +  rtems_id                                period_id;
> +  rtems_name                              period_name;
> +  rtems_rate_monotonic_period_status      period_status;
> +  rtems_status_code                       status;
> +  int                                     i;
> +  period_name = rtems_build_name('P','E','R','1');
> +  TEST_BEGIN();
> +  /* create period */
> +  status = rtems_rate_monotonic_create(
> +      period_name,
> +      &period_id
> +  directive_failed( status, "rate_monotonic_create" );
> +  /* modify the count to UINT32_MAX and attempt to miss deadline*/
> +  puts( "Testing overflow condition" );
> +  rtems_test_spin_until_next_tick();
> +  status = rtems_rate_monotonic_period( period_id, 50 );
> +  directive_failed( status, "rate_monotonic_period above loop" );
> +  puts( "Modify the count of postponed_job manually" );
> +  modify_count( period_id );
> +  /* Check the status */
> +  status = rtems_rate_monotonic_get_status( period_id, &period_status );
> +  directive_failed( status, "rate_monotonic_get_status" );
> +  printf( "Init Postponed jobs = %"PRIu32", and expected %"PRIu32"\n",
> period_status.postponed_jobs_count, UINT32_MAX );
> +  rtems_test_assert( period_status.postponed_jobs_count == UINT32_MAX );
> +  for ( i=1 ; i <= 2 ; i++ ) {
> +    status = rtems_task_wake_after( 100 );
> +    directive_failed( status, "rtems_task_wake_after(100)" );
> +    puts( "Task misses its deadline." );
> +    /* print out the count which should keep in UINT32_MAX, since the
> period still misses its deadline */
> +    printf( "Count = %"PRIu32", and expected %"PRIu32"\n",
> period_status.postponed_jobs_count, UINT32_MAX);
> +    rtems_test_assert( period_status.postponed_jobs_count == UINT32_MAX);
> +    fatal_directive_status(
> +      status,
> +      RTEMS_TIMEOUT,
> +      "rtems_rate_monotonic_period 2-n"
> +  TEST_END();
> +  rtems_test_exit(0);
> +/* configuration information */
> +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> +#define CONFIGURE_MILLISECONDS_PER_TICK 1
> +#define CONFIGURE_MAXIMUM_TASKS             1
> +#define CONFIGURE_MAXIMUM_PERIODS           1
> +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> +#include <rtems/confdefs.h>
> +/* end of file */
> diff --git a/testsuites/sptests/sp78/sp78.doc b/testsuites/sptests/sp78/
> sp78.doc
> index 0000000..ad64e4b
> --- /dev/null
> +++ b/testsuites/sptests/sp78/sp78.doc
> @@ -0,0 +1,18 @@
> +#  COPYRIGHT (c) 2017 Kuan-Hsun Chen.
> +#  The license and distribution terms for this file may be
> +#  found in the file LICENSE in this distribution or at
> +#  http://www.rtems.org/license/LICENSE.
> +This file describes the directives and concepts tested by this test set.
> +test set name:  sp78
> +directives:
> +  rtems_rate_monotonic_get_status
> +concepts:
> ++ Test the overflow condition for postponed_jobs.
> diff --git a/testsuites/sptests/sp78/sp78.scn b/testsuites/sptests/sp78/
> sp78.scn
> index 0000000..4cb71db
> --- /dev/null
> +++ b/testsuites/sptests/sp78/sp78.scn
> @@ -0,0 +1,9 @@
> +*** BEGIN OF TEST SP 78 ***
> +Testing overflow condition
> +Modify the count of postponed_job manually
> +Init Postponed jobs = 4294967295, and expected 4294967295
> +Task misses its deadline.
> +Count = 4294967295, and expected 4294967295
> +*** END OF TEST SP 78 ***
> 1.9.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170126/d5fa50c8/attachment-0002.html>
