[PATCH v3] rtems: Fix _Rate_monotonic_Renew_deadline()
    Kuan Hsun Chen
    c0066c at gmail.com
    Fri Jan 27 22:13:43 UTC 2017
Aha, now v4 should be fine. I remove a typo.
2017-01-27 22:27 GMT+01:00 Gedare Bloom <gedare at rtems.org>:
> The acinclude came back
> On Fri, Jan 27, 2017 at 3:03 PM, Kuan-Hsun Chen <c0066c at gmail.com> wrote:
> > Prepare a precondition to prevent the potential integer overflow.
> > Remove one redundant parameter in _Rate_monotonic_Renew_deadline().
> > sptests/sp78: Create
> > A test case for checking the overflow condition of postponed_jobs
> > in rtems_rate_monotonic_period_status.
> > Close #2885.
> >  c/src/lib/libbsp/powerpc/acinclude.m4 |   4 +-
> >  cpukit/rtems/src/ratemontimeout.c     |  11 ++--
> >  testsuites/sptests/Makefile.am        |   2 +-
> >  testsuites/sptests/configure.ac       |   1 +
> >  testsuites/sptests/sp78/Makefile.am   |  22 +++++++
> >  testsuites/sptests/sp78/init.c        | 120
> >  testsuites/sptests/sp78/sp78.doc      |  18 +++++
> >  testsuites/sptests/sp78/sp78.scn      |   9 +++
> >  8 files changed, 180 insertions(+), 7 deletions(-)
> >  create mode 100644 testsuites/sptests/sp78/Makefile.am
> >  create mode 100644 testsuites/sptests/sp78/init.c
> >  create mode 100644 testsuites/sptests/sp78/sp78.doc
> >  create mode 100644 testsuites/sptests/sp78/sp78.scn
> > diff --git a/c/src/lib/libbsp/powerpc/acinclude.m4
> b/c/src/lib/libbsp/powerpc/acinclude.m4
> > index 4c83475..edc67b5 100644
> > --- a/c/src/lib/libbsp/powerpc/acinclude.m4
> > +++ b/c/src/lib/libbsp/powerpc/acinclude.m4
> > @@ -32,12 +32,12 @@ AC_DEFUN([RTEMS_CHECK_BSPDIR],
> >      AC_CONFIG_SUBDIRS([t32mppc]);;
> >    tqm8xx )
> >      AC_CONFIG_SUBDIRS([tqm8xx]);;
> > -  virtex )
> > -    AC_CONFIG_SUBDIRS([virtex]);;
> >    virtex4 )
> >      AC_CONFIG_SUBDIRS([virtex4]);;
> >    virtex5 )
> >      AC_CONFIG_SUBDIRS([virtex5]);;
> > +  virtex )
> > +    AC_CONFIG_SUBDIRS([virtex]);;
> >      AC_MSG_ERROR([Invalid BSP]);;
> >    esac
> > diff --git a/cpukit/rtems/src/ratemontimeout.c b/cpukit/rtems/src/
> ratemontimeout.c
> > index bcc4ccf..5a838fd 100644
> > --- a/cpukit/rtems/src/ratemontimeout.c
> > +++ b/cpukit/rtems/src/ratemontimeout.c
> > @@ -9,7 +9,7 @@
> >   *  COPYRIGHT (c) 1989-2009.
> >   *  On-Line Applications Research Corporation (OAR).
> > - *  COPYRIGHT (c) 2016 Kuan-Hsun Chen.
> > + *  COPYRIGHT (c) 2016-2017 Kuan-Hsun Chen.
> >   *  The license and distribution terms for this file may be
> >   *  found in the file LICENSE in this distribution or at
> > @@ -24,13 +24,16 @@
> >  static void _Rate_monotonic_Renew_deadline(
> >    Rate_monotonic_Control *the_period,
> > -  Thread_Control         *owner,
> >    ISR_lock_Context       *lock_context
> >    uint64_t deadline;
> > -  ++the_period->postponed_jobs;
> > +  /* stay at 0xffffffff if postponed_jobs is going to overflow */
> > +  if ( the_period->postponed_jobs != UINT32_MAX ) {
> > +    ++the_period->postponed_jobs;
> >    the_period->state = RATE_MONOTONIC_EXPIRED;
> >    deadline = _Watchdog_Per_CPU_insert_relative(
> > @@ -85,6 +88,6 @@ void _Rate_monotonic_Timeout( Watchdog_Control
> *the_watchdog )
> >        _Thread_Unblock( owner );
> >    } else {
> > -    _Rate_monotonic_Renew_deadline( the_period, owner, &lock_context );
> > +    _Rate_monotonic_Renew_deadline( the_period, &lock_context );
> > diff --git a/testsuites/sptests/Makefile.am
> b/testsuites/sptests/Makefile.am
> > index 5ef87a0..11e9bcd 100644
> > --- a/testsuites/sptests/Makefile.am
> > +++ b/testsuites/sptests/Makefile.am
> > @@ -10,7 +10,7 @@ _SUBDIRS = \
> >      sp40 sp41 sp42 sp43 sp44 sp45 sp46 sp47 sp48 sp49 \
> >      sp50 sp51 sp52 sp53 sp54 sp55 sp56 sp57 sp58 sp59 \
> >      sp60      sp62 sp63 sp64 sp65 sp66 sp67 sp68 sp69 \
> > -    sp70 sp71 sp72 sp73 sp74 sp75 sp76 sp77 sp2038 \
> > +    sp70 sp71 sp72 sp73 sp74 sp75 sp76 sp77 sp78 sp2038 \
> >      spassoc01 spchain spcoverage spobjgetnext \
> >      spprintk spprivenv01 sprbtree01 spsize spstkalloc \
> >      spstkalloc02 spthreadq01 spwatchdog spwkspace \
> > diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/
> configure.ac
> > index 77ec512..a2af200 100644
> > --- a/testsuites/sptests/configure.ac
> > +++ b/testsuites/sptests/configure.ac
> > @@ -144,6 +144,7 @@ sp74/Makefile
> >  sp75/Makefile
> >  sp76/Makefile
> >  sp77/Makefile
> > +sp78/Makefile
> >  sp2038/Makefile
> >  spassoc01/Makefile
> >  spcbssched01/Makefile
> > diff --git a/testsuites/sptests/sp78/Makefile.am
> b/testsuites/sptests/sp78/Makefile.am
> > new file mode 100644
> > index 0000000..e814104
> > --- /dev/null
> > +++ b/testsuites/sptests/sp78/Makefile.am
> > @@ -0,0 +1,22 @@
> > +rtems_tests_PROGRAMS = sp78
> > +sp78_SOURCES = init.c ../../support/src/spin.c
> > +dist_rtems_tests_DATA = sp78.scn
> > +dist_rtems_tests_DATA += sp78.doc
> > +include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
> > +include $(top_srcdir)/../automake/compile.am
> > +include $(top_srcdir)/../automake/leaf.am
> > +AM_CPPFLAGS += -I$(top_srcdir)/../support/include
> > +LINK_OBJS = $(sp78_OBJECTS)
> > +LINK_LIBS = $(sp78_LDLIBS)
> > +sp78$(EXEEXT): $(sp78_OBJECTS) $(sp78_DEPENDENCIES)
> > +       @rm -f sp78$(EXEEXT)
> > +       $(make-exe)
> > +include $(top_srcdir)/../automake/local.am
> > diff --git a/testsuites/sptests/sp78/init.c b/testsuites/sptests/sp78/
> init.c
> > index 0000000..4d3f534
> > --- /dev/null
> > +++ b/testsuites/sptests/sp78/init.c
> > @@ -0,0 +1,120 @@
> > + *  COPYRIGHT (c) 2017 Kuan-Hsun Chen.
> > + *  The license and distribution terms for this file may be
> > + *  found in the file LICENSE in this distribution or at
> > + *  http://www.rtems.org/license/LICENSE.
> > +#ifdef HAVE_CONFIG_H
> > +#include "config.h"
> > +#endif
> > +#include <rtems/cpuuse.h>
> > +#include <tmacros.h>
> > +#include <rtems/rtems/ratemonimpl.h>
> > +#include "test_support.h"
> > +const char rtems_test_name[] = "SP 78";
> > +/* forward declarations to avoid warnings */
> > +rtems_task Init( rtems_task_argument argument );
> > +static void modify_count( rtems_id id );
> > +  rtems_id            id
> > +  Rate_monotonic_Control                  *the_period;
> > +  ISR_lock_Context                        lock_context;
> > +  the_period = _Rate_monotonic_Get( id, &lock_context );
> > +  _Rate_monotonic_Acquire_critical( the_period, &lock_context );
> > +  the_period->postponed_jobs = UINT32_MAX;
> > +  _Rate_monotonic_Release( the_period, &lock_context );
> > +rtems_task Init(
> > +  rtems_task_argument argument
> > +  rtems_id                                period_id;
> > +  rtems_name                              period_name;
> > +  rtems_rate_monotonic_period_status      period_status;
> > +  rtems_status_code                       status;
> > +  int                                     i;
> > +  period_name = rtems_build_name('P','E','R','1');
> > +  TEST_BEGIN();
> > +  /* create period */
> > +  status = rtems_rate_monotonic_create(
> > +      period_name,
> > +      &period_id
> > +  directive_failed( status, "rate_monotonic_create" );
> > +  /* modify the count to UINT32_MAX and attempt to miss deadline*/
> > +  puts( "Testing overflow condition" );
> > +  rtems_test_spin_until_next_tick();
> > +  status = rtems_rate_monotonic_period( period_id, 50 );
> > +  directive_failed( status, "rate_monotonic_period above loop" );
> > +  puts( "Modify the count of postponed_job manually" );
> > +  modify_count( period_id );
> > +  /* Check the status */
> > +  status = rtems_rate_monotonic_get_status( period_id, &period_status
> > +  directive_failed( status, "rate_monotonic_get_status" );
> > +  printf( "Init Postponed jobs = %"PRIu32", and expected %"PRIu32"\n",
> period_status.postponed_jobs_count, UINT32_MAX );
> > +  rtems_test_assert( period_status.postponed_jobs_count == UINT32_MAX
> > +  for ( i=1 ; i <= 2 ; i++ ) {
> > +    status = rtems_task_wake_after( 100 );
> > +    directive_failed( status, "rtems_task_wake_after(100)" );
> > +    puts( "Task misses its deadline." );
> &period_status );
> > +    /* print out the count which should keep in UINT32_MAX, since the
> period still misses its deadline */
> > +    printf( "Count = %"PRIu32", and expected %"PRIu32"\n",
> period_status.postponed_jobs_count, UINT32_MAX);
> UINT32_MAX);
> > +    fatal_directive_status(
> > +      status,
> > +      RTEMS_TIMEOUT,
> > +      "rtems_rate_monotonic_period 2-n"
> > +  TEST_END();
> > +  rtems_test_exit(0);
> > +/* configuration information */
> > +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> > +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> > +#define CONFIGURE_MILLISECONDS_PER_TICK 1
> > +#define CONFIGURE_MAXIMUM_TASKS             1
> > +#define CONFIGURE_MAXIMUM_PERIODS           1
> > +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
> > +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> > +#include <rtems/confdefs.h>
> > +/* end of file */
> > diff --git a/testsuites/sptests/sp78/sp78.doc b/testsuites/sptests/sp78/
> sp78.doc
> > index 0000000..ad64e4b
> > --- /dev/null
> > +++ b/testsuites/sptests/sp78/sp78.doc
> > @@ -0,0 +1,18 @@
> > +#  COPYRIGHT (c) 2017 Kuan-Hsun Chen.
> > +#  The license and distribution terms for this file may be
> > +#  found in the file LICENSE in this distribution or at
> > +#  http://www.rtems.org/license/LICENSE.
> > +This file describes the directives and concepts tested by this test set.
> > +test set name:  sp78
> > +directives:
> > +  rtems_rate_monotonic_get_status
> > +concepts:
> > ++ Test the overflow condition for postponed_jobs.
> > diff --git a/testsuites/sptests/sp78/sp78.scn b/testsuites/sptests/sp78/
> sp78.scn
> > index 0000000..4cb71db
> > --- /dev/null
> > +++ b/testsuites/sptests/sp78/sp78.scn
> > @@ -0,0 +1,9 @@
> > +*** BEGIN OF TEST SP 78 ***
> > +Testing overflow condition
> > +Modify the count of postponed_job manually
> > +Init Postponed jobs = 4294967295, and expected 4294967295
> > +Task misses its deadline.
> > +Count = 4294967295, and expected 4294967295
> > +*** END OF TEST SP 78 ***
> > 1.9.1
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170127/8addb413/attachment-0002.html>
