[PATCH] rtems: Revise tests: sprmsched01 and spedfsched04
Kuan Hsun Chen c0066c at gmail.com
Mon Jan 30 23:21:57 UTC 2017
By taking Sebastian's suggestions, I revise both tests.
Now the tests are independent to the target time and console driver.
Before I use time unit as second and the results rely on the absolute time.
Now I use rtems_test_spin_for_ticks() and downscale the timeunit from
second to 100ms.
Both tests only check if the overrun handling is correct or not by
using rtems_rate_monotonic_get_status() to check the count of postponed
jobs.
If they are correct, all the assertions are passed.
2017-01-31 0:15 GMT+01:00 Gedare Bloom <gedare at rtems.org>:
> Does this fix a deficiency in the current tests?
> On Mon, Jan 30, 2017 at 1:34 PM, Kuan-Hsun Chen <c0066c at gmail.com> wrote:
> > Instead of using the target time and console driver,
> > both tests now use assertions and rtems_rate_monotonic_get_status() to
> verify the count of postponed jobs.
> > The setting of spedfsched04 is slightly changed.
> > Update #2795
> >  testsuites/sptests/spedfsched04/Makefile.am      |  2 +-
> >  testsuites/sptests/spedfsched04/init.c           | 89
> >  testsuites/sptests/spedfsched04/spedfsched04.scn | 27 ++-----
> >  testsuites/sptests/sprmsched01/Makefile.am       |  4 +-
> >  testsuites/sptests/sprmsched01/init.c            | 74
> >  testsuites/sptests/sprmsched01/sprmsched01.scn   | 55 ++-------------
> >  6 files changed, 97 insertions(+), 154 deletions(-)
> > diff --git a/testsuites/sptests/spedfsched04/Makefile.am
> b/testsuites/sptests/spedfsched04/Makefile.am
> > index 39f8210..a39519a 100644
> > --- a/testsuites/sptests/spedfsched04/Makefile.am
> > +++ b/testsuites/sptests/spedfsched04/Makefile.am
> > @@ -1,6 +1,6 @@
> >  rtems_tests_PROGRAMS = spedfsched04
> > -spedfsched04_SOURCES = init.c
> > +spedfsched04_SOURCES = init.c ../../support/src/spin.c
> >  dist_rtems_tests_DATA = spedfsched04.scn
> >  dist_rtems_tests_DATA += spedfsched04.doc
> > diff --git a/testsuites/sptests/spedfsched04/init.c
> b/testsuites/sptests/spedfsched04/init.c
> > index f80883d..8dd93db 100644
> > --- a/testsuites/sptests/spedfsched04/init.c
> > +++ b/testsuites/sptests/spedfsched04/init.c
> > @@ -1,24 +1,25 @@
> > - * @brief A heuristic example to demonstrate how the postponed jobs are
> handled.
> > + * @brief A heuristic example to demonstrate how the postponed jobs are
> handled in EDF.
> >   * Given two tasks with implicit deadline under EDF policy.
> > - * Task 1 has (4, 5) and task 2 has (4, 6), where (execution time,
> period/deadline).
> > - * For the simplicity, we only execute the first task twice.
> > + * Task 1 has (400, 500) and task 2 has (450, 550), where (required
> ticks, period/deadline).
> > + * For the simplicity, we only execute the first task three times.
> >   * In the original implementation in v4.11, no matter how many periods
> are
> >   * expired, only one job will be released with a shifted deadline
> assignment.
> > - * In this example, the first job of task 2 will be blocked by the
> second job
> > - * of task 1, so that there at least one following job is postponed.
> > - * Due to overhead/delay, the second following job will be postponed as
> well.
> > + * In this example, task 2 will be blocked by the second and third jobs
> > + * of task 1, so that there are two jobs are postponed.
> > + * Due to the domino effects, the following jobs of task 2 will be
> postponed until Job 9.
> >   * If the overrun handling is correct, the period of task 2 changes
> back to
> > - * normal status at time 22.
> > - * Otherwise, the release time of job 3 is no longer periodic.
> > + * normal status at Job 9.
> > + * Otherwise, the release time of job 3 is no longer periodic
> > + * and there is no more postponed jobs.
> > - *  COPYRIGHT (c) 2016 Kuan-Hsun Chen.
> > + *  COPYRIGHT (c) 2016-2017 Kuan-Hsun Chen.
> >   *  The license and distribution terms for this file may be
> >   *  found in the file LICENSE in this distribution or at
> > @@ -30,23 +31,19 @@
> >  #endif
> >  #include <rtems/cpuuse.h>
> > -#include <rtems/counter.h>
> > -#include <stdio.h>
> > -#include <inttypes.h>
> > -#include "tmacros.h"
> > +#include <tmacros.h>
> > +#include "test_support.h"
> >  const char rtems_test_name[] = "SPEDFSCHED 4";
> > -static const uint32_t Periods[] = { 5000, 6000 };
> > -static const uint32_t Iterations[] = { 4000, 4000 };
> > +static const uint32_t Periods[] = { 500, 550 };
> > +static const uint32_t Iterations[] = { 400, 450 };
> >  static const rtems_name Task_name[] = {
> >    rtems_build_name( 'T', 'A', '1', ' ' ),
> >    rtems_build_name( 'T', 'A', '2', ' ' )
> >  static const rtems_task_priority Prio[3] = { 2, 5 };
> > -static const uint32_t testnumber = 11; /* stop condition */
> > +static const uint32_t testnumber = 9; /* stop condition */
> >  static uint32_t tsk_counter[] = { 0, 0 };
> >  static rtems_id   Task_id[ 2 ];
> > @@ -58,35 +55,42 @@ static rtems_task Task(
> >    rtems_task_argument argument
> > -  rtems_status_code status;
> > -  rtems_id    RM_period;
> > -  rtems_id    selfid=rtems_task_self();
> > -  uint32_t    start, end, flag=0, index;
> > -  rtems_counter_ticks t0;
> > +  rtems_status_code                         status;
> > +  rtems_id                                  RM_period;
> > +  rtems_id                                  selfid=rtems_task_self();
> > +  rtems_rate_monotonic_period_status        period_status;
> > +  uint32_t                                  flag=0;
> > -  t0 = rtems_counter_nanoseconds_to_ticks( 1000000 ); //1ms ticks
> counter
> > -  /*create period*/
> > +  /* create period */
> >    status = rtems_rate_monotonic_create( Task_name[ argument ],
> &RM_period );
> >    directive_failed( status, "rtems_rate_monotonic_create" );
> >    while ( FOREVER ) {
> >      status = rtems_rate_monotonic_period( RM_period, Periods[ argument
> > -    if( flag == 0 && status == RTEMS_TIMEOUT ){
> > -      flag = 1;
> > -      printf( "RTEMS_TIMEOUT\n" );
> > -    } else if ( flag == 1 && status == RTEMS_SUCCESSFUL ) {
> > -      flag = 0;
> > -      printf( "RTEMS_SUCCESSFUL\n" );
> > -    start = rtems_clock_get_ticks_since_boot();
> > -    printf( "Job %" PRIu32 " Task %" PRIuPTR " starts at tick %" PRIu32
> ".\n", tsk_counter[ argument ]+1, argument, start );
> > -    for( index = 0; index < Iterations[ argument ]; index++ ){
> > -      rtems_counter_delay_ticks( t0 );
> > -    end = rtems_clock_get_ticks_since_boot();
> > -    printf( "                                  Job %" PRIu32" Task %"
> PRIuPTR " ends at tick %" PRIu32".\n", tsk_counter[ argument ]+1, argument,
> end );
> > +    /* Do some work */
> > +    rtems_test_spin_for_ticks( Iterations[ argument ] );
> >      if( argument == 1 ){
> > +      if( status == RTEMS_TIMEOUT ){
> > +        if( flag == 0 ){
> > +          puts( "First time RTEMS_TIMEOUT" );
> > +          puts( "Task 2 should have 2 postponed job due to preemption."
> > +          rtems_test_assert( period_status.postponed_jobs_count == 2 );
> > +          flag = 1;
> > +      } else if ( flag == 1 && status == RTEMS_SUCCESSFUL ) {
> > +        puts( "RTEMS_SUCCESSFUL" );
> > +        puts( "Overrun handling is finished, now Task 2 becomes
> normal." );
> > +        rtems_test_assert( period_status.postponed_jobs_count == 0 );
> > +        flag = 0;
> > +      /* Check the status */
> > +      status = rtems_rate_monotonic_get_status( RM_period,
> &period_status );
> > +      directive_failed( status, "rate_monotonic_get_status" );
> > +      //printf( "Count = %"PRIu32"\n", period_status.postponed_jobs_
> count);
> >        if( tsk_counter[ argument ] == testnumber ){
> >          TEST_END();
> >          status = rtems_rate_monotonic_delete( RM_period );
> > @@ -97,7 +101,8 @@ static rtems_task Task(
> >      tsk_counter[ argument ]+=1;
> >      if ( argument == 0 ){
> > -      if( tsk_counter[ argument ] == 2 ){
> > +      if( tsk_counter[ argument ] == 3 ){
> > +        puts("Task 1 has released 3 jobs and finished.");
> >          directive_failed( status, "rtems_rate_monotonic_delete" );
> >          status = rtems_task_delete( selfid );
> > @@ -116,7 +121,6 @@ static rtems_task Init(
> >    TEST_BEGIN();
> > -  printf( "\nTicks per second in your system: %" PRIu32 "\n",
> rtems_clock_get_ticks_per_second() );
> >    /* Create two tasks */
> >    for ( index = 0; index < RTEMS_ARRAY_SIZE(Task_name); ++index ){
> > @@ -127,7 +131,6 @@ static rtems_task Init(
> >      directive_failed( status, "rtems_task_create loop" );
> >    /* After creating the periods for tasks, start to run them
> sequencially. */
> >      status = rtems_task_start( Task_id[ index ], Task, index);
> > @@ -139,7 +142,7 @@ static rtems_task Init(
> >  #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> >  #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> > -#define CONFIGURE_MICROSECONDS_PER_TICK     1000
> > +#define CONFIGURE_MICROSECONDS_PER_TICK     100
> >  #define CONFIGURE_MAXIMUM_TASKS             3
> >  #define CONFIGURE_MAXIMUM_PERIODS           2
> > diff --git a/testsuites/sptests/spedfsched04/spedfsched04.scn
> b/testsuites/sptests/spedfsched04/spedfsched04.scn
> > index 6d8060be..f1c41c4 100644
> > --- a/testsuites/sptests/spedfsched04/spedfsched04.scn
> > +++ b/testsuites/sptests/spedfsched04/spedfsched04.scn
> > @@ -1,24 +1,7 @@
> >  *** BEGIN OF TEST SPEDFSCHED 4 ***
> > -Ticks per second in your system: 1000
> > -Job 1 Task 1 starts at tick 14.
> > -                                        Job 1 Task 1 ends at tick 4023.
> > -Job 1 Task 2 starts at tick 4025.
> > -Job 2 Task 1 starts at tick 5013.
> > -                                        Job 2 Task 1 ends at tick 9023.
> > -                                        Job 1 Task 2 ends at tick 12045.
> > -System TIMEOUT
> > -Job 2 Task 2 starts at tick 12045.
> > -                                        Job 2 Task 2 ends at tick 16054.
> > -Job 3 Task 2 starts at tick 16054.
> > -                                        Job 3 Task 2 ends at tick 20061.
> > -System SUCCESSFUL
> > -Job 4 Task 2 starts at tick 22025.
> > -                                        Job 4 Task 2 ends at tick 26033.
> > -Job 5 Task 2 starts at tick 28025.
> > -                                        Job 5 Task 2 ends at tick 32033.
> > -Job 6 Task 2 starts at tick 34025.
> > -                                        Job 6 Task 2 ends at tick 38033.
> > +Task 1 has released 3 jobs and finished.
> > +First time RTEMS_TIMEOUT
> > +Task 2 should have 2 postponed job due to preemption.
> > +RTEMS_SUCCESSFUL
> > +Overrun handling is finished, now Task 2 becomes normal.
> >  *** END OF TEST SPEDFSCHED 4 ***
> > diff --git a/testsuites/sptests/sprmsched01/Makefile.am
> b/testsuites/sptests/sprmsched01/Makefile.am
> > index 068bb19..a8cf788 100644
> > --- a/testsuites/sptests/sprmsched01/Makefile.am
> > +++ b/testsuites/sptests/sprmsched01/Makefile.am
> > @@ -1,7 +1,7 @@
> >  rtems_tests_PROGRAMS = sprmsched01
> > -sprmsched01_SOURCES = init.c
> > +sprmsched01_SOURCES = init.c ../../support/src/spin.c
> >  dist_rtems_tests_DATA = sprmsched01.scn
> >  dist_rtems_tests_DATA += sprmsched01.doc
> > diff --git a/testsuites/sptests/sprmsched01/init.c b/testsuites/sptests/
> sprmsched01/init.c
> > index 2332920..6bc7ddd 100644
> > --- a/testsuites/sptests/sprmsched01/init.c
> > +++ b/testsuites/sptests/sprmsched01/init.c
> > @@ -1,5 +1,5 @@
> handled.
> handled in RMS.
> >   * Given two tasks with implicit deadline under fixed-priority
> scheudling.
> >   * Task 1 has (6, 10) and task 2 has (1, 2), where (execution time,
> deadline/period).
> > @@ -20,7 +20,7 @@
> > @@ -32,23 +32,19 @@
> >  #endif
> > -#include <stdio.h>
> >  const char rtems_test_name[] = "SPRMSCHED 1";
> > -static const uint32_t Periods[] = { 10000, 2000 };
> > -static const uint32_t Iterations[] = { 6000, 1000 };
> > +static const uint32_t Periods[] = { 1000, 200 };
> > +static const uint32_t Iterations[] = { 600, 100 };
> > @@ -60,13 +56,12 @@ static rtems_task Task(
> > +  uint32_t                                   flag=0;
> counter
> >    /*create period*/
> &RM_period );
> > @@ -74,26 +69,30 @@ static rtems_task Task(
> >    while ( FOREVER ) {
> >      //directive_failed( status, "rtems_rate_monotonic_period" ); let
> TIMEOUT pass
> > -    if( argument == 1 && flag == 0 && status == RTEMS_TIMEOUT ){
> > -      flag = 1;
> > -      flag = 0;
> > -    if ( argument == 1 )
> PRIu32 ".\n", tsk_counter[ argument ]+1, argument, start );
> > -    else
> > -      printf( "Task %" PRIuPTR " starts at tick %" PRIu32 ".\n",
> argument, start );
> end );
> > -      if( tsk_counter[ argument ] == testnumber ){
> > +        if( flag == 0 ){
> > +          puts( "Task 2 should have 3 postponed jobs due to
> preemption." );
> > +          rtems_test_assert( period_status.postponed_jobs_count == 3 );
> > +          flag = 1;
> normal." );
> > +        flag = 0;
> &period_status );
> > +      if( tsk_counter[ argument ] == testnumber ){
> >          TEST_END();
> > @@ -104,6 +103,7 @@ static rtems_task Task(
> > +        puts( "Task 1 has released two jobs" );
> > @@ -122,7 +122,7 @@ static rtems_task Init(
> >    TEST_BEGIN();
> > +  //printf( "\nTicks per second in your system: %" PRIu32 "\n",
> > @@ -145,7 +145,7 @@ static rtems_task Init(
> > diff --git a/testsuites/sptests/sprmsched01/sprmsched01.scn
> b/testsuites/sptests/sprmsched01/sprmsched01.scn
> > index 9205a59..e01712c 100644
> > --- a/testsuites/sptests/sprmsched01/sprmsched01.scn
> > +++ b/testsuites/sptests/sprmsched01/sprmsched01.scn
> > @@ -1,50 +1,7 @@
> > -*** BEGIN OF TEST Rate Monotonic 01 - Overrun Test ***
> > -Job 1 Task 1 starts at tick 13.
> > -                                        Job 1 Task 1 ends at tick 6021.
> > -Job 1 Task 2 starts at tick 6022.
> > -                                        Job 1 Task 2 ends at tick 7024.
> > -Job 2 Task 2 starts at tick 8022.
> > -                                        Job 2 Task 2 ends at tick 9023.
> > -Job 2 Task 1 starts at tick 10013.
> > -                                        Job 2 Task 1 ends at tick 16021.
> > -Job 3 Task 2 starts at tick 16023.
> > -                                        Job 3 Task 2 ends at tick 17024.
> > -RTEMS_TIMEOUT
> > -Job 4 Task 2 starts at tick 17025.
> > -                                        Job 4 Task 2 ends at tick 18026.
> > -Job 5 Task 2 starts at tick 18026.
> > -                                        Job 5 Task 2 ends at tick 19027.
> > -Job 6 Task 2 starts at tick 19028.
> > -                                        Job 6 Task 2 ends at tick 20029.
> > -Job 7 Task 2 starts at tick 20029.
> > -                                        Job 7 Task 2 ends at tick 21031.
> > -Job 8 Task 2 starts at tick 21031.
> > -                                        Job 8 Task 2 ends at tick 22033.
> > -Job 9 Task 2 starts at tick 22033.
> > -                                        Job 9 Task 2 ends at tick 23035.
> > +*** BEGIN OF TEST SPRMSCHED 1 ***
> > +Task 1 has released two jobs
> > +Task 2 should have 3 postponed jobs due to preemption.
> >  RTEMS_SUCCESSFUL
> > -Job 10 Task 2 starts at tick 24022.
> > -                                        Job 10 Task 2 ends at tick
> 25023.
> > -Job 11 Task 2 starts at tick 26022.
> > -                                        Job 11 Task 2 ends at tick
> 27024.
> > -Job 12 Task 2 starts at tick 28022.
> > -                                        Job 12 Task 2 ends at tick
> 29024.
> > -Job 13 Task 2 starts at tick 30022.
> > -                                        Job 13 Task 2 ends at tick
> 31023.
> > -Job 14 Task 2 starts at tick 32022.
> > -                                        Job 14 Task 2 ends at tick
> 33023.
> > -Job 15 Task 2 starts at tick 34022.
> > -                                        Job 15 Task 2 ends at tick
> 35023.
> > -Job 16 Task 2 starts at tick 36022.
> > -                                        Job 16 Task 2 ends at tick
> 37023.
> > -Period information by period
> > ---- CPU times are in seconds ---
> > ---- Wall times are in seconds ---
> > -   ID     OWNER COUNT MISSED          CPU TIME                  WALL
> TIME
> > -                                    MIN/MAX/AVG
> MIN/MAX/AVG
> > -0x42010002 TA2     15      6 1.001686/7.012146/2.404131
> 1.001698/13.013378/5.204723
> > -*** END OF TEST Rate Monotonic 01 ***
> > +*** END OF TEST SPRMSCHED 1 ***
> > 1.9.1
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170131/1aa6a5f6/attachment-0002.html>
