GSoC Mentors / Projects of Interest
Tue Jan 31 23:03:01 UTC 2017
On Tue, Jan 31, 2017 at 12:54 PM, Gedare Bloom <gedare at rtems.org> wrote:
> On Tue, Jan 31, 2017 at 12:21 PM, Tanu Hari Dixit <tokencolour at gmail.com>
> wrote:
> > Hello,
> > I created (https://devel.rtems.org/ticket/2891#ticket) on the lines of
> > Gedare's advice for this open project
> > (https://devel.rtems.org/wiki/Developer/Projects/Open/ImproveBeagleBSP).
> Looks nice, a few minor things:
> * You removed the "Introduction" section. Any reason or just an oversight?
> * The 'status' field is gone too. But, I think the status is not
> needed in the ticket format.
> Did you face any difficulties in making the transition? It would be
> good to document your workflow on the Open Projects page.
> > The link to buy USB-TTL FTDI Cable 3.3V on the open project page is
> > probably broken. What should I replace it with? Please tell if some
> See if you can find something appropriate on Google?
I knew I had bought at least one so went to Amazon to see what we
have here at OAR.
https://www.amazon.com/GearMo-Header-TTL-232R-3V3-Windows-Support/dp/B004LBXO2A
Other folks in the community may have alternatives. It is a pretty generic
piece of hardware. But there was that issue with the FTDI driver refusing
to work with cloned FTDI chips. So I would bet there are some out there
you don't want.
> > edit is needed and whether I should follow this pattern. Furthermore,
> > please indicate whether this project is of interest. Also which other
> > open projects should be converted to tickets?
> We should convert all of the open projects to tickets eventually. And
> then generate a report in the Open Projects page based on the tickets.
> I have done this for the BSP ones and found the following changes
> should be made in the workflow:
> * Use only one keyword. I prefer "SoC" so it is generic to other
> 'summer of code' style projects.
> * Use the components field to further categorize. We have some obvious
> ones for the subheadings now, such as 'bsps', 'libbsd', 'testing'.
> Others should be identified or else we can create new components if
> necessary. I'd like to stick with the current subheadings for this
> year's GSoC, but we can revise later.
> > Probably the community is interested in the idea to create simple
> > examples or sanity tests for all RTEMS directives so that they can be
> > included in the documentation (something that is user friendly). Also,
> > there was a thread titled 'Desirable Application Stacks (Add-On
> > Library Collections)' . Which ideas can be derived from there?
> > Regards,
> > Tanu Hari Dixit.
> > On Tue, Jan 31, 2017 at 4:52 AM, Joel Sherrill <joel at rtems.org> wrote:
> >> On Mon, Jan 30, 2017 at 5:13 PM, Gedare Bloom <gedare at rtems.org> wrote:
> >>> On Mon, Jan 30, 2017 at 12:25 PM, Tanu Hari Dixit <
> >>> wrote:
> >>> > I'll be glad to do it. Please guide me as to how to proceed.
> >>> We will need to import each existing Open Project description into a
> >>> new ticket. It would be best to start with one to "try it out". The
> >>> project title should be the Summary of the ticket, the text of the
> >>> project page should be converted into the Description of the ticket,
> >>> type should be Enhancement, Milestone "Indefinite", and put GSoC into
> >>> the keywords, and we might want to use some other keywords e.g. to
> >>> define the project type (e.g. one of: testing, ecosystem, kernel,
> >>> statistics, BSP, API, libbsd, languages, libraries). The owner should
> >>> be assigned to one of the mentors if indicated, with others in CC if
> >>> any, or else set blank.
> >> I agree it would be nice to get all the Open Project ideas as tickets
> and
> >> off the Wiki. Some of the ideas are likely no longer interesting/valid
> at
> >> this point and could just be deleted.
> >> FWIW I also want to move some of the Wiki content into Sphinx documents.
> >> I think being able to release them with RTEMS branches and use git
> >> for revision control.
> >> --joel
> >>> > On Mon, Jan 30, 2017 at 9:38 PM, Gedare Bloom <gedare at rtems.org>
> wrote:
> >>> >> Yes that would be much nicer. Maybe we can get potential GSoC
> Students
> >>> >> to do the work ;)
> >>> >> On Mon, Jan 30, 2017 at 1:40 AM, Sebastian Huber
> >>> >> <sebastian.huber at embedded-brains.de> wrote:
> >>> >> > Maybe we should move all this open projects wiki stuff into
> tickets
> >>> >> > with
> >>> >> > some sort of "GSoC" tag.
> >>> >> > Sebastian Huber, embedded brains GmbH
> >>> >> > Address : Dornierstr. 4, D-82178 Puchheim, Germany
> >>> >> > Phone   : +49 89 189 47 41-16
> >>> >> > Fax     : +49 89 189 47 41-09
> >>> >> > E-Mail  : sebastian.huber at embedded-brains.de
> >>> >> > PGP     : Public key available on request.
> >>> >> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des
> EHUG.
> >>> >> _______________________________________________
> >>> >> devel mailing list
> >>> >> devel at rtems.org
> >>> >> http://lists.rtems.org/mailman/listinfo/devel
> >>> devel mailing list
> >>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170131/aeda0fff/attachment-0002.html>
