[PATCH] Fix GDB build on ArchLinux
andreas.koelbl at st.oth-regensburg.de andreas.koelbl at st.oth-regensburg.de
Sat Jul 1 16:01:20 UTC 2017
From: Andreas Kölbl <andreas.koelbl at st.oth-regensburg.de>
Archlinux provides both, libguile v2.0 and v2.2. GDB states in
configuration its compatibility with both versions of libguile which is
false. The SCM_port interface of libguile was removed in v2.2 and
therefore breaks GDB as a user.
RTEMS does not use libguile and therefore it can be compiled without
support.
https://sourceware.org/bugzilla/show_bug.cgi?id=21104
Close #3054.
 source-builder/config/gdb-7-1.cfg | 1 +
 1 file changed, 1 insertion(+)
diff --git a/source-builder/config/gdb-7-1.cfg b/source-builder/config/gdb-7-1.cfg
index 21591b5..a045c3b 100644
--- a/source-builder/config/gdb-7-1.cfg
+++ b/source-builder/config/gdb-7-1.cfg
@@ -119,6 +119,7 @@ BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
     %{?gdb-sim-options:%{gdb-sim-options}} \
     --without-zlib \
     --with-expat \
+    --with-guile=no \
     %{!?without_python:%{with_python_option}} \
     --prefix=%{_prefix} --bindir=%{_bindir} \
     --exec-prefix=%{_exec_prefix} \
2.13.2
