LIBBSD
Mon Jul 3 05:46:53 UTC 2017
On 30/06/17 20:08, Kirspel, Kevin wrote:
> Case #2: Enable the RTEMS callout timer but do not call "callout_process()" (the timer service routine just resets the timer and quits) .
> IDLE Task CPUUSE: 93.144%
> TIME Task CPUUSE: 6.282%
In this case you have some low-level problem on your target. Is the
cache enabled and properly set up in the MMU? How many ticks per second
do you use?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
