[PATCH 06/10] rtems: Fix rtems_scheduler_remove_processor()
Thu Jul 6 13:36:45 UTC 2017
Account for the thread processor affinity and make sure that it is
possible to allocate a processor to each thread dedicated to a scheduler
instance.
Update #3059.
 cpukit/rtems/src/schedulerremoveprocessor.c | 12 ++++++++----
 1 file changed, 8 insertions(+), 4 deletions(-)
diff --git a/cpukit/rtems/src/schedulerremoveprocessor.c b/cpukit/rtems/src/schedulerremoveprocessor.c
index 538366bb22..06acacd158 100644
--- a/cpukit/rtems/src/schedulerremoveprocessor.c
+++ b/cpukit/rtems/src/schedulerremoveprocessor.c
@@ -45,7 +45,13 @@ static bool _Scheduler_Check_processor_removal(
   _Thread_Wait_acquire( the_thread, &queue_context );
   _Thread_State_acquire_critical( the_thread, &state_context );
-  if ( _Thread_Scheduler_get_home( the_thread ) == iter_context->scheduler ) {
+  if (
+    _Thread_Scheduler_get_home( the_thread ) == iter_context->scheduler
+      && !_Processor_mask_Has_overlap(
+        &the_thread->Scheduler.Affinity,
+        _Scheduler_Get_processors( iter_context->scheduler )
     iter_context->status = RTEMS_RESOURCE_IN_USE;
@@ -103,9 +109,7 @@ rtems_status_code rtems_scheduler_remove_processor(
   _Scheduler_Release_critical( scheduler, &lock_context );
   _ISR_lock_ISR_enable( &lock_context );
-  if ( processor_count == 0 ) {
-    _Thread_Iterate( _Scheduler_Check_processor_removal, &iter_context );
+  _Thread_Iterate( _Scheduler_Check_processor_removal, &iter_context );
   _ISR_lock_ISR_disable( &lock_context );
   _Scheduler_Acquire_critical( scheduler, &lock_context );
2.12.3
