[PATCH v2 03/15] score: Add some processor mask functions
Fri Jul 7 13:54:40 UTC 2017
Update #3059.
 cpukit/score/include/rtems/score/processormask.h | 99 ++++++++++++++++++++++++
 1 file changed, 99 insertions(+)
diff --git a/cpukit/score/include/rtems/score/processormask.h b/cpukit/score/include/rtems/score/processormask.h
index 27c35d38f1..b550aa42a9 100644
--- a/cpukit/score/include/rtems/score/processormask.h
+++ b/cpukit/score/include/rtems/score/processormask.h
@@ -59,6 +59,11 @@ RTEMS_INLINE_ROUTINE bool _Processor_mask_Is_zero( const Processor_mask *mask )
   return BIT_EMPTY( CPU_MAXIMUM_PROCESSORS, mask );
+RTEMS_INLINE_ROUTINE void _Processor_mask_Fill( Processor_mask *mask )
+  BIT_FILL( CPU_MAXIMUM_PROCESSORS, mask );
 RTEMS_INLINE_ROUTINE void _Processor_mask_Assign(
   Processor_mask *dst, const Processor_mask *src
@@ -91,6 +96,100 @@ RTEMS_INLINE_ROUTINE bool _Processor_mask_Is_set(
+ * @brief Returns true if the processor sets a and b are equal, and false
+ * otherwise.
+RTEMS_INLINE_ROUTINE bool _Processor_mask_Is_equal(
+  const Processor_mask *a,
+  const Processor_mask *b
+  return !BIT_CMP( CPU_MAXIMUM_PROCESSORS, a, b );
+ * @brief Returns true if the intersection of the processor sets a and b is
+ * non-empty, and false otherwise.
+RTEMS_INLINE_ROUTINE bool _Processor_mask_Has_overlap(
+  return BIT_OVERLAP( CPU_MAXIMUM_PROCESSORS, a, b );
+ * @brief Returns true if the processor set small is a subset of processor set
+ * big, and false otherwise.
+RTEMS_INLINE_ROUTINE bool _Processor_mask_Is_subset(
+  const Processor_mask *big,
+  const Processor_mask *small
+  return BIT_SUBSET( CPU_MAXIMUM_PROCESSORS, big, small );
+ * @brief Performs a bitwise a = b & c.
+RTEMS_INLINE_ROUTINE void _Processor_mask_And(
+  Processor_mask       *a,
+  const Processor_mask *b,
+  const Processor_mask *c
+  BIT_AND2( CPU_MAXIMUM_PROCESSORS, a, b, c );
+ * @brief Performs a bitwise a = b & ~c.
+RTEMS_INLINE_ROUTINE void _Processor_mask_Nand(
+  BIT_NAND2( CPU_MAXIMUM_PROCESSORS, a, b, c );
+ * @brief Performs a bitwise a = b | c.
+RTEMS_INLINE_ROUTINE void _Processor_mask_Or(
+  BIT_OR2( CPU_MAXIMUM_PROCESSORS, a, b, c );
+ * @brief Performs a bitwise a = b ^ c.
+RTEMS_INLINE_ROUTINE void _Processor_mask_Xor(
+  BIT_XOR2( CPU_MAXIMUM_PROCESSORS, a, b, c );
+RTEMS_INLINE_ROUTINE uint32_t _Processor_mask_Count( const Processor_mask *a )
+  return (uint32_t) BIT_COUNT( CPU_MAXIMUM_PROCESSORS, a );
+RTEMS_INLINE_ROUTINE uint32_t _Processor_mask_Find_last_set( const Processor_mask *a )
+  return (uint32_t) BIT_FLS( CPU_MAXIMUM_PROCESSORS, a );
  * @brief Returns the subset of 32 processors containing the specified index as
  * an unsigned 32-bit integer.
2.12.3
