[PATCH v2 13/15] score: Add simple affinity support to EDF SMP
Fri Jul 7 13:54:50 UTC 2017
Update #3059.
 cpukit/sapi/include/confdefs.h                     |   3 +-
 cpukit/sapi/include/rtems/scheduler.h              |   9 +-
 cpukit/score/include/rtems/score/scheduleredfsmp.h |  37 +-
 .../score/include/rtems/score/schedulersmpimpl.h   | 140 ++++++-
 cpukit/score/src/scheduleredfsmp.c                 | 461 +++++++++++++++++----
 cpukit/score/src/schedulerpriorityaffinitysmp.c    |   3 +-
 cpukit/score/src/schedulerprioritysmp.c            |   3 +-
 cpukit/score/src/schedulersimplesmp.c              |   3 +-
 cpukit/score/src/schedulersmpstartidle.c           |  22 +-
 cpukit/score/src/schedulerstrongapa.c              |   3 +-
 testsuites/smptests/Makefile.am                    |   2 +
 testsuites/smptests/configure.ac                   |   2 +
 testsuites/smptests/smpschededf01/init.c           |   4 +-
 testsuites/smptests/smpschededf02/Makefile.am      |  19 +
 testsuites/smptests/smpschededf02/init.c           | 383 +++++++++++++++++
 .../smptests/smpschededf02/smpschededf02.doc       |  11 +
 .../smptests/smpschededf02/smpschededf02.scn       |   0
 testsuites/smptests/smpschededf03/Makefile.am      |  19 +
 testsuites/smptests/smpschededf03/init.c           | 160 +++++++
 .../smptests/smpschededf03/smpschededf03.doc       |  12 +
 .../smptests/smpschededf03/smpschededf03.scn       |   2 +
 testsuites/smptests/smpscheduler07/init.c          |   2 +-
 22 files changed, 1190 insertions(+), 110 deletions(-)
 create mode 100644 testsuites/smptests/smpschededf02/Makefile.am
 create mode 100644 testsuites/smptests/smpschededf02/init.c
 create mode 100644 testsuites/smptests/smpschededf02/smpschededf02.doc
 create mode 100644 testsuites/smptests/smpschededf02/smpschededf02.scn
 create mode 100644 testsuites/smptests/smpschededf03/Makefile.am
 create mode 100644 testsuites/smptests/smpschededf03/init.c
 create mode 100644 testsuites/smptests/smpschededf03/smpschededf03.doc
 create mode 100644 testsuites/smptests/smpschededf03/smpschededf03.scn
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index 77b80d1cce..d01c927014 100755
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -992,7 +992,8 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
   #if !defined(CONFIGURE_SCHEDULER_CONTROLS)
     /** Configure the context needed by the scheduler instance */
-    #define CONFIGURE_SCHEDULER_CONTEXT RTEMS_SCHEDULER_CONTEXT_EDF_SMP(dflt)
+    #define CONFIGURE_SCHEDULER_CONTEXT \
+      RTEMS_SCHEDULER_CONTEXT_EDF_SMP(dflt, CONFIGURE_MAXIMUM_PROCESSORS)
     /** Configure the controls for this scheduler instance */
     #define CONFIGURE_SCHEDULER_CONTROLS \
diff --git a/cpukit/sapi/include/rtems/scheduler.h b/cpukit/sapi/include/rtems/scheduler.h
index fae0db4913..8684b798f7 100644
--- a/cpukit/sapi/include/rtems/scheduler.h
+++ b/cpukit/sapi/include/rtems/scheduler.h
@@ -99,12 +99,15 @@
   #define RTEMS_SCHEDULER_CONTEXT_EDF_SMP_NAME( name ) \
     RTEMS_SCHEDULER_CONTEXT_NAME( EDF_SMP_ ## name )
-  #define RTEMS_SCHEDULER_CONTEXT_EDF_SMP( name ) \
-    static Scheduler_EDF_SMP_Context RTEMS_SCHEDULER_CONTEXT_EDF_SMP_NAME( name )
+  #define RTEMS_SCHEDULER_CONTEXT_EDF_SMP( name, max_cpu_count ) \
+    static struct { \
+      Scheduler_EDF_SMP_Context Base; \
+      Scheduler_EDF_SMP_Ready_queue Ready[ ( max_cpu_count ) + 1 ]; \
+    } RTEMS_SCHEDULER_CONTEXT_EDF_SMP_NAME( name )
   #define RTEMS_SCHEDULER_CONTROL_EDF_SMP( name, obj_name ) \
-      &RTEMS_SCHEDULER_CONTEXT_EDF_SMP_NAME( name ).Base.Base, \
+      &RTEMS_SCHEDULER_CONTEXT_EDF_SMP_NAME( name ).Base.Base.Base, \
       SCHEDULER_EDF_SMP_ENTRY_POINTS, \
       SCHEDULER_EDF_MAXIMUM_PRIORITY, \
       ( obj_name ) \
diff --git a/cpukit/score/include/rtems/score/scheduleredfsmp.h b/cpukit/score/include/rtems/score/scheduleredfsmp.h
index 8f6e85777a..f0b71436bd 100644
--- a/cpukit/score/include/rtems/score/scheduleredfsmp.h
+++ b/cpukit/score/include/rtems/score/scheduleredfsmp.h
@@ -34,14 +34,24 @@ extern "C" {
 typedef struct {
-  Scheduler_SMP_Context Base;
-  RBTree_Control        Ready;
-} Scheduler_EDF_SMP_Context;
-typedef struct {
   Scheduler_SMP_Node Base;
+  uint64_t           generation;
+  uint32_t           ready_queue_index;
 } Scheduler_EDF_SMP_Node;
+typedef struct {
+  Chain_Node              Node;
+  RBTree_Control          Queue;
+  Scheduler_EDF_SMP_Node *scheduled;
+} Scheduler_EDF_SMP_Ready_queue;
+typedef struct {
+  Scheduler_SMP_Context         Base;
+  Chain_Control                 Affine_queues;
+  Scheduler_EDF_SMP_Ready_queue Ready[ RTEMS_ZERO_LENGTH_ARRAY ];
+} Scheduler_EDF_SMP_Context;
 #define SCHEDULER_EDF_SMP_ENTRY_POINTS \
     _Scheduler_EDF_SMP_Initialize, \
@@ -62,8 +72,8 @@ typedef struct {
     _Scheduler_EDF_Release_job, \
     _Scheduler_EDF_Cancel_job, \
     _Scheduler_default_Tick, \
-    _Scheduler_SMP_Start_idle \
-    SCHEDULER_OPERATION_DEFAULT_GET_SET_AFFINITY \
+    _Scheduler_EDF_SMP_Start_idle, \
+    _Scheduler_EDF_SMP_Set_affinity \
 void _Scheduler_EDF_SMP_Initialize( const Scheduler_Control *scheduler );
@@ -128,6 +138,19 @@ void _Scheduler_EDF_SMP_Yield(
   Scheduler_Node          *node
+void _Scheduler_EDF_SMP_Start_idle(
+  const Scheduler_Control *scheduler,
+  Thread_Control          *idle,
+  struct Per_CPU_Control  *cpu
+bool _Scheduler_EDF_SMP_Set_affinity(
+  Thread_Control          *thread,
+  Scheduler_Node          *node,
+  const Processor_mask    *affinity
 #ifdef __cplusplus
diff --git a/cpukit/score/include/rtems/score/schedulersmpimpl.h b/cpukit/score/include/rtems/score/schedulersmpimpl.h
index 620a42f863..3afa6b2a0c 100644
--- a/cpukit/score/include/rtems/score/schedulersmpimpl.h
+++ b/cpukit/score/include/rtems/score/schedulersmpimpl.h
@@ -7,7 +7,7 @@
- * Copyright (c) 2013, 2016 embedded brains GmbH.  All rights reserved.
+ * Copyright (c) 2013, 2017 embedded brains GmbH.  All rights reserved.
  *  embedded brains GmbH
  *  Dornierstr. 4
@@ -317,6 +317,12 @@ typedef void ( *Scheduler_SMP_Update )(
   Priority_Control   new_priority
+typedef void ( *Scheduler_SMP_Set_affinity )(
+  Scheduler_Context *context,
+  void              *arg
 typedef bool ( *Scheduler_SMP_Enqueue )(
   Scheduler_Node    *node_to_enqueue
@@ -329,6 +335,23 @@ typedef void ( *Scheduler_SMP_Allocate_processor )(
   Per_CPU_Control   *victim_cpu
+typedef void ( *Scheduler_SMP_Register_idle )(
+  Scheduler_Node    *idle,
+  Per_CPU_Control   *cpu
+static inline void _Scheduler_SMP_Do_nothing_register_idle(
+  (void) context;
+  (void) idle;
+  (void) cpu;
 static inline bool _Scheduler_SMP_Insert_priority_lifo_order(
   const Chain_Node *to_insert,
   const Chain_Node *next
@@ -903,6 +926,50 @@ static inline void _Scheduler_SMP_Schedule_highest_ready(
   } while ( action == SCHEDULER_TRY_TO_SCHEDULE_DO_BLOCK );
+static inline void _Scheduler_SMP_Preempt_and_schedule_highest_ready(
+  Scheduler_Node                   *victim,
+  Per_CPU_Control                  *victim_cpu,
+  Scheduler_SMP_Extract             extract_from_ready,
+  Scheduler_SMP_Get_highest_ready   get_highest_ready,
+  Scheduler_SMP_Move                move_from_ready_to_scheduled,
+  Scheduler_SMP_Allocate_processor  allocate_processor
+  Scheduler_Try_to_schedule_action action;
+  do {
+    Scheduler_Node *highest_ready = ( *get_highest_ready )( context, victim );
+    action = _Scheduler_Try_to_schedule_node(
+      context,
+      highest_ready,
+      NULL,
+      _Scheduler_SMP_Get_idle_thread
+    if ( action == SCHEDULER_TRY_TO_SCHEDULE_DO_SCHEDULE ) {
+      _Scheduler_SMP_Preempt(
+        context,
+        highest_ready,
+        victim,
+        allocate_processor
+      ( *move_from_ready_to_scheduled )( context, highest_ready );
+    } else {
+      _Assert( action == SCHEDULER_TRY_TO_SCHEDULE_DO_BLOCK );
+      _Scheduler_SMP_Node_change_state(
+        highest_ready,
+        SCHEDULER_SMP_NODE_BLOCKED
+      ( *extract_from_ready )( context, highest_ready );
+  } while ( action == SCHEDULER_TRY_TO_SCHEDULE_DO_BLOCK );
  * @brief Blocks a thread.
@@ -1274,11 +1341,34 @@ static inline void _Scheduler_SMP_Withdraw_node(
+static inline void _Scheduler_SMP_Do_start_idle(
+  Per_CPU_Control             *cpu,
+  Scheduler_SMP_Register_idle  register_idle
+  Scheduler_SMP_Context *self;
+  Scheduler_SMP_Node    *node;
+  self = _Scheduler_SMP_Get_self( context );
+  node = _Scheduler_SMP_Thread_get_node( idle );
+  _Scheduler_Thread_change_state( idle, THREAD_SCHEDULER_SCHEDULED );
+  node->state = SCHEDULER_SMP_NODE_SCHEDULED;
+  _Thread_Set_CPU( idle, cpu );
+  ( *register_idle )( context, &node->Base, cpu );
+  _Chain_Append_unprotected( &self->Scheduled, &node->Base.Node.Chain );
+  _Scheduler_SMP_Release_idle_thread( &self->Base, idle );
 static inline void _Scheduler_SMP_Add_processor(
-  Scheduler_Context       *context,
-  Thread_Control          *idle,
-  Scheduler_SMP_Has_ready  has_ready,
-  Scheduler_SMP_Enqueue    enqueue_scheduled_fifo
+  Scheduler_SMP_Has_ready      has_ready,
+  Scheduler_SMP_Enqueue        enqueue_scheduled_fifo,
@@ -1289,6 +1379,7 @@ static inline void _Scheduler_SMP_Add_processor(
   node = _Thread_Scheduler_get_home_node( idle );
   _Scheduler_SMP_Node_change_state( node, SCHEDULER_SMP_NODE_SCHEDULED );
+  ( *register_idle )( context, node, _Thread_Get_CPU( idle ) );
   if ( ( *has_ready )( &self->Base ) ) {
     ( *enqueue_scheduled_fifo )( &self->Base, node );
@@ -1355,6 +1446,45 @@ static inline Thread_Control *_Scheduler_SMP_Remove_processor(
   return idle;
+static inline void _Scheduler_SMP_Set_affinity(
+  void                            *arg,
+  Scheduler_SMP_Set_affinity       set_affinity,
+  Scheduler_SMP_Enqueue            enqueue_fifo,
+  Scheduler_SMP_Node_state node_state;
+  node_state = _Scheduler_SMP_Node_state( node );
+  if ( node_state == SCHEDULER_SMP_NODE_SCHEDULED ) {
+    _Scheduler_SMP_Extract_from_scheduled( node );
+    _Scheduler_SMP_Preempt_and_schedule_highest_ready(
+      context,
+      node,
+      _Thread_Get_CPU( thread ),
+      extract_from_ready,
+      get_highest_ready,
+      move_from_ready_to_scheduled,
+    ( *set_affinity )( context, node, arg );
+    ( *enqueue_fifo )( context, node );
+  } else if ( node_state == SCHEDULER_SMP_NODE_READY ) {
+    ( *extract_from_ready )( context, node );
+  } else {
 #ifdef __cplusplus
diff --git a/cpukit/score/src/scheduleredfsmp.c b/cpukit/score/src/scheduleredfsmp.c
index 644bf2f347..866977b169 100644
--- a/cpukit/score/src/scheduleredfsmp.c
+++ b/cpukit/score/src/scheduleredfsmp.c
@@ -21,13 +21,13 @@
 #include <rtems/score/scheduleredfsmp.h>
 #include <rtems/score/schedulersmpimpl.h>
-static Scheduler_EDF_SMP_Context *
+static inline Scheduler_EDF_SMP_Context *
 _Scheduler_EDF_SMP_Get_context( const Scheduler_Control *scheduler )
   return (Scheduler_EDF_SMP_Context *) _Scheduler_Get_context( scheduler );
 _Scheduler_EDF_SMP_Get_self( Scheduler_Context *context )
   return (Scheduler_EDF_SMP_Context *) context;
@@ -83,7 +83,8 @@ void _Scheduler_EDF_SMP_Initialize( const Scheduler_Control *scheduler )
     _Scheduler_EDF_SMP_Get_context( scheduler );
   _Scheduler_SMP_Initialize( &self->Base );
-  _RBTree_Initialize_empty( &self->Ready );
+  _Chain_Initialize_empty( &self->Affine_queues );
+  /* The ready queues are zero initialized and thus empty */
 void _Scheduler_EDF_SMP_Node_initialize(
@@ -99,7 +100,7 @@ void _Scheduler_EDF_SMP_Node_initialize(
   _Scheduler_SMP_Node_initialize( scheduler, smp_node, the_thread, priority );
-static void _Scheduler_EDF_SMP_Do_update(
+static inline void _Scheduler_EDF_SMP_Do_update(
@@ -113,112 +114,334 @@ static void _Scheduler_EDF_SMP_Do_update(
   _Scheduler_SMP_Node_update_priority( smp_node, new_priority );
-static bool _Scheduler_EDF_SMP_Has_ready( Scheduler_Context *context )
+static inline bool _Scheduler_EDF_SMP_Has_ready( Scheduler_Context *context )
   Scheduler_EDF_SMP_Context *self = _Scheduler_EDF_SMP_Get_self( context );
-  return !_RBTree_Is_empty( &self->Ready );
+  return !_RBTree_Is_empty( &self->Ready[ 0 ].Queue );
-static Scheduler_Node *_Scheduler_EDF_SMP_Get_highest_ready(
+static inline bool _Scheduler_EDF_SMP_Overall_less(
+  const Scheduler_EDF_SMP_Node *left,
+  const Scheduler_EDF_SMP_Node *right
+  Priority_Control lp;
+  Priority_Control rp;
+  lp = left->Base.priority;
+  rp = right->Base.priority;
+  return lp < rp || (lp == rp && left->generation < right->generation );
+static inline Scheduler_EDF_SMP_Node *
+_Scheduler_EDF_SMP_Challenge_highest_ready(
+  Scheduler_EDF_SMP_Context *self,
+  Scheduler_EDF_SMP_Node    *highest_ready,
+  RBTree_Control            *ready_queue
+  Scheduler_EDF_SMP_Node *other;
+  other = (Scheduler_EDF_SMP_Node *) _RBTree_Minimum( ready_queue );
+  _Assert( other != NULL );
+  if ( _Scheduler_EDF_SMP_Overall_less( other, highest_ready ) ) {
+    return other;
+  return highest_ready;
+static inline Scheduler_Node *_Scheduler_EDF_SMP_Get_highest_ready(
-  Scheduler_Node    *node
+  Scheduler_Node    *filter
-  Scheduler_EDF_SMP_Context *self = _Scheduler_EDF_SMP_Get_self( context );
-  Scheduler_Node *first = (Scheduler_Node *) _RBTree_Minimum( &self->Ready );
+  Scheduler_EDF_SMP_Context *self;
+  Scheduler_EDF_SMP_Node    *highest_ready;
+  Scheduler_EDF_SMP_Node    *node;
+  uint32_t                   rqi;
+  const Chain_Node          *tail;
+  Chain_Node                *next;
+  self = _Scheduler_EDF_SMP_Get_self( context );
+  highest_ready = (Scheduler_EDF_SMP_Node *)
+    _RBTree_Minimum( &self->Ready[ 0 ].Queue );
+  _Assert( highest_ready != NULL );
+   * The filter node is a scheduled node which is no longer on the scheduled
+   * chain.  In case this is an affine thread, then we have to check the
+   * corresponding affine ready queue.
+  node = (Scheduler_EDF_SMP_Node *) filter;
+  rqi = node->ready_queue_index;
+  if ( rqi != 0 && !_RBTree_Is_empty( &self->Ready[ rqi ].Queue ) ) {
+    highest_ready = _Scheduler_EDF_SMP_Challenge_highest_ready(
+      self,
+      highest_ready,
+      &self->Ready[ rqi ].Queue
+  tail = _Chain_Immutable_tail( &self->Affine_queues );
+  next = _Chain_First( &self->Affine_queues );
+  while ( next != tail ) {
+    Scheduler_EDF_SMP_Ready_queue *ready_queue;
+    ready_queue = (Scheduler_EDF_SMP_Ready_queue *) next;
+      self,
+      highest_ready,
+      &ready_queue->Queue
+    next = _Chain_Next( next );
+  return &highest_ready->Base.Base;
-  (void) node;
+static inline void _Scheduler_EDF_SMP_Set_scheduled(
+  Scheduler_EDF_SMP_Node    *scheduled,
+  const Per_CPU_Control     *cpu
+  self->Ready[ _Per_CPU_Get_index( cpu ) + 1 ].scheduled = scheduled;
+static inline Scheduler_EDF_SMP_Node *_Scheduler_EDF_SMP_Get_scheduled(
+  const Scheduler_EDF_SMP_Context *self,
+  uint32_t                         rqi
+  return self->Ready[ rqi ].scheduled;
+static inline Scheduler_Node *_Scheduler_EDF_SMP_Get_lowest_scheduled(
+  Scheduler_Node    *filter_base,
+  Chain_Node_order   order
+  Scheduler_EDF_SMP_Node *filter;
+  uint32_t                rqi;
+  filter = _Scheduler_EDF_SMP_Node_downcast( filter_base );
+  rqi = filter->ready_queue_index;
+  if ( rqi != 0 ) {
+    node = _Scheduler_EDF_SMP_Get_scheduled( self, rqi );
+    if ( node->ready_queue_index > 0 ) {
+      _Assert( node->ready_queue_index == rqi );
+      return &node->Base.Base;
+  return _Scheduler_SMP_Get_lowest_scheduled( context, filter_base, order );
-  _Assert( &first->Node != NULL );
+static inline void _Scheduler_EDF_SMP_Update_generation(
-  return first;
+  generation = self->generation;
+  node->generation = generation;
+  self->generation = generation + 1;
-static void _Scheduler_EDF_SMP_Move_from_scheduled_to_ready(
+static inline void _Scheduler_EDF_SMP_Keep_generation(
+  (void) self;
+  (void) node;
+static inline void _Scheduler_EDF_SMP_Insert_ready(
-  Scheduler_Node    *scheduled_to_ready
+  Scheduler_Node    *node_base,
+  void            ( *update_generation )(
+                       Scheduler_EDF_SMP_Context *,
+  bool            ( *less )( const void *, const RBTree_Node * )
-  Scheduler_EDF_SMP_Node *node =
-    _Scheduler_EDF_SMP_Node_downcast( scheduled_to_ready );
+  uint32_t                       rqi;
+  node = _Scheduler_EDF_SMP_Node_downcast( node_base );
+  ready_queue = &self->Ready[ rqi ];
-  _Chain_Extract_unprotected( &node->Base.Base.Node.Chain );
+  ( *update_generation )( self, node );
   _RBTree_Initialize_node( &node->Base.Base.Node.RBTree );
   _RBTree_Insert_inline(
-    &self->Ready,
+    &ready_queue->Queue,
     &node->Base.Base.Node.RBTree,
     &node->Base.priority,
-    _Scheduler_EDF_SMP_Less
+    less
+  if ( rqi != 0 && _Chain_Is_node_off_chain( &ready_queue->Node ) ) {
+    scheduled = _Scheduler_EDF_SMP_Get_scheduled( self, rqi );
+    if ( scheduled->ready_queue_index == 0 ) {
+      _Chain_Append_unprotected( &self->Affine_queues, &ready_queue->Node );
-static void _Scheduler_EDF_SMP_Move_from_ready_to_scheduled(
+static inline void _Scheduler_EDF_SMP_Extract_from_ready(
-  Scheduler_Node    *ready_to_scheduled
+  Scheduler_Node    *node_to_extract
-    _Scheduler_EDF_SMP_Node_downcast( ready_to_scheduled );
+  uint32_t                       rqi;
+  node = _Scheduler_EDF_SMP_Node_downcast( node_to_extract );
-  _RBTree_Extract( &self->Ready, &node->Base.Base.Node.RBTree );
+  _RBTree_Extract( &ready_queue->Queue, &node->Base.Base.Node.RBTree );
   _Chain_Initialize_node( &node->Base.Base.Node.Chain );
-  _Chain_Insert_ordered_unprotected(
-    &self->Base.Scheduled,
-    &node->Base.Base.Node.Chain,
-    _Scheduler_SMP_Insert_priority_fifo_order
+  if (
+    rqi != 0
+      && _RBTree_Is_empty( &ready_queue->Queue )
+      && !_Chain_Is_node_off_chain( &ready_queue->Node )
+    _Chain_Extract_unprotected( &ready_queue->Node );
+    _Chain_Set_off_chain( &ready_queue->Node );
+static inline void _Scheduler_EDF_SMP_Move_from_scheduled_to_ready(
+  Scheduler_Node    *scheduled_to_ready
+  _Chain_Extract_unprotected( &scheduled_to_ready->Node.Chain );
+  _Scheduler_EDF_SMP_Insert_ready(
+    context,
+    scheduled_to_ready,
+    _Scheduler_EDF_SMP_Update_generation,
+    _Scheduler_EDF_SMP_Less
-static void _Scheduler_EDF_SMP_Insert_ready_lifo(
+static inline void _Scheduler_EDF_SMP_Move_from_ready_to_scheduled(
-  Scheduler_Node    *node_to_insert
+  Scheduler_Node    *ready_to_scheduled
-    _Scheduler_EDF_SMP_Node_downcast( node_to_insert );
+  _Scheduler_EDF_SMP_Extract_from_ready( context, ready_to_scheduled );
+  _Scheduler_SMP_Insert_scheduled_fifo( context, ready_to_scheduled );
-  _RBTree_Initialize_node( &node->Base.Base.Node.RBTree );
-  _RBTree_Insert_inline(
-    &self->Ready,
-    &node->Base.Base.Node.RBTree,
-    &node->Base.priority,
+static inline void _Scheduler_EDF_SMP_Insert_ready_lifo(
+  Scheduler_Node    *node_to_insert
+    context,
+    node_to_insert,
+    _Scheduler_EDF_SMP_Keep_generation,
     _Scheduler_EDF_SMP_Less_or_equal
-static void _Scheduler_EDF_SMP_Insert_ready_fifo(
+static inline void _Scheduler_EDF_SMP_Insert_ready_fifo(
-    &self->Ready,
+    context,
+    node_to_insert,
-static void _Scheduler_EDF_SMP_Extract_from_ready(
+static inline void _Scheduler_EDF_SMP_Allocate_processor(
-  Scheduler_Node    *node_to_extract
+  Scheduler_Node    *scheduled_base,
+  Scheduler_Node    *victim_base,
-    _Scheduler_EDF_SMP_Node_downcast( node_to_extract );
-  _Chain_Initialize_node( &node->Base.Base.Node.Chain );
+  uint32_t                       rqi;
+  (void) victim_base;
+  scheduled = _Scheduler_EDF_SMP_Node_downcast( scheduled_base );
+  rqi = scheduled->ready_queue_index;
+  if ( rqi != 0 ) {
+    Per_CPU_Control               *desired_cpu;
+    if ( !_Chain_Is_node_off_chain( &ready_queue->Node ) ) {
+    desired_cpu = _Per_CPU_Get_by_index( rqi - 1 );
+    if ( victim_cpu != desired_cpu ) {
+      _Assert( node->ready_queue_index == 0 );
+      _Scheduler_EDF_SMP_Set_scheduled( self, node, victim_cpu );
+      _Scheduler_SMP_Allocate_processor_exact(
+        context,
+        &node->Base.Base,
+        NULL,
+        victim_cpu
+      victim_cpu = desired_cpu;
+  _Scheduler_EDF_SMP_Set_scheduled( self, scheduled, victim_cpu );
+    context,
+    &scheduled->Base.Base,
+    NULL,
+    victim_cpu
 void _Scheduler_EDF_SMP_Block(
@@ -236,11 +459,11 @@ void _Scheduler_EDF_SMP_Block(
     _Scheduler_EDF_SMP_Extract_from_ready,
     _Scheduler_EDF_SMP_Get_highest_ready,
     _Scheduler_EDF_SMP_Move_from_ready_to_scheduled,
-    _Scheduler_SMP_Allocate_processor_lazy
+    _Scheduler_EDF_SMP_Allocate_processor
-static bool _Scheduler_EDF_SMP_Enqueue_ordered(
+static inline bool _Scheduler_EDF_SMP_Enqueue_ordered(
   Chain_Node_order      order,
@@ -255,12 +478,12 @@ static bool _Scheduler_EDF_SMP_Enqueue_ordered(
     insert_ready,
     insert_scheduled,
     _Scheduler_EDF_SMP_Move_from_scheduled_to_ready,
-    _Scheduler_SMP_Get_lowest_scheduled,
+    _Scheduler_EDF_SMP_Get_lowest_scheduled,
-static bool _Scheduler_EDF_SMP_Enqueue_lifo(
+static inline bool _Scheduler_EDF_SMP_Enqueue_lifo(
@@ -274,7 +497,7 @@ static bool _Scheduler_EDF_SMP_Enqueue_lifo(
-static bool _Scheduler_EDF_SMP_Enqueue_fifo(
+static inline bool _Scheduler_EDF_SMP_Enqueue_fifo(
@@ -288,7 +511,7 @@ static bool _Scheduler_EDF_SMP_Enqueue_fifo(
-static bool _Scheduler_EDF_SMP_Enqueue_scheduled_ordered(
+static inline bool _Scheduler_EDF_SMP_Enqueue_scheduled_ordered(
@@ -305,11 +528,11 @@ static bool _Scheduler_EDF_SMP_Enqueue_scheduled_ordered(
     insert_ready,
     insert_scheduled,
-static bool _Scheduler_EDF_SMP_Enqueue_scheduled_lifo(
+static inline bool _Scheduler_EDF_SMP_Enqueue_scheduled_lifo(
@@ -323,7 +546,7 @@ static bool _Scheduler_EDF_SMP_Enqueue_scheduled_lifo(
-static bool _Scheduler_EDF_SMP_Enqueue_scheduled_fifo(
+static inline bool _Scheduler_EDF_SMP_Enqueue_scheduled_fifo(
@@ -354,7 +577,7 @@ void _Scheduler_EDF_SMP_Unblock(
-static bool _Scheduler_EDF_SMP_Do_ask_for_help(
+static inline bool _Scheduler_EDF_SMP_Do_ask_for_help(
   Thread_Control    *the_thread,
@@ -368,8 +591,8 @@ static bool _Scheduler_EDF_SMP_Do_ask_for_help(
     _Scheduler_EDF_SMP_Insert_ready_lifo,
     _Scheduler_SMP_Insert_scheduled_lifo,
@@ -439,10 +662,24 @@ void _Scheduler_EDF_SMP_Withdraw_node(
+static inline void _Scheduler_EDF_SMP_Register_idle(
+  Scheduler_Node    *idle_base,
+  Scheduler_EDF_SMP_Node    *idle;
+  idle = _Scheduler_EDF_SMP_Node_downcast( idle_base );
+  _Scheduler_EDF_SMP_Set_scheduled( self, idle, cpu );
 void _Scheduler_EDF_SMP_Add_processor(
@@ -454,7 +691,8 @@ void _Scheduler_EDF_SMP_Add_processor(
     context,
     idle,
     _Scheduler_EDF_SMP_Has_ready,
-    _Scheduler_EDF_SMP_Enqueue_scheduled_fifo
+    _Scheduler_EDF_SMP_Enqueue_scheduled_fifo,
+    _Scheduler_EDF_SMP_Register_idle
@@ -490,3 +728,78 @@ void _Scheduler_EDF_SMP_Yield(
+static inline void _Scheduler_EDF_SMP_Do_set_affinity(
+  void              *arg
+  const uint32_t         *rqi;
+  rqi = arg;
+  node->ready_queue_index = *rqi;
+  Scheduler_Context *context;
+  context = _Scheduler_Get_context( scheduler );
+  _Scheduler_SMP_Do_start_idle(
+    context,
+    idle,
+    cpu,
+  Processor_mask     a;
+  Processor_mask     b;
+  uint32_t           rqi;
+  _Processor_mask_And( &a, &context->Processors, affinity );
+  if ( _Processor_mask_Count( &a ) == 0 ) {
+    return false;
+  _Processor_mask_And( &b, &_SMP_Online_processors, affinity );
+  if ( _Processor_mask_Count( &b ) == _SMP_Processor_count ) {
+    rqi = 0;
+  } else {
+    rqi = _Processor_mask_Find_last_set( &a );
+  _Scheduler_SMP_Set_affinity(
+    context,
+    thread,
+    node,
+    &rqi,
+    _Scheduler_EDF_SMP_Do_set_affinity,
+    _Scheduler_EDF_SMP_Extract_from_ready,
+    _Scheduler_EDF_SMP_Get_highest_ready,
+    _Scheduler_EDF_SMP_Move_from_ready_to_scheduled,
+    _Scheduler_EDF_SMP_Enqueue_fifo,
+  return true;
diff --git a/cpukit/score/src/schedulerpriorityaffinitysmp.c b/cpukit/score/src/schedulerpriorityaffinitysmp.c
index 99938cdc56..c35883f142 100644
--- a/cpukit/score/src/schedulerpriorityaffinitysmp.c
+++ b/cpukit/score/src/schedulerpriorityaffinitysmp.c
@@ -579,7 +579,8 @@ void _Scheduler_priority_affinity_SMP_Add_processor(
     context,
     idle,
     _Scheduler_priority_SMP_Has_ready,
-    _Scheduler_priority_affinity_SMP_Enqueue_scheduled_fifo
+    _Scheduler_priority_affinity_SMP_Enqueue_scheduled_fifo,
+    _Scheduler_SMP_Do_nothing_register_idle
diff --git a/cpukit/score/src/schedulerprioritysmp.c b/cpukit/score/src/schedulerprioritysmp.c
index 5548ebf8e8..071a4218f3 100644
--- a/cpukit/score/src/schedulerprioritysmp.c
+++ b/cpukit/score/src/schedulerprioritysmp.c
@@ -323,7 +323,8 @@ void _Scheduler_priority_SMP_Add_processor(
     context,
     idle,
-    _Scheduler_priority_SMP_Enqueue_scheduled_fifo
+    _Scheduler_priority_SMP_Enqueue_scheduled_fifo,
diff --git a/cpukit/score/src/schedulersimplesmp.c b/cpukit/score/src/schedulersimplesmp.c
index 2884876381..4be43abff1 100644
--- a/cpukit/score/src/schedulersimplesmp.c
+++ b/cpukit/score/src/schedulersimplesmp.c
@@ -398,7 +398,8 @@ void _Scheduler_simple_SMP_Add_processor(
     context,
     idle,
     _Scheduler_simple_SMP_Has_ready,
-    _Scheduler_simple_SMP_Enqueue_scheduled_fifo
+    _Scheduler_simple_SMP_Enqueue_scheduled_fifo,
diff --git a/cpukit/score/src/schedulersmpstartidle.c b/cpukit/score/src/schedulersmpstartidle.c
index d396a159fe..bdb1b47876 100644
--- a/cpukit/score/src/schedulersmpstartidle.c
+++ b/cpukit/score/src/schedulersmpstartidle.c
@@ -1,5 +1,5 @@
  * The license and distribution terms for this file may be
  * found in the file LICENSE in this distribution or at
@@ -18,18 +18,12 @@ void _Scheduler_SMP_Start_idle(
-  Scheduler_Context     *context;
-  Scheduler_SMP_Context *self;
-  Scheduler_SMP_Node    *node;
+  Scheduler_Context *context = _Scheduler_Get_context( scheduler );
-  context = _Scheduler_Get_context( scheduler );
-  self = _Scheduler_SMP_Get_self( context );
-  node = _Scheduler_SMP_Thread_get_node( idle );
-  _Scheduler_Thread_change_state( idle, THREAD_SCHEDULER_SCHEDULED );
-  node->state = SCHEDULER_SMP_NODE_SCHEDULED;
-  _Thread_Set_CPU( idle, cpu );
-  _Chain_Append_unprotected( &self->Scheduled, &node->Base.Node.Chain );
-  _Scheduler_SMP_Release_idle_thread( &self->Base, idle );
+    context,
+    idle,
+    cpu,
diff --git a/cpukit/score/src/schedulerstrongapa.c b/cpukit/score/src/schedulerstrongapa.c
index f6313584f6..d5bfed74f4 100644
--- a/cpukit/score/src/schedulerstrongapa.c
+++ b/cpukit/score/src/schedulerstrongapa.c
@@ -457,7 +457,8 @@ void _Scheduler_strong_APA_Add_processor(
     context,
     idle,
     _Scheduler_strong_APA_Has_ready,
-    _Scheduler_strong_APA_Enqueue_scheduled_fifo
+    _Scheduler_strong_APA_Enqueue_scheduled_fifo,
diff --git a/testsuites/smptests/Makefile.am b/testsuites/smptests/Makefile.am
index 01dc52e524..40f0b0fd7a 100644
--- a/testsuites/smptests/Makefile.am
+++ b/testsuites/smptests/Makefile.am
@@ -36,6 +36,8 @@ _SUBDIRS += smpschedaffinity03
 _SUBDIRS += smpschedaffinity04
 _SUBDIRS += smpschedaffinity05
 _SUBDIRS += smpschededf01
+_SUBDIRS += smpschededf02
+_SUBDIRS += smpschededf03
 _SUBDIRS += smpschedsem01
 _SUBDIRS += smpscheduler01
 _SUBDIRS += smpscheduler02
diff --git a/testsuites/smptests/configure.ac b/testsuites/smptests/configure.ac
index f3a840b593..d72f6e072d 100644
--- a/testsuites/smptests/configure.ac
+++ b/testsuites/smptests/configure.ac
@@ -91,6 +91,8 @@ smpschedaffinity03/Makefile
 smpschedaffinity04/Makefile
 smpschedaffinity05/Makefile
 smpschededf01/Makefile
+smpschededf02/Makefile
+smpschededf03/Makefile
 smpschedsem01/Makefile
 smpscheduler01/Makefile
 smpscheduler02/Makefile
diff --git a/testsuites/smptests/smpschededf01/init.c b/testsuites/smptests/smpschededf01/init.c
index c1c995e69b..6b250cf699 100644
--- a/testsuites/smptests/smpschededf01/init.c
+++ b/testsuites/smptests/smpschededf01/init.c
@@ -140,11 +140,13 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_TASKS 3
 #define CONFIGURE_MAXIMUM_PERIODS 2
+#define CONFIGURE_MAXIMUM_PROCESSORS 1
 #define CONFIGURE_SCHEDULER_EDF_SMP
 #include <rtems/scheduler.h>
-RTEMS_SCHEDULER_CONTEXT_EDF_SMP(a);
+RTEMS_SCHEDULER_CONTEXT_EDF_SMP(a, CONFIGURE_MAXIMUM_PROCESSORS);
   RTEMS_SCHEDULER_CONTROL_EDF_SMP(a, rtems_build_name('E', 'D', 'F', ' '))
diff --git a/testsuites/smptests/smpschededf02/Makefile.am b/testsuites/smptests/smpschededf02/Makefile.am
new file mode 100644
index 0000000000..6e9e01cb60
--- /dev/null
+++ b/testsuites/smptests/smpschededf02/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = smpschededf02
+smpschededf02_SOURCES = init.c
+dist_rtems_tests_DATA = smpschededf02.scn smpschededf02.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(smpschededf02_OBJECTS)
+LINK_LIBS = $(smpschededf02_LDLIBS)
+smpschededf02$(EXEEXT): $(smpschededf02_OBJECTS) $(smpschededf02_DEPENDENCIES)
+	@rm -f smpschededf02$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/smptests/smpschededf02/init.c b/testsuites/smptests/smpschededf02/init.c
index 0000000000..e0c5182f2e
--- /dev/null
+++ b/testsuites/smptests/smpschededf02/init.c
@@ -0,0 +1,383 @@
+ * Copyright (c) 2016, 2017 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+#ifdef HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include "tmacros.h"
+#include <rtems.h>
+const char rtems_test_name[] = "SMPSCHEDEDF 2";
+#define CPU_COUNT 2
+#define TASK_COUNT 5
+#define P(i) (UINT32_C(2) + i)
+#define A(cpu0, cpu1) ((cpu1 << 1) | cpu0)
+#define IDLE UINT8_C(255)
+#define NAME rtems_build_name('E', 'D', 'F', ' ')
+typedef struct {
+  enum {
+    KIND_RESET,
+    KIND_SET_PRIORITY,
+    KIND_SET_AFFINITY,
+    KIND_BLOCK,
+    KIND_UNBLOCK
+  } kind;
+  size_t index;
+  struct {
+    rtems_task_priority priority;
+    uint32_t cpu_set;
+  } data;
+  uint8_t expected_cpu_allocations[CPU_COUNT];
+} test_action;
+typedef struct {
+  rtems_id timer_id;
+  rtems_id master_id;
+  rtems_id task_ids[TASK_COUNT];
+  size_t action_index;
+} test_context;
+#define RESET \
+    KIND_RESET, \
+    0, \
+    { 0 }, \
+    { IDLE, IDLE } \
+#define SET_PRIORITY(index, prio, cpu0, cpu1) \
+    KIND_SET_PRIORITY, \
+    index, \
+    { .priority = prio }, \
+    { cpu0, cpu1 } \
+#define SET_AFFINITY(index, aff, cpu0, cpu1) \
+    KIND_SET_AFFINITY, \
+    index, \
+    { .cpu_set = aff }, \
+    { cpu0, cpu1 } \
+#define BLOCK(index, cpu0, cpu1) \
+    KIND_BLOCK, \
+    index, \
+    { 0 }, \
+    { cpu0, cpu1 } \
+#define UNBLOCK(index, cpu0, cpu1) \
+    KIND_UNBLOCK, \
+    index, \
+    { 0 }, \
+    { cpu0, cpu1 } \
+static const test_action test_actions[] = {
+  RESET,
+  UNBLOCK(      0,              0, IDLE),
+  UNBLOCK(      1,              0,    1),
+  UNBLOCK(      3,              0,    1),
+  SET_PRIORITY( 1,  P(2),       0,    1),
+  SET_PRIORITY( 3,  P(1),       0,    3),
+  BLOCK(        3,              0,    1),
+  SET_AFFINITY( 1,  A(1, 1),    0,    1),
+  SET_AFFINITY( 1,  A(1, 0),    1,    0),
+  SET_AFFINITY( 1,  A(1, 1),    1,    0),
+  SET_AFFINITY( 1,  A(0, 1),    0,    1),
+  BLOCK(        0,           IDLE,    1),
+  UNBLOCK(      0,              0,    1),
+  BLOCK(        1,              0, IDLE),
+  RESET,
+   * Show that FIFO order is honoured across all threads of the same priority.
+  SET_PRIORITY( 1,  P(0),    IDLE, IDLE),
+  SET_PRIORITY( 2,  P(1),    IDLE, IDLE),
+  SET_PRIORITY( 3,  P(1),    IDLE, IDLE),
+  SET_AFFINITY( 3,  A(1, 0), IDLE, IDLE),
+  SET_PRIORITY( 4,  P(1),    IDLE, IDLE),
+  SET_AFFINITY( 4,  A(1, 0), IDLE, IDLE),
+  UNBLOCK(      2,              0,    1),
+  UNBLOCK(      4,              0,    1),
+  BLOCK(        1,              0,    2),
+  BLOCK(        2,              3,    0),
+  BLOCK(        3,              4,    0),
+  RESET,
+   * Schedule a high priority affine thread directly with a low priority affine
+   * thread in the corresponding ready queue.  In this case we, remove the
+   * affine ready queue in _Scheduler_EDF_SMP_Allocate_processor().
+  SET_AFFINITY( 3,  A(0, 1),    0,    1),
+  SET_PRIORITY( 2,  P(1),       0,    1),
+  SET_AFFINITY( 2,  A(0, 1),    0,    1),
+  UNBLOCK(      2,              0,    2),
+  BLOCK(        1,              0,    2),
+  BLOCK(        2,              0,    3),
+  RESET
+static test_context test_instance;
+static void set_priority(rtems_id id, rtems_task_priority prio)
+  rtems_status_code sc;
+  sc = rtems_task_set_priority(id, prio, &prio);
+  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+static void set_affinity(rtems_id id, uint32_t cpu_set_32)
+  cpu_set_t cpu_set;
+  size_t i;
+  CPU_ZERO(&cpu_set);
+  for (i = 0; i < CPU_COUNT; ++i) {
+    if ((cpu_set_32 & (UINT32_C(1) << i)) != 0) {
+      CPU_SET(i, &cpu_set);
+  sc = rtems_task_set_affinity(id, sizeof(cpu_set), &cpu_set);
+static void reset(test_context *ctx)
+  size_t i;
+  for (i = 0; i < TASK_COUNT; ++i) {
+    set_priority(ctx->task_ids[i], P(i));
+    set_affinity(ctx->task_ids[i], A(1, 1));
+  for (i = CPU_COUNT; i < TASK_COUNT; ++i) {
+    sc = rtems_task_suspend(ctx->task_ids[i]);
+    rtems_test_assert(sc == RTEMS_SUCCESSFUL || sc == RTEMS_ALREADY_SUSPENDED);
+    sc = rtems_task_resume(ctx->task_ids[i]);
+    rtems_test_assert(sc == RTEMS_SUCCESSFUL || sc == RTEMS_INCORRECT_STATE);
+  /* Order the idle threads explicitly */
+    const Per_CPU_Control *c;
+    const Thread_Control *h;
+    c = _Per_CPU_Get_by_index(CPU_COUNT - 1 - i);
+    h = c->heir;
+    sc = rtems_task_suspend(h->Object.id);
+static void check_cpu_allocations(test_context *ctx, const test_action *action)
+  size_t i;
+    size_t e;
+    e = action->expected_cpu_allocations[i];
+    c = _Per_CPU_Get_by_index(i);
+    h = c->heir;
+    if (e != IDLE) {
+      rtems_test_assert(h->Object.id == ctx->task_ids[e]);
+    } else {
+      rtems_test_assert(h->is_idle);
+ * Use a timer to execute the actions, since it runs with thread dispatching
+ * disabled.  This is necessary to check the expected processor allocations.
+static void timer(rtems_id id, void *arg)
+  test_context *ctx;
+  size_t i;
+  ctx = arg;
+  i = ctx->action_index;
+  if (i == 0) {
+    sc = rtems_task_suspend(ctx->master_id);
+  if (i < RTEMS_ARRAY_SIZE(test_actions)) {
+    const test_action *action = &test_actions[i];
+    rtems_id task;
+    ctx->action_index = i + 1;
+    task = ctx->task_ids[action->index];
+    switch (action->kind) {
+      case KIND_SET_PRIORITY:
+        set_priority(task, action->data.priority);
+        break;
+      case KIND_SET_AFFINITY:
+        set_affinity(task, action->data.cpu_set);
+        break;
+      case KIND_BLOCK:
+        sc = rtems_task_suspend(task);
+        break;
+      case KIND_UNBLOCK:
+        sc = rtems_task_resume(task);
+        break;
+      default:
+        rtems_test_assert(action->kind == KIND_RESET);
+        reset(ctx);
+        break;
+    check_cpu_allocations(ctx, action);
+    sc = rtems_timer_reset(id);
+  } else {
+    sc = rtems_task_resume(ctx->master_id);
+    sc = rtems_event_transient_send(ctx->master_id);
+static void do_nothing_task(rtems_task_argument arg)
+  (void) arg;
+  while (true) {
+    /* Do nothing */
+static void test(void)
+  size_t i;
+  ctx = &test_instance;
+  ctx->master_id = rtems_task_self();
+    sc = rtems_task_create(
+      NAME,
+      P(i),
+      RTEMS_MINIMUM_STACK_SIZE,
+      RTEMS_DEFAULT_MODES,
+      RTEMS_DEFAULT_ATTRIBUTES,
+      &ctx->task_ids[i]
+    sc = rtems_task_start(ctx->task_ids[i], do_nothing_task, 0);
+  sc = rtems_timer_create(NAME, &ctx->timer_id);
+  sc = rtems_timer_fire_after(ctx->timer_id, 1, timer, ctx);
+  sc = rtems_event_transient_receive(RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+    sc = rtems_task_delete(ctx->task_ids[i]);
+  sc = rtems_timer_delete(ctx->timer_id);
+static void Init(rtems_task_argument arg)
+  TEST_BEGIN();
+  if (rtems_get_processor_count() == CPU_COUNT) {
+    test();
+  } else {
+    puts("warning: wrong processor count to run the test");
+  TEST_END();
+  rtems_test_exit(0);
+#define CONFIGURE_MICROSECONDS_PER_TICK 1000
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS (1 + TASK_COUNT)
+#define CONFIGURE_MAXIMUM_TIMERS 1
+#define CONFIGURE_MAXIMUM_PROCESSORS CPU_COUNT
+#define CONFIGURE_SCHEDULER_EDF_SMP
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/smptests/smpschededf02/smpschededf02.doc b/testsuites/smptests/smpschededf02/smpschededf02.doc
index 0000000000..ece0e1a20e
--- /dev/null
+++ b/testsuites/smptests/smpschededf02/smpschededf02.doc
@@ -0,0 +1,11 @@
+This file describes the directives and concepts tested by this test set.
+test set name: smpschededf02
+directives:
+  TBD
+concepts:
+  TBD
diff --git a/testsuites/smptests/smpschededf02/smpschededf02.scn b/testsuites/smptests/smpschededf02/smpschededf02.scn
index 0000000000..e69de29bb2
diff --git a/testsuites/smptests/smpschededf03/Makefile.am b/testsuites/smptests/smpschededf03/Makefile.am
index 0000000000..e3496f50aa
--- /dev/null
+++ b/testsuites/smptests/smpschededf03/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = smpschededf03
+smpschededf03_SOURCES = init.c
+dist_rtems_tests_DATA = smpschededf03.scn smpschededf03.doc
+LINK_OBJS = $(smpschededf03_OBJECTS)
+LINK_LIBS = $(smpschededf03_LDLIBS)
+smpschededf03$(EXEEXT): $(smpschededf03_OBJECTS) $(smpschededf03_DEPENDENCIES)
+	@rm -f smpschededf03$(EXEEXT)
+	$(make-exe)
diff --git a/testsuites/smptests/smpschededf03/init.c b/testsuites/smptests/smpschededf03/init.c
index 0000000000..33029532c6
--- /dev/null
+++ b/testsuites/smptests/smpschededf03/init.c
@@ -0,0 +1,160 @@
+ * Copyright (c) 2017 embedded brains GmbH.  All rights reserved.
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#include "config.h"
+#endif
+#include <rtems.h>
+const char rtems_test_name[] = "SMPSCHEDEDF 3";
+#define CPU_COUNT 32
+#define TASK_COUNT (3 * CPU_COUNT)
+typedef struct {
+} test_context;
+static void wait_task(rtems_task_argument arg)
+  (void) arg;
+  while (true) {
+    sc = rtems_task_wake_after(1);
+static uint32_t simple_random(uint32_t v)
+  v *= 1664525;
+  v += 1013904223;
+  return v;
+static void affinity_task(rtems_task_argument arg)
+  uint32_t v;
+  uint32_t n;
+  v = (uint32_t) arg;
+  n = rtems_get_processor_count();
+  while (true) {
+    cpu_set_t set;
+    CPU_ZERO(&set);
+    CPU_SET((v >> 13) % n, &set);
+    v = simple_random(v);
+    sc = rtems_task_set_affinity(RTEMS_SELF, sizeof(set), &set);
+static void create_and_start_task(
+  test_context *ctx,
+  rtems_task_entry entry,
+  size_t i,
+  size_t j
+  j = j * CPU_COUNT + i;
+    rtems_build_name('E', 'D', 'F', ' '),
+    i + 2,
+    &ctx->task_ids[j]
+  sc = rtems_task_start(ctx->task_ids[j], entry, j);
+static void delete_task(
+  size_t i,
+  size_t j
+  sc = rtems_task_delete(ctx->task_ids[j]);
+static void test(test_context *ctx)
+  size_t i;
+    create_and_start_task(ctx, wait_task, i, 0);
+    create_and_start_task(ctx, affinity_task, i, 1);
+    create_and_start_task(ctx, affinity_task, i, 2);
+  sc = rtems_task_wake_after(10 * rtems_clock_get_ticks_per_second());
+    delete_task(ctx, i, 0);
+    delete_task(ctx, i, 1);
+    delete_task(ctx, i, 2);
+  TEST_BEGIN();
+  test(&test_instance);
+  TEST_END();
diff --git a/testsuites/smptests/smpschededf03/smpschededf03.doc b/testsuites/smptests/smpschededf03/smpschededf03.doc
index 0000000000..1d11c42b21
--- /dev/null
+++ b/testsuites/smptests/smpschededf03/smpschededf03.doc
@@ -0,0 +1,12 @@
+test set name: smpschededf03
+directives:
+  - EDF SMP scheduler operations.
+concepts:
+  - Randomized test case to show some stability of simple thread processor
+    affinity support of the EDF SMP scheduler.
diff --git a/testsuites/smptests/smpschededf03/smpschededf03.scn b/testsuites/smptests/smpschededf03/smpschededf03.scn
index 0000000000..1435f03920
--- /dev/null
+++ b/testsuites/smptests/smpschededf03/smpschededf03.scn
@@ -0,0 +1,2 @@
+*** BEGIN OF TEST SMPSCHEDEDF 3 ***
+*** END OF TEST SMPSCHEDEDF 3 ***
diff --git a/testsuites/smptests/smpscheduler07/init.c b/testsuites/smptests/smpscheduler07/init.c
index cbffe89012..bb065b3844 100644
--- a/testsuites/smptests/smpscheduler07/init.c
+++ b/testsuites/smptests/smpscheduler07/init.c
@@ -32,7 +32,7 @@ const char rtems_test_name[] = "SMPSCHEDULER 7";
   RTEMS_SCHEDULER_CONTROL_EDF_SMP( a, rtems_build_name('T', 'E', 'S', 'T'))
2.12.3
