Interrupts strange behavior on RISC-V
Denis Obrezkov denisobrezkov at gmail.com
Sat Jul 8 15:09:54 UTC 2017
Hello all,
I worked with local interrupts last few days and found some strange
behavior:
I am trying to handle local interrupts.
That's what I do, in my handler for timer interrupts:
* disable timer interrupts in mie
* read a current value from mtime
* copy it to mtimecmp (both are 64bit width types)
* add some big value to mtimecmp
* enable timer interrupts in mie.
And I have two boards and the problem is that on one of them interrupts are
permanently generated because mip register is always 1 in mtip position,
though mtimecmp is greater than mtime, and are not generated at all on the
other.
In this piece of code, I turn on interrupts:
la t0, RISCV_Exception_default
csrs mtvec, t0
li t0, 0x88
csrs mie, t0
csrsi mstatus, 0x8
My start file:
https://github.com/embeddedden/rtems-riscv/blob/hifive1/c/src/lib/libbsp/riscv32/hifive1/start/start.S
and ISR:
https://github.com/embeddedden/rtems-riscv/blob/hifive1/c/src/lib/libbsp/riscv32/hifive1/irq/irq.c
I also posted this question here:
https://forums.sifive.com/t/how-to-deal-with-local-interrupts-in-hifive1/632
Regards, Denis Obrezkov
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170708/68a54fa8/attachment.html>
