Interrupts strange behavior on RISC-V
Hesham Almatary heshamelmatary at gmail.com
Sun Jul 9 04:25:27 UTC 2017
On Sun, Jul 9, 2017 at 10:46 AM, Joel Sherrill <joel at rtems.org> wrote:
> Yeah!!
> Does this mean you have a ticker variant working now? With polled console
> IO?
> I ask because that is a nice capability merge point. When merged, you move
> from a large submission to review to smaller more incremental ones. Easier
> to review, etc.
+1
> On Jul 8, 2017 7:30 PM, "Denis Obrezkov" <denisobrezkov at gmail.com> wrote:
>> I found the problem, I made a mistake in my code, instead of:
>> if ((cause & MCAUSE_MTIME) == MCAUSE_MTIME) {
>> I have written:
>> if (cause & MCAUSE_MTIME) {
>> now local interrupts work.
>> 2017-07-08 19:18 GMT+02:00 Denis Obrezkov <denisobrezkov at gmail.com>:
>>> 2017-07-08 18:05 GMT+02:00 Joel Sherrill <joel at rtems.org>:
>>>> On Jul 8, 2017 10:09 AM, "Denis Obrezkov" <denisobrezkov at gmail.com>
>>>> wrote:
>>>> Hello all,
>>>> I worked with local interrupts last few days and found some strange
>>>> behavior:
>>>> I am trying to handle local interrupts.
>>>> That's what I do, in my handler for timer interrupts:
>>>> * disable timer interrupts in mie
>>>> * read a current value from mtime
>>>> * copy it to mtimecmp (both are 64bit width types)
>>>> * add some big value to mtimecmp
>>>> * enable timer interrupts in mie.
>>>> And I have two boards and the problem is that on one of them interrupts
>>>> are permanently generated because mip register is always 1 in mtip position,
>>>> though mtimecmp is greater than mtime, and are not generated at all on the
>>>> other.
>>>> Is there a procedure for clearing the interrupt?
>>> Yes, it is written that external interrupts are cleared by PLIC (external
>>> interrupt controller),
>>> software interrupts are cleared I think by the main thread (I didn't find
>>> it in docs), and timer
>>> interrupts are cleared by writing the value in mtimecmp memory-mapped
>>> register greater
>>> than in mtime  (memory mapped register too.) [2, p.28]
>>>> In this piece of code, I turn on interrupts:
>>>> la t0, RISCV_Exception_default
>>>> csrs mtvec, t0
>>>> li t0, 0x88
>>>> csrs mie, t0
>>>> csrsi mstatus, 0x8
>>>> Can you point us to the documentation and section where this timer
>>>> behavior is defined? Sometimes having someone else read it can provide a
>>>> different interpretation.
>>>> And is there other code like Linux which deals with this timer? There
>>>> may be a magic sequence you are missing
>>> I wasn't able to find a magic sequence and didn't look at Linux code, but
>>> I initialized it like in hifive1 example provided with FreedomStudio (IDE
>>> for HiFive1).:
>>> https://github.com/sifive/freedom-e-sdk/tree/master/bsp
>>> But these are the docs:
>>> Description of mstatus register, which contains mie field for global
>>> interrupt enabling (Ch 3.1.6):
>>> [1] https://riscv.org/specifications/privileged-isa/
>>> Description of the core, on which SoC is based (Ch 6 is about
>>> interrupts):
>>> [2] https://www.sifive.com/documentation/coreplex/e31-coreplex-manual/
>>> There are also description of the SoC:
>>> https://www.sifive.com/documentation/freedom-soc/freedom-e300-platform-reference-manual/
>>> and description of the chip:
>>> https://www.sifive.com/documentation/chips/freedom-e310-g000-manual/
>>> Regards, Denis Obrezkov
Hesham
